Question about Lands Phones
Fdh my security keypad lock is not opening.
  • 421 Answers
I forgot my samsung cell phone keypad and now i dont know how to unlock it??
Hi Friends,
Press the menu button and * you phone keypad is open. the mention instruction how to use phone keypad lock.
  1. From the standby screen, press Menu
  2. Press Settings
  3. Press Phone
  4. Press Security
  5. From the Lock Phone section press one of the folllowing:
    • On- The phone locks immediately and stays locked until you enter the correct lock code
    • Off- The phone remains unlocked
Sep 03, 2011 | Samsung Cell Phones
Tip
How to lock a Samsung Intensity cell phone
Unlike flip phones, cell phones like the Samsung Intensity are subject to accidental keypad-pressing and dialing when they are in your pocket, purse, or even a holster. To avoid unintentionally using up voice or data minutes, you can lock your phone and temporarily disable the keypad.
There are two ways to lock a Samsung Intensity - the standard keypad lock and the security lock.
- To use the standard lock:
You can lock your phone at any time from the main screen by holding down the "0" key for about two seconds. The keypad will immediately lock, and you won't be able to use any functions or make any calls (except for calling the local emergency number). To unlock the phone, press the right option button (in the upper right corner of the keypad, next to the End button) followed by the Menu or OK button.
You can also set up Auto Key Lock, which will automatically lock your keypad after the backlight turns off. The Auto Key Lock setting can be found in the menu under Settings & Tools > Phone Settings > Auto Key Lock.
- To use the security lock:
The security lock also prevents your keypad from being used, but it requires a code to be entered in order to unlock the phone. To enable the security lock, go into the main menu and select Settings & Tools > Phone Settings > Security > Lock Phone Now. (You'll need to know your phone's security code in order to access this setting -- by default it is typically the last four digits of your phone number.)
To unlock the phone, press the right option button and then enter your phone's security code, followed by the OK button.
You can set your phone to go into security lock mode as soon as you turn it on by enabling Phone Lock Setting under the Security menu. Every time you turn your phone on, you'll need to enter the security code in order to unlock it. However, once you unlock it, it will remain unlocked until you either manually lock it or turn it off and then back on.
on Mar 04, 2011 | Samsung SCH-U450 Cell Phone
My security code for keypad lock i forgot...i want to open & i want to use back but i forgot what code i use before..
To remove the security lock,get the master reset code from here
Simpleunlocking.com
and reset from security Lock or password Lock.
Aug 08, 2011 | Nokia 1600 Cellular Phone
I want your phone locker?
You can set up a security code to lock your Nokia 6288 keypad in case a thief tries to call from your stolen phone
Published on Mar 14, 2007
You can set up a security code to lock your Nokia 6280's keypad in case your phone opens in your pocket and calls one of your contacts, annoying them and potentially running up a huge bill.
The code will also stop a thief from using your stolen Nokia 6280 to run up a huge phone bill before you can alert your network provider.
To set the security code, click Menu > Settings > Phone > Security keyguard. You'll be prompted for the Security code. By default this is 12345. Enter this and press OK. Select On and click Select to see the message 'Security keyguard activated'.
Now when you slide your phone shut and press Lock, you'll see the message 'Keypad locked with security code'.
When you slide it open, you'll be prompted to enter the security code. Type your code and click OK to activate your keypad.
Of course, if any potential phone thieves are reading this, they'll now know the default security code is 12345.
To change the security code, go to Menu > Settings > Security > Access codes > Change security code. When prompted, enter your current security code and click OK. The enter your new security code (a PIN between 5 and 10 digits in length), click OK and enter the new code again to verify it. Click OK and you'll see the message 'Security code changed'.
Hope this helps.
Jan 12, 2011 | Nokia Lands Phones
How to lock the screen of Nokia E-63 using security code. Want want to lock the screen of My Nokia E-63 and want to know how to use the security lock for loacking the screen apart from using auto lock...
you just goto setting, than security, than keypad lock, & select security lock & open it.
Than you define a security code & use it.
OR
you just use third party software like keypad security lock & many more.
Jan 10, 2011 | Nokia E63 Cell Phone
The number illumination has gone out. How to fix?
My keypad won't light up when door is locked when you push lock won't light up green:
To make the keys light up when you want to enter your code, you have to push the lock button on the keypad first. If the keypad light never comes on, open the door and manually lock the interior lock, then press the keypad lock button. The above instructions should then work.
Jan 07, 2011 | Schlage BE365-PLY BE365PLY626 Satin...
My Nokia 6020 is 'locked' with 'Opening Folder'
Check out this link below to download a PDF manual, software, and more for your phone. Just copy and paste into your browser.
http://europe.nokia.com/get-support-and-software/product-support/nokia-6020
Keypad lock (keyguard) from page 29 in your manual:
To prevent the keys from being accidentally pressed, select Menu, and press *
within 3.5 seconds to lock the keypad.
To unlock the keypad, select Unlock, and press *.
To answer a call when the keyguard is on, press the call key. When you end or reject the call, the keypad automatically locks.
Security code from page 17 in your manual:
The security code (5 to 10 digits) helps to protect your phone against
unauthorized use. The preset code is 12345. To change the code and set the phone to request the code, see Security p. 80.
Hope this helps, let me know if I can help you with anything else. It would be very kind of you if this does work for you to please rate me or leave a short note. I would really appreciate it. Thank you for your time.
JimmyC
Oct 16, 2009 | Nokia Cell Phones
Jhdfn dfn
are you sure its not nh fg f fdhn ?
I think you need to fdh jdyfdhdfg to fix it
Aug 13, 2009 | Dell (UD295) 80 GB Hard Drive
How to lock the keypad with security code for sony ericsson?
I DONT WANT THE AUTOMATIC KEYPAD LOCK..BUT I WANT TO KNOW HOW TO MAKE KEYPAD SECURITY CODE SAME AS NOKIA..PLEASE HELP ME..
Dec 26, 2008 | Sony Ericsson S710a
My LG intellowasher DD WM1480 FDH washer displays DE (door open) and refuses to start, if I repeatedly open and close door sometimes it will start or the door will lock and it still doesnt start.
I have this problem too for my LG Intellowasher. I suspect it is because you're selecting "Rinse Hold" from the options. Try turning the power off and washing again on another setting to see if this resolves the issue.
May 03, 2008 | Washing Machines
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
