Question about Intel D845GVSR Motherboard
Switch on problem no processor running
Switch on the power supply mother small LED only working not processor fan and power supply fan not running plz give a solution
845gvsr no display given ram beep but ram ;ram ic and bios is ok what can i do sir
Posted on Jul 27, 2009
Hello hamara mother board tntel D845 problem
Posted on Aug 09, 2009
2 Suggested Answers
ekcnoel
  • 998 Answers
SOURCE: switch on the power supply
To narrow the problem remove the power supply to the unit then get a small wire to short the green and black wire it is the switch of the power supply, if you do this and the power supply power up, to know that the power supply power up, look at the fan it will turn on.
Posted on Sep 02, 2011
with metal electric tester touch the pins that turn on computer, pins on the side marked with pw
Jul 17, 2014 | Intel D845GVSR Motherboard
Sep 02, 2011 | Intel D845GVSR Motherboard
I am not sure if this is a problem with power supply. Yesterday suddenly my machine stopped working. I wasnt using it. It just shut off. Now when I started the cpu, I see one green LED on the mother...
the problem is in your motherboard..this most cause unregulated flow of power from the source electric..but if the green led is off so its the processor.try to test it with a motherboard tester..or get another board that same spec with the you have,and transfer the processsor if it is working
Feb 10, 2011 | Cooler Master RS-400-PSAR-J3 400W ATX12V...
The computer has on occasion crashed for no apprent reason. I had the power supply out and it has normal light indications until it i plugged into the mother board. I have had itwork normally, for a...
Bad Power Supply. Weak voltage power rail.
Bestec is a low quality power supply. Used to save the computer manufacturer money.
Also, a Power Supply with a weak voltage power rail will put out enough power to light LED lights, and perhaps spin fans, but not enough power to turn the Processor on, and/or keep it on.
A) ALL the LED lights use less than 1 Watt of power.
B) EACH fan uses 2 to 3 Watts
C) A typical Processor uses 51 to 125 Watts. Depends on what Processor it is.
Replace the Power Supply. Clean the inside of the computer out, with a can of compressed air for computers before installing.
What is the computer manufacturer name, and Model Number. The Model Number is on the back of a desktop computer tower next to the Windows product key, or up on the side of the computer tower.
Post back in a Comment.
Regards,
joecoolvette
Dec 04, 2010 | Bestec ATX-1956F (ATX1956F) 200-Watt Power...
RE ASUS P5S800-VM Motherboard.. system will not power up.. processor heatsink fan does not power up ... but ... removing processor and pressing power switch fan does work.. what is the problem??
[There are three main power rails in the SMPS for your desktop computer.
A) The 3.3 Volt power rail
B) The 5 Volt power rail
C) The 12 Volt power rail ]
1) ALL of the LED lights on at once use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical Processor can use 51 to 125 Watts of power.
Just depends on what Processor it.
Remove the Processor, and you will have power to light LED lights, and spin fans.
Of course without a Processor operating, you have No computer.
Do you have a KNOWN to be good, Compatible power supply available to use for a test unit?
Need guidance in replacing, or suggestions for Power Supply's to choose from, post In a Comment.
Regards,
joecoolvette
Dec 02, 2010 | ASUS P5S800-VM Motherboard
Just had to reatach my fan back over the processor but i took the mother board out and my wires came off the mother board which where for the power switch and the reset button, can anyone tell me which...
Hello Sir, hi, the wires on your casing are usually labeled, like in the picture below: cyberdyers_0.jpg
the power led green wire goes to the power led + and the white goes to the - . Now the HDD + goes to the HDD + the red wire, power switch can be interchange, same as the reset switch.
Dec 01, 2010 | Computers & Internet
Computer not working
Try to reseat the connectors on the mother board.
Feb 21, 2010 | NEC (190300) 235-Watt Power Supply
Psu shut down
99% TIME IT IS A FAULTY FAN GOING OUT.
REPLACING THE FAN INSIDE THE POWER SUPPLY WILL RESOLVE THE PROBLEM.
P/S ARE CHEAP, JUST BUY A NEW ONE OOR REPLACE WITH ONE YOU HAVE ON HAND
CANDYMANGANDY
Jan 27, 2009 | Antec Solution SL400 Power Supply
TO noggin
remove all pwoer connector from motherboard and short green and black wire in supply shocket.If supply is run then it is the problem of motherboard.
Feb 28, 2008 | Dell - NPS-200PB-73M (NPS200PB73M) Power...
Intel D845GVSR Motherboard Logo
389 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
