Question about Heavy Machinery
I need a makita safety relay/switch for my DSH 2301 Makita part No 650 010 083 Can You help please
  • 313 Answers
SOURCE: makita 1420 - 14.4v 1.3Ah cordless drill
try toolpartsdirect.com & go to makita & type in model #
Posted on Jun 09, 2008
danny_murray
  • 55 Answers
SOURCE: I need a owners manual for my makita LS1011
Here this should help out
http://www.makita.com/en-us/Modules/Tools/ToolDetails.aspx?ID=370
Posted on Dec 05, 2008
SOURCE: makita table saw switch wiring
After much trial and error, a little smoke, and wrecking one replacement switch, I solved a similar problem with my Craftsman Cmpd Mitre saw. Different saw, but likely the same principles are involved.
If the switch is a double pole single throw switch, with one side normally open (N0) and the other normally closed (NC), and the saw has a separate wire for the brake, this will probably work.
One side of the switch should have contacts that are normally open (NO) and only connect when the switch is ON. The Hot (Black) wire from the plug connects to the wire on the machine side (red or maybe black) through this NO side. So, connect these two wires via this NO side and the saw will run when the switch is ON but will have no brake; so far so good.
There should be another wire (Not the neutral white) which is the brake wire. This gets connected to one of the connection sites of the Normally Closed (NC) side of the switch. From the other connection site of this NC side run a short "jumper" wire (of the same guage as the other wires) to the Machine Side of the NO side of the switch (same place as that Red or Black? wire above) .
What seems to happen is this:
There's no power to the machine or the brake when the switch is OFF. Turn it ON and power goes from Hot through the NO (now closed) side and the saw runs. The brake doesn't run when the saw runs because the NC switch is now open. Turn the switch OFF and the NC switch is in fact closed and power is transfered to the brake via the jumper wire from the still spinning armature which now acts as a generator (alternator?). Once the brake has done its job and the armature stops spinning there's no power anywhere until you turn the switch ON again.
Or at least that's the theory, and in my case it works; no more smoke.
Posted on Feb 04, 2009
johnnymills
SOURCE: Need to know what the lights mean on a makita dc24sa charger
• When the battery cartridge is inserted, the charging light color will change from green to red and charging will begin.
The charging light will remain lit steadily during charging.
• One red charging light indicates charged condition in 0 – 80% and two red ones indicates 80 – 100%.
• With finish of charge, the charging lights will change from two red ones to two green ones.
• The charging time is as follows:
Battery B9017A, BH1220, BH1420, BH9020A: approx. 20 minutes.
Battery B2417, BH1233, BH1433, BH2420, BH9033A: approx. 30 minutes.
Battery B2430, BH2433: approx. 60 minutes.
Posted on Apr 07, 2009
gaz-dee
  • 62 Answers
SOURCE: need diagram of switch for a 6302 drill
try hear http://www.ereplacementparts.com/makita-6302-drill-parts-c-97_106_147_473.html
Posted on Oct 28, 2009
Makita MLT100 table saw when stop button is pressed the motor switches off saw seems to be running really roughly and the the blade takes an age to stop spinning. Normally blade stops really quickly.
I can't find this saw at Makita; so, generally. Follow all safety precautions. :-)
If the saw is running rough, the first thing I'd check is the brushes for the motor, especially if it has any age. These are fairly inexpensive and will solve a lot of woes. The next thing would be to check the thumb switch, if it has one. This is the switch that allows you to pull the trigger to run the saw, if it's just a button, then check the actual trigger switch to make sure it's working properly as it probably, not always, also engages the brushes to reverse the motor for a second, to slow it down so it stops faster.
So, check the brushes on the motor, if they show any signs of wear, it's probably them. 2nd, check the switch. Please let me know and if I've helped, give me a vote up. Thanks.
May 18, 2017 | Makita Saws
Can i bypass the switch on a makita skill saw
OMG, absolutely NOT!
I know a guy without 3 fingers due to one of those on a construction site. He said he never felt a thing.
Buy a new switch.
  • Makita Canada Inc. www.makita.ca Makita Canada: The best in class for cordless power tool technology. A leader in power tool technology for the professional.
  • Makita Saw Parts ' Great Selection ' Great Prices ... www.ereplacementparts.com/makita-saw-parts-c-97_98.html Fix your Makita Saw today with parts, diagrams, accessories and repair advice from eReplacement Parts! Worldwide shipping, no hassle returns.
