Question about Acer Aspire 5920-6727 Notebook
I got LED lit on but black screen. No harddrive movement or sound
I can turn on and off the LEDs but screen still got nothing. No spinning sound of fan or drive..
    President:
  • 1,383 Answers
When you power up the computer press F8 key if you can see safe mode and otehr menu then you can do it.
Enter in enable vga mode then change screen resolution 1024*768
Posted on Jul 27, 2009
Reset counter
By the way, what is the make and model of your printer?
  1. Resetting the Drum Page Counter
    • 1 reset-counter-dell-laser-printer-1.1-800x800.jpg Toggle switch in back of the printer. Shut off the printer.
    • 2 reset-counter-dell-laser-printer-1.2-800x800.jpg Front door opened Hold down the "Continue" button while opening the front door. Then turn on the printer.
    • 3 reset-counter-dell-laser-printer-1.3-800x800.jpg Error LED lit Keep the Continue button held down until only the "Error LED" is on then release the button. Close the door.
    • 4 reset-counter-dell-laser-printer-1.4-800x800.jpg Top 3 LEDs lit. The Continue button, Ready/Data, Toner Low, and Load Paper LEDs should all be lit up.
    • 5 reset-counter-dell-laser-printer-1.5-800x800.jpg Toner low LED lit. Press "Cancel" a few times to cycle through the LEDs until just the "Toner Low LED" is lit.
    • 6 Press and hold the "Continue" button until the LEDs cycle through and release only when the LED stops at Toner Low.
    • 7 Turn the printer off and back on.
I hope you find it very helpful. Best regards.
Aug 16, 2011 | Office Equipment & Supplies
Washing Machine stopped through cycle and now will not turn on
Check the wiring harness, connections, contacts, etc. Look for some corrosion and loose connections. Also, check the water inlet for anything that may cause a reduction in water flow.
Dec 02, 2007 | Fisher Paykel EcoSmart GWL15
Tip
The Fisher & Paykel Smart Drive and EcoSmart electronic washing machines are...
The Fisher & Paykel Smart Drive and EcoSmart electronic washing machines are equipped with fault detecting software to help easily determine the cause whenever a problem occurs. Not like other electronic washing machines, these ones do not have displays to flash the code, but rather use the eight (8) light-emitting diodes (LED) of the Wash Progress indicators to indicate the fault code. The eight (8) LEDs stands as an 8-bit binary number (zeroes and ones) that must be decoded and then converted to the decimal number system to get the fault code.
The fault code can be decoded by determining which Wash Progress LEDs are lit. Once determined which of the LEDs are lit, write down the 8-bit binary code; 1 for lit LEDs and 0 for the off ones. For example; the final wash, rinse, and spin LEDs are lit; the binary code is 00001101. This in turn can be converted to the decimal number system by multiplying each digit with its corresponding place value then adding up the result. From left to right, the place values are 128, 64, 32, 16, 8, 4 , 2, and 1 respectively. Therefore, the decimal equivalent of 00001101 is 128(0) + 64(0) + 32(0) + 16(0) + 8(1) + 4(1) + 2(0) + 1(1) = 8 + 4 + 1 = 13; the fault code is 13.
on Apr 17, 2010 | Electrical Supplies
Touch pad always lit up...
Yes, if the leds are all lit and no respnse, then your board in the top counsel is faulty. Have you haad any power surges recenlty.? Power surges sometimes mess up computer boards. But yeah, it sounds like its bad tho. There should be led light on unless you start pushing buttons. Have you hit the "off" selection. If nothing turns off the led lighting, it sounds like the board might be bad...hopefully this helps
Jul 31, 2009 | Maytag Neptune MAH5500B Front Load Washer
Compaq V5005us is weird. Powers on with black screen and freezes
It sounds like your Video card and/or motherboard are starting to give out or your LCD is giving way. Try plugging the laptop into an external screen and see if it still acts strangely or even displays on the external monitor.
Mar 18, 2009 | Compaq Presario 2100U Notebook
Toshiba A105 keeps Restarting ---
maybe the power input is error
the uncorrect power input will result bad
or, it's your mobo broken
Jan 25, 2009 | Toshiba Satellite A105 Notebook
Black screen and numbers 2 and 4 lit
The 2 and 4 LED error code indicatesVideo subsystem configuration or failure”. You either have a bad video circuit or your video drivers have a problem. Try booting into “safe mode” by tapping the F8 key when powering on the computer. If the computer comes up in safe mode then your video drivers may have to be reloaded.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 15, 2008 | Dell Dimension 9150 (DIM915MIN) PC Desktop
My fisher paykel eco smart is GWL11 not GWL15
00110001 CODE 49 COLD VALVE FAULTY
1 FILTER IN HOSE AT TAP END CLOGGED OR FILTER IN VAVE AT MACHINE END OF HOSE CHECK THESE FIRST .
2 SOLENOID OPEN CIRCUIT OR BECOMING OPEN CIRCUIT WHEN HOT.
3 CONTROLLER NOT SUPPLYING VOLTAGE TO SOLENOID.
TRY THINGS IN THIS ORDER AND GOOD LUCK
Jun 27, 2008 | Fisher and Paykel GWL11 Top Load Washer
Press "end of cycle" for 5 seconds or more to clear the screen. Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Acer Aspire 5920-6727 Notebook Logo
116 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
