Question about General Electric Clothes Dryer Knob - WE1X1208
My dryer knob fell off, and the plastic rod that it attaches to broke off. What do I do?
I think your switch is mounted to the back panel and has fallen off. The stem that holds the knob is still there, the switch has just fallen down into the space behind the back panel. You can remove the back panel with 3 screws across the top rear (unplug it first!). I'm afraid you will find the back panel requires replacement to solve this. It is about $80, and all the switches will have to be re-mounted on the new panel.
Posted on Sep 28, 2011
  • 30 Answers
Try and glue it or just buy a new one. sounds like it was made in japan
Posted on Jul 27, 2009
Where to get a top thread tension control part for model 1595281?
If the rod broke you are a goner. Time for a new machine. A photo would help.
Jan 30, 2014 | Kenmore Sewing Machines
Replace door handle
You must be talking about the door handle itself. The rod connects the door handle to the door latch. The plastic clip when snapped onto the rod will keep the rod from coming out of the hole in the door handle where it attaches. Is it the handle that is broke or the clip?
May 23, 2013 | Chrysler 300M Cars & Trucks
GFDN240ELOWW
My husband just fix my GE Dryer GFDN240WW "Start Button broke" issue. Here is what he did; He removed the control knob to access the phillp screw. Unscrewed screw and lift up on control to remove panel and unhook power supply. Then set control panel on face. Unscrewed 5 larger screws to removed black plastic panel w/ mother board attached. Set board aside and located power button which was broke off. Compare button to all other buttons on panel to see how they are attached to panel. My husband used Plumbers Goop from Lowes store to attached power button like the others. Then he reassembled the dryer and presto! It works!
Jun 09, 2012 | GE Dryers
Inside the drum, there are three "panels" attached to to the wall of the drum. I guess they are used to tumble the clothes so the heat is evenly exchanged? One of the panels broke off. ...
It wont hurt anything to use it like that. The screws probably fell outside the drum when they came loose. You can look at the other two to see how they are fastened if you want to put it back on.
Apr 01, 2011 | Dryers
Drivers door won't open using outside latch.
The rod connecting the outside latch handle to the latch catch is disconnected. Someone will need to take the door panel off and repair the connection rod. It was a broken plastic connector that joined the rods on my 2003 Kia Optima that caused the problem.
Mar 01, 2011 | 2002 Kia Sportage
How do you find the connection point for the horizontal rod that goes from the inside door handle to the vertical rod (with plastic knob at the top of it) that locks/unlocks the door? The car is a 1998...
The horizontal rod doesn't actually connect to the vertical rod. The horizontal rod connects to the door latch mechanism. The vertical rod also connects to the door latch, but at a different location. If as I'm guessing the horizontal rod has become dis-connected, it's probably because either the connector broke or fell off. If you need any further clarification, please leave a comment and I will try to help.
Jan 15, 2010 | 1998 Toyota Corolla
Broken door lock on a 1997 Saturn
The rod may have gotten bent causing the plastic clip to break. Strighten out the rod so it has it's length again to push on the luck to unlock the door. Good luck and hope this helps.You don't have to remove the rod, you can do it in it's place with your fingers.
Jun 17, 2009 | 1997 Saturn SL
MAYTAG ATLANTIS DRYER TIMER SWITCH
the key is to dismantle the font ofthe knob assy( the small plastic center of knob pulls out) it also acts as a locking ring /clip to hold unto the new timer shaft
Mar 18, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
General Electric Clothes Dryer Knob - WE1X1208 Logo
769 people viewed this question
Top General Electric Hardware & Accessories Experts
jdthefixer
Freddy
Are you a General Electric Hardware and Accessory Expert? Answer questions, earn points and help others
