E2 error code on Hobart dishwasher
E0, E2, E3 & E4 - This appears if the machine isn't filling or filling high enough. When any of these codes display, the unit won't run. Check out our troubleshooting guide for possible causes.Jul. 17, 2019
The error code "OE" indicates a drain error. This error will display
if the washer is draining too slow or if it's not fully drained in
within 10 minutes. This would also explain why it's not spinning
properly. The drain pump filter will need to checked and cleaned
F1-E0 - EEPROM Communication Error - Disconnect power for at least 30 seconds and then reconnect. Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure. Select the 'cancel' function and wait 60 seconds. If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$$$$
