Pump not coming on and does not make any noise. I removed the back cap and the shaft turns. Problem started one week ago.
SOURCE: 98 f150 4.2 110.000 miles went to start up engine started clacking and smoking out exhaust
the intakes go bad on these engines....... they leak coolant in the cylinders and cause a hydro lock that causes the rods to bend making the piston skirt hit the crank......" clicking noise" theres a law suit in progress for this issue......... you can find info on the internet
SOURCE: pwr steering pump failure GM truck
check to see if truck has a power steering pump cooler try to bypass cooler sounds like it has a blockage in the cooler not allowing fuild to circulate should fix problem
SOURCE: 2006 Cobalt fuel pump
That does happen ~ more often than you would think,unfortunately. The 2006 Cobalts seem to be falling to pieces right now,though. If you are still under warranty make them check and repair everything especially your computer.
SOURCE: 1995 Lexus ES300 car wont start, tried alot of
check your fuse box. you might have a blown fuse
SOURCE: a few seconds after brakes are applied the pedal
you have two problems here, your master cylinder has a leaking seal, the low pedal is resault, the power brake booster rubber diaphram is damaged and leaking from the brake fluid that is getting into it from the master cylinder, these are sold as a unit that has been rebuilt.
Testimonial: "Thank You for your response. However there is a new twist that I posted."
