Apple iPod nano Logo
Posted on Jul 27, 2009
I forgot my code on volume limit - Apple iPod nano
Anonymous
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Aug 10, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
0
Helped
557
Points
6
I believe that if you plug in ur ipod to a computer it should reset it but i am not sure. you could just reset your ipod by holding menu and the center button at the same time.
Dont know the code to unlock my ipod screen and volume limit
this should help you below. If you have set a password on the volume limit and forgot the password please let me know cause you will then have to remove the password or restore the device. This is only one step in trying to remove the volume limit it may work or it may not and you will have to use another method. But please tell me if this method works and if it doesnt i will instruct you on where to go from here. To set the maximum volume limit for iPod classic: 1 Choose Settings > Volume Limit. The volume control shows the current volume. 2 Use the Click Wheel to select the maximum volume limit. You can press Play to hear the currently selected song play while you select the maximum volume limit. 3 Press Play/Pause to set the maximum volume limit. A triangle on the volume bar indicates the maximum volume limit. 4 Press the Menu button to accept the maximum volume limit without requiring a combination to change it. Or, on the Enter Combination screen, set a combination to require that the combination be entered to change the maximum volume limit. If you cannot remember the passcode, you will need to restore your device using the computer with
which you last synced it. This allows you to reset your passcode and resync the data from the device
(or restore from a backup). If you restore on a different computer that was never synced with the
device, you will be able to unlock the device for use and remove the passcode, but your data will not
be present Follow the steps that i have outlined below. If this does not completely help your situation please
let me know and i will be glad to assist you. According to Apple, if you have forgotten the code, you can unlock the IPod by doing the following: 1 If you can't unlock IPod using either [the code or connecting it to the computer you use to manage
its songs. . . Plug the iPod USB cable into the bottom of the iPod Nano. 2 Plug the other end of the iPod USB cable into a free USB port on a Mac or PC computer. 3 Open the iTunes application by clicking on the Dock icon on a Mac or using the Start menu on a PC. 4 Click on the name of your iPod Nano under the "Devices" list in the iTunes window. 5 Click on the "Sync" button to establish a connection between your iPod and the computer. 6 Click on the eject symbol next to your iPod's name after the syncing process has finished. 7 Unplug your iPod Nano. The device will be unlocked and you will be able to access all normal features
again. if that does not work you can restore your iPod to factory settings using iPod Updater. Please note
that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod. If you want to change the primary computer that your IPod is associated with, do this: 1. Restore your iPod. WARNING: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data. 2. Connect your iPod to the computer that you want to be the primary computer. 3. Open iTunes and synchronize. Apple also notes that company "representatives cannot unlock an iPod if you forget your combination.
If you can't unlock your iPod and you don't have access to the primary computer, your only option is
to restore the IPod, which will erase all music and data." If you need further assistance please feel free to follow up with a comment and i will be here to
assist you. If this assisted you please feel free to rate the comment. thanks and have a great day.
I forgot my volume unlock code on my ipod 80gb
Oh dear. Connect your iPod to your computer, open iTunes and click the (Restore) button. This replaces everything on your iPod with new stuff from iTunes. You will be able to reset your volume limit code but use something that's easy to remember like your postcode
1helpful
3answers
I need to the code for the model ma477ll
I forgot my code to my ipod how do i put in a new one?
I cant unlock the volume lock
First what happen to your Ipod? just connect your ipod in your pc with installed i tune that fit to you're ipod and click restore it click next.
CANNOT FIND UNLOCKING CODE FOR VOLUME LIMITER ON IPOD CLASSIC BLACK 120GB
this should help you below. If you have set a password on the volume limit and forgot the password please let me know cause you will then have to remove the password or restore the device. This is only one step in trying to remove the volume limit it may work or it may not and you will have to use another method. But please tell me if this method works and if it doesnt i will instruct you on where to go from here. To set the maximum volume limit for iPod classic: 1 Choose Settings > Volume Limit. The volume control shows the current volume. 2 Use the Click Wheel to select the maximum volume limit. You can press Play to hear the currently selected song play while you select the maximum volume limit. 3 Press Play/Pause to set the maximum volume limit. A triangle on the volume bar indicates the maximum volume limit. 4 Press the Menu button to accept the maximum volume limit without requiring a combination to change it. Or, on the Enter Combination screen, set a combination to require that the combination be entered to change the maximum volume limit. If you need further assistance please feel free to follow up with a comment and i will be here to
1helpful
Volume limit unlock code
2answers
I forgot password of my ipod model no: A1137,2 GB
HELLO!!!!
I've been using iPod nano for 1 year.I forgot password for volume limit lock. so i can't change the volume.Plz tell me how 2 unlock the volume limit. Reply @ early as possible.
Ipod lock code
  1. Enable hidden folders.
    In Windows Explorer,go to "Tools", "Folder Options". Then click on the tab called "View", and under "Hidden Files and Folders", click "Show Hidden Files and Folders".
  2. Navigate ("My Computer" to double-click on the icon of your attached iPod) to the hidden folder named "iPod_Control", and once there click on the folder "Device". Once there, delete the file named "_volumelocked".
  3. Eject your iPod. Then, restart your iPod. You can do this by holding down the center and menu button for at least 6 seconds.
  4. Once your iPod has rebooted, check and make sure that it worked. Simply go into "Settings", "Volume Limit". If it asks for a PIN, you did it WRONG. Retry the above procedure.
5helpful
3answers
Reset ipod nano code
restore your ipod using itunes, and it should reset that pass word
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
