Question about Philips 43PP9202 43" Rear Projection Television
Replacing convergence ic on Philips 43pp9202
Is replacing the convergence ic's on my Philips 43pp9202 something that I would be able to do my self or will I have to have a tech do it?
  • Philips Master
  • 5,138 Answers
Re: replacing convergence ic on Philips 43pp9202
IF you can solder yes you can fix it yourself. Replace STK-392-110s with STK-392-180s,
Posted on Nov 22, 2007
0 characters
3 Points
Convergence problem
replace the convergence ic. the IC# is STK392-120, replace this two ic at the same time. then put some silicon grease on the back of the IC for better heat transfer. some will work on replacing just 1 IC but I would recommend to replace both per philips advise. hope this help. regards, cebuwano.
Mar 17, 2009 | Philips 43PP9202 43" Rear Projection...
Red Convergence issue. Can't adjust. 3d picture.
If you can solder, try resoldering the pins on the convergence ICs. If that fails to resolve the problem, replace the ICs. Please note that there are potentally dangerous hogh voltages present inside hte set even when unplugged.
Keep us posted on your progress.
Feb 21, 2009 | Philips 43PP9202 43" Rear Projection...
Hi there, i have an old Philips 43pp925/79 rear projection tv. A few weeks ago convergence ic went bad, so i replaced them both and i replaced 6 resistors. Now there is no bending on the screen but...
You will have to go into Service Menu to realine convergences and What was the STKs numbers you replaced/ and did you go with same part number?I think i have service code for this set will have to look thur my files.
Dec 24, 2008 | Philips 43PP9202 43" Rear Projection...
Convergence problem
Some how instead of posting this to another persons problem it posted here.Hmm Oh well you said you replaced STKs what was their numbers and you may need Service Code also to Realine convergences
Philips Rear Projection TV 43PP9202 Picture looks 3D
You need to replace both convergence ICs they are STK392-120 you will also need about four 6.8 ohm 1 watt resistors. You can get replacement ICs and resistors at the following link and they provide free instalation instructions with pictures. here is the link.
Jul 20, 2008 | Philips 43PP9202 43" Rear Projection...
you can do this yourself and if you buy your parts at the sight I posted you also get pic installation instructions as well as free online tech support
May 10, 2008 | Philips Magnavox 51MP392H Rear Projection...
Its a straight forward repair just take out the convergence ICs and solder in two new ones. takes about an hour from beginning to end. just apply heat sink compound on the new ICs before installing them. And in that model check the resistors right next to the ICs as 1 or 2 of them often burn open when the ICs go out. Let me know if you need any additional info. The ICs cost about 10.00 each you will ned two.
Mar 23, 2008 | Philips 43PP9202 43" Rear Projection...
Phillips chirping
two STK392-120 convergence modules that usually cause the beeping. So I changed them both again, but I also found two open 7.5 ohm resistors are in the general area of the convergence modules, and I replaced them as well. I also replace 1 swollen capacitor that was probably going to blow in the future but not really a problem yet.
Sony Convergence
Jan 25, 2008 | Philips 43PP9202 43" Rear Projection...
PHILIPS 43PP920217
Either a convergence problem where the 2 stk's need changing and resistors in that area, or the vertical Ic is damaged and needs replaced.
Aug 04, 2007 | Philips 43PP9202 43" Rear Projection...
Help tv comes on and goes right back off
A common problem with this model is the convergence IC's on the small signal module going bad and keeping the set from staying on due to protective shutdown circuits used. If that is your problem, the easiest fix would be to replace the module - Philips Part #313503710091, about $200 or so, or have a technican replace both IC's Stk392-120, Philips Part #932212344682 about $45.00 each plus labor and service charge of course. Other parts could be bad, but this is likely what I would try first.
Feb 09, 2007 | Philips 43PP9202 43" Rear Projection...
Philips 43PP9202 43" Rear Projection Television Logo
75 people viewed this question
Top Philips Projection Televisions Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Projection Television Expert? Answer questions, earn points and help others
