Question about Asko D1716 Built-in Dishwasher
Water arms not turning - Asko D1716 Built-in Dishwasher
  • 76 Answers
Can u tell u r prb in detail plz...bcoz it will be helpful to me to explain u in detail to solve u r prb!!!
Posted on Jul 27, 2009
Middle spray arm is not turning
check the arm assembly bearing for free play,then the spray arm for food residue blockage,then if these are o.k.,then replace the water conduit that runs up the back interior wall of the washer,the basket has what is called a water horn and is rolled into and against the water conduit to get water to this arm to turn it,after time this horn loses fit and lets water get past it so you lose water pressure and it no longer gets the watert pressure needed to turn it
Nov 08, 2010 | LG LDF6810ST Stainless Steel Built-in...
Water not pumping through wash arms
It would be helpful to know the model no. of your dishwasher.
I few things to check
1. is the water getting into the unit - tap on etc.
2. are the spray arms free of debris - remove and clean the holes
3. do you hear the arms rotate when unit is turned on.
4. how do you know the water is not pumping through the arms
Hopefully we can diagnose the problem for you.
Jan 24, 2010 | Jenn-Air Dishwashers
Middle wash arm doesn't turn on quiet power 1 ge dishwasher
The last two holes (the ones wich give the spin to the arm) are blocked. Remove the arm and try to unblock with a thootpick and by running water into the arm.
Good luck
Jul 27, 2009 | Dishwashers
Bottom Spray Arm Not Rotating
check to make sure you are getting enough water entering the dishwasher. If you add a liter of water, does the water arm turn then? If so, you may have a faulty water valve that is not allowing enough water to enter to turn the spray arm. Hope that solves it :)
Feb 26, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Lower and upper spray arm will not turn
If the spray arm is not binding due to worn out plastic bushings, then it could be a lack of water pressure, because it is water pressure which makes the arm turn.
Give it a gentle tap in a clockwise direction,,does it spin easily?
If it does,,then it will be lack of water pressure that will be the cause.
Possible pump wear or failure.
Jan 30, 2009 | Maytag MDBE790 Built-in Dishwasher
Neff dishwasher
if the arm is rotating freely when you give it a push by hand, then the problem is blockage in the jets in the arm - the arm only rotates with water coming out of angled jets at the end. take arm out, spray water in centre hole and whatever is blocking the jets should become visible. prize out with a paperclip or similiar
Aug 07, 2008 | Dishwashers
Spray arm on KitchenAid KDC 17
water pressure should spin the arm. If it is not spinning and you have tub full of water-circulation pump could be the problem
Jan 05, 2008 | Dishwashers
Dishwasher
  This dishwasher does not feed water to top and bottom arms at same time.  It starts with bottom and then after awhile it switches to top and then cycles.  If water comes out arms but arms won't turn,  check all holes in arms.  It's the water spraying out these that causes arms to turn.   If arms spin freely by hand,  it's a plugged arm or holes in arm or insufficient water in tank.
  Being that it only sprays 4 inches suggests a water level problem or possible mineral build up restricting flow.
Oct 11, 2007 | Frigidaire 24 in. PLD2850 Built-in...
Bottom Dishwasher arm not turning
have you seen whether water is pouring out of the bottom supply tube with the lower arm removed? not 100% sure on this model but some units have a half load switch but that should turn off the top one. there may be a blockage in the lower water supply tubeways.
Jun 15, 2007 | Bosch 24 in. SGS43C12 Classixx...
I replaced the spray arm seal, but the arm still wont spin. I get water but not enough pressure to turn the top arm. The bottom arm works fine. Should the top arm turn easily when pushed by hand. It...
arms should turn freely. spray arms are only rotated by water spraying out from angled jets at end. check for blockage in spray arms - sweet corn and rice are the worst offenders. take spray arms off and run water in centre hole and see it runs out of all the jets freely
Apr 08, 2007 | Whirlpool GU2400XTPS Built-in Dishwasher
Asko D1716 Built-in Dishwasher Logo
83 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Owen Barnes
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
