Since yesterday,,the 80 is reading the gps,,the boat,the antenna,,everything is a ok,,but he dosen't see the 120 that is blind,,no gps,,no antenna,,no boat
SOURCE: master vs. repeater confusion
The master/repeater selection is for the purpose of determining which display is in control of the waypoint and route database.
Turn on both units and let them boot up. Do not answer the master/repeater question until both are on. Then press "Set as master" on the preferred one.
The units remember individually if they were set as a master or repeater the last time they were on. If they are powering up to find themselves in a different configuration than they were previously in, that will prompt the whole master/repeater thing to happen.
SOURCE: loosing GPS signal on a E120, also have 2-E80's on
1. All your E Series MUST HAVE the same Software 5.23
2 You must set the Divice where the GPS Signal comes in as MASTER
all the other Repeater
3. Your GPS antena shoud be mounted outside
SOURCE: cut antenna wire raymarine 300waas gps
That unit uses a TNC connector. Just have someone install a new one on the end of the cable. IT's a little more difficult than a F connector for a TV but not rocket science. You can also send it in to Mid-Shore Electronics. Just google them and get their number. They have alot of experience with the older stuff.
