Check if the internal ventilation fan is running. It is intended to cool down the oven exterior. Some units made 2004-2007 can overheat during self-cleaning.
the problem is the fan is either bad or there's a screen near the fan,it could be blocked with dust but f34 is a problem with the cooling fan,the fan cools off the electronics and your machine is overheating and shutting down,check the fan
We had this problem a long time ago.. At the very bottom of the lower oven there is a slot.. Maybe 1" tall.. Look in there with a flash light. You will see 2 sail switches.. More then likey one of them is stuck.. The other problem could be the fan motor not running which would cause the same error.. "Fan air flow" But if you are getting flow it is probably the switch,.