  • images of makita saw parts bing.com/images th?id=oip.m79ac54922c7af758ce5909fe9cde9163o0&w=87&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.m8226e4e7540d1403e6b34f0609fee8ado0&w=87&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.mc9c1b6c779ab4de644cda35842865ffbo0&w=87&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.mfb5ac75b7411568957f4d7028521f0b4o0&w=80&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.mdd935730eb9fe8614bf23952794b8ca9o0&w=87&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.md1140885e7ec8b5124cabfe71fdb3085o0&w=87&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2 See more images of makita saw parts
  • Makita Power Tool Parts - Makita Parts - eReplacementParts www.ereplacementparts.com/makita-parts-c-97.html We have the genuine Makita parts and tool repair help you need to get your power tools running like new again.
  • Makita Parts - Tool Replacement Parts ' Tool Parts Direct www.toolpartsdirect.com > Brands Makita Tool Parts - Shop Makita parts online at Tool Parts Direct. Over 38,000 Makita replacement parts and schematics available.
  • Related searches for makita saw parts
  • Makita Tool Parts :: Makita Saws - Tool Parts Canada ... www.toolpartscanada.com/makita-tool-parts/makita-saws-page-3.html Please choose your tool from Makita Benchtop line below view parts breakdown
  • Makita Saw Parts ' Sears PartsDirect www.searspartsdirect.com > All Brands > Makita Parts Shop the best selection of Makita saws repair parts and accessories at Sears PartsDirect. Find replacement parts for any Makita saws repair project.
  • Makita - Authorized Factory Service Centers www.makitatools.com/en-us/Modules/Service/ServiceCenters.aspx Makita Authorized Service Centers meet our high-quality ... Genuine quality Makita replacement parts; Most tools repaired within 3 days; Maximum Repair Cost Program;
  • Makita Saw Parts ' eBay 9k= www.ebay.com/bhp/makita-saw-parts Find great deals on eBay for Makita Saw Parts in Corded Circular Saws. Shop with confidence.
  • PARTS - Makita UK https://www.makitauk.com/shop/parts Parts . Ask Makita ' Find a dealer. Part search Search for tool drawing: Filter: 1 - 2 - 3 - 4 ... Contact Makita! 01908 211678. Monday - Friday 8am to 5:30pm.
  • Makita Tool Parts - Tool Parts Canada - Parts that makes ... www.toolpartscanada.com/makita-tool-parts.html Please Choose Makita category Below Which Matches Your Tool
  • Jun 20, 2016 | Makita Saws
    Makita How To wire the switch
    Did you look up the parts breakdown at Makita.com? They often have wiring diagrams on the parts breakdowns. Just enter the model number in the search window and it should take you to a page that will have a link to the parts breakdown.
    Nov 17, 2013 | Saws
    What size replacement chain do i need for a makita 5012b chainsaw
    I went here:
    Oregon Bar & Chain Selector
    http://www.oregonchain.com/pro/lookups/selguide.aspx?BusId=OCS&SellReg=USA&LangId=ENG
    Chose :Makita;5012B;12";All:All:All"
    There are different gauges and numbers of drive links depending on the bar in use. Please for your safety stop in a local saw shop with your existing chain. It can be used as a template to fabricate a replacement in a few minutes (inquire about gauge and # of drive links). Once you have a new one leave the old one with them and for a small additional fee they will sharpen it.
    If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
    Lou
    Thank You for using FixYa.
    Apr 17, 2010 | Makita 5012B 12'' Electric Chain Saw
    Makita table saw switch wiring
    i need the owner/operator manual for a makita table saw model 12711 please tell me what steps to take to get one
    Mar 01, 2009 | Makita Saws
    Need to Replace Makita Drill Switch
    If you have the switch and know what tool you bought it for go to MAKITA.com and under Authorized and Factory Service centers in the tool bar, click on it and the page will open to allow you to view or download a schematic for this product. Hope this helps. Dave
    Dec 19, 2008 | Drills
    Heavy Machinery Logo
    103 people viewed this question
    Top Heavy Machinery Experts
    Bill Boyd
    Tom Chichester
    ray gallant
    Are you a Heavy Machinery Expert? Answer questions, earn points and help others
