Question about JustCom JC-102CPA KVM Switch
I am looking for the manual, how do I toggle it?
I lost the manual long before I hooked it up.
I have a Model D12-100 flat-screen TV, hooked up to DirecTV. I have lost my TV remote and have lost the signal for DirecTV. How do I get the signal to the HDM1 or HDM2 category without the TV remote?
First off, D12-100 is your direct TV Box, Not your TV. A D-12 -100 direct tv box is not an HD box and will only connect to your tv via a coaxial cable or av jacks (red, white, yellow).
If you have lost your remote for your tv and your direct tv remote does not operate it, then you should be able to find the manual buttons on your television somewhere along the edge of the screen.
Toggle inputs till your on "TV" then use the channel selection to toggle it up or down till it's on channel 3 or 4 for Direct tv, If that doesn't work toggle inputs again and try the AV inputs. And of course if you want to use another device toggle inputs to HDMI 1 or 2.
Jan 05, 2015 | Televison & Video
Ignition switch dont work can i bypass it
LOOK AT IGNITION SWITCH IT HAS A PIN THAT HOLDS TUMBLER FOR KEY. DEPRESS PIN AND YOU CAN REMOVE TUMBLER, PULL IT OUT AND HOOK IT BACK TO WIRE HARNESS. JUST USE A SCREWDRIVER TO START AS USUAL.
Apr 18, 2014 | Holley 1985 Ford Bronco 5.8L Mechanical...
How to bypass brake jensen vm9215bt
Did this work? none of the codes (543210 / 1264) work for me. I dont want to hardwire it.
Oct 22, 2012 | Jensen VM9215BT
I just bought two flood lamps to fit to the bumper of my 95 jeep wrangler, how would i wire them to a toggle switch?
  1. 2-wires on each fog ligth
  2. toggle switch 2-hook up
  3. okay run hot wire from battery to one side of toggle
  4. on fog ligths one wire migth be white or black
  5. take one of the wire on fog ligth (white)&other fog ligth (white)wire
  6. take a wire hook both white wire from both ligths an hook to this wire an run it to the other side of toggle
  7. black wire on ligths hook them to ground
  8. after you hook the ligths up an they work it best to put a fuse connector between one of the wires on toggle
Dec 06, 2010 | Jeep Wrangler Cars & Trucks
I have an Dual brand 300 watt amplifier that I just bought and I hooked everything up right (battery---power, ground----sanded metal, bypassed remote with toggle switch remote-----+terminal on switch...
Is your toggle hooked to ground? Hook your toggle switch to the battery and then the other end of that toggle the remote input on the amp.
Aug 15, 2010 | Car Audio & Video
I've lost the manual. Can I hook a hose directly
yes you can, but you may have to drill it out to let the water out
Apr 10, 2010 | Maytag M7DH65B2A Dehumidifier
How can i add a leds (just for looking) to my bike?
Hook leds wire up to coil or run toggle and hook to battery
Jul 09, 2009 | 2002 Honda VT 750 CD Shadow A.C.E. Deluxe
Cannot hook monitor up to be primary laptop monitor
Your laptop should have a Function key and a monitor toggle button. THe function key is normally labeled "Fn" in the lower left corner of the keyboard, and the monitor toggle button is usually in the F-key row (F1-F12) at the top. Look for the key that has a picture of one or two monitors or rectangles. Hold the Function key down and press the toggle button a time or two. This should move you through the different viewing modes. What kind of laptop is it?
Jan 28, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
Hooking projector
You will probably need a standard VGA cable. The ends look like the connection for a monitor. Take a look if you don't know what I'm talking about: http://en.wikipedia.org/wiki/VGA_connector
There should be a port on your laptop and one on the projector. After it's hooked up you might have to toggle between the projection settings or select the correct source on the projector. Normally, there is a source or input button on the projector. If the picture isn't showing up on the projector but is on the laptop or vice versa, you'll need to toggle between settings. On my dell, it is fn (function) and the F8 key but sometimes it's the F7 key or some other F? key, just look for the LCD/CRT on the function button or the picture of a monitor looking thing. This is only if you don't see the image from the projector. Hope this helps you out!
Nov 09, 2007 | Compaq Presario 1200 Notebook
Initial set up
Hi Hit the menu button, and look for the word "idioma" which means language, and select that. You should then be able to toggle back and forth between English and Spanish. You may have to look under "opciones config. vcr" which is VCR Setup to find it. Hope this helps, Good Luck!
Mar 09, 2007 | Mitsubishi HS-U430 VHS VCR
JustCom JC-102CPA KVM Switch Logo
253 people viewed this question
Top JustCom Computers & Internet Experts
David Payne
David Payne
Are you a JustCom Computer and Internet Expert? Answer questions, earn points and help others
