Question about HP cp1700 Color Inkjet Printer
May hp inkjet hang up in start and the scanner continuously moving..all the buttons not working and the light blinking..please help me..
  • 40 Answers
The scanner cannot find"home". Need to clean scanner mirror box.
Posted on Jul 27, 2009
  • duongthangdt Jul 27, 2009
    the scanner cannot find"home". Need to clean scanner mirror box.
The printert dos not respiond to any cartridge and dos blink at all /
Issue: All the lights blink In this error condition , the following blinking lights pattern displays on the control panel:
  • On/Resume light : Blinking
  • Check Paper light : Blinking
  • Check Print Cartridge light : Blinking
  • Black Start Copy light : Blinking
  • Color Start Copy light : Blinking
Figure 107: All the lights are blinking on the control panelc00864301.gif Solution one: Make sure that the front panel overlay is installed correctly If the front panel overlay, or bezel, is incorrectly installed, the product may indicate a false carriage stall error condition. If the product has not been set up before, follow these steps to ensure correct installation of the front panel overlay. If the front panel overlay is already installed, and your printer has been working for some time, do not attempt to reinstall the overlay. Press firmly on the overlay to ensure proper installation of the overlay adhesive or pins. NOTE: If you have already installed the front panel overlay, proceed to the next solution.
  1. Disconnect the power cord from the rear of the product.
    Please arte me Thanks Techbelkin
    TECHBELKIN ORIGINAL SOLUTION
  2. Locate the front panel overlay and peel off the paper backing to expose the adhesive as shown in the graphic below. Figure 108: Remove the paper backing from the front panel overlayc00005257.jpg
  3. Lift the scanner lid.
  4. Carefully line up and install the front panel overlay. Figure 109: Install the front panel overlayc00005258.jpg Figure 110: Correctly installed front panel overlayc00005259.jpg
  5. Reconnect the power cord to the rear of the product.
  6. Try the intended task again.
Solution two: Reset the All-in-One Follow these steps to perform a power reset. Step one: Perform a power reset
  1. Press the On/Resume button (c01602202.gif ) to turn on the product.
  2. With the product turned on , disconnect the power cord from the rear of the product.
  3. Unplug the power cord from the wall outlet.
  4. Wait at least 15 seconds.
  5. Plug the power cord back into the wall outlet.
  6. Reconnect the power cord to the rear of the product.
  7. If the product does not turn on automatically, press the On/Resume button (c01602202.gif ) to turn the product back on.
Step two: Print a self-test report Follow these steps to print a self-test report.
  1. Load plain, white paper into the paper tray.
  2. Press and hold the Cancel button (c02517757.gif ), and then press the Start Copy Color button. The product prints a self-test report.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , continue to the next solution.
Solution three: Service the All-in-One If you have completed all the steps and are still experiencing a problem, continue to the Service the All-in-One section at the end of this document. Service the All-in-One If you have completed all the preceding steps and are still experiencing a problem, service the product. Determine if your product is in warranty or out of warranty. If you need help determining your product's warranty status, go to HP's Warranty Check Tool .
  • If your product is in warranty , contact HP.
  • If your product is out of warranty , fees might apply for contacting HP.
Jan 08, 2011 | HP PSC 1315 All-In-One InkJet Printer
I have properly connected my HP Scanjet 2400 scanner with my system and the appropriate software was successfully installed, the light is blinking and when we try to scan, it tries to start, but it...
sometimes the power management causes the scanner to act up or fail altogether.
Try: Solution: Disable power management on the USB hubBy default, Window XP tries to disable USB port when the HP Scanjet scanner is not in use to save power. The scanner fails to wake up when called. To fix this problem use the steps below:
  1. Click Start , right-click My Computer , then click Properties . The System Properties window will open.
  2. Click the Hardware tab, then Device Manager . The Device Managerwindow will open.
  3. Double-click the Universal Serial Bus controller branch to expand it.
  4. Right-click USB Root Hub , then click Properties . The USB Root Hub Properties window will open.
  5. Click the Power Management tab.
  6. Remove the check from the Allow the computer to turn off this device to save powercheck box.
  7. Click OK , and close USB Root Hub Properties window.
  8. Close any other open windows.
Aug 28, 2010 | HP ScanJet 2400 Flatbed Scanner
Scanner not working
Kindly reinstall the printer driver cd. It will install the missing software like scanner.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 21, 2010 | HP PSC 1510 All-In-One InkJet Printer
COPY LIGHT BLINKING-PRESSED START BUTTON-WARMING UP.-NO PRINTING.
The news is not good. If the following document from HP support does not solve your problem you may have a faulty scanner bulb. Sorry!
HP PSC 950 Warming Up Error
Dec 28, 2009 | HP PSC 950 All-In-One InkJet Printer
Power and attenion keeps flashing says turn power off then on
Perform a partial reset of the HP All-in-One
  1. Turn on the HP All-in-One.
  2. Disconnect the power cord from the back of the unit.
  3. Press and hold the # and 3 buttons simultaneously.
  4. While still holding down the # and 3 buttons, connect the power cord to the back of the unit.
  5. Continue holding the buttons until the Power button blinks.
  6. Follow the instructions that display on the unit to select the language settings.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 30, 2009 | HP Officejet J5780 All-In-One InkJet...
Scanner Faliure
Fiend your solution direct from hp. Here is your solution...
http://www.hp.com/printer/prob676ijt65/solution
8011
Jan 16, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Scanner wont work The letter E is on. Lights are blinking
Un-hook it from the computer. Turn it off then on. See if it may be a code from the computer causing it.
Also, Check inside and make sure there isn't anything that is keeping the carriage from moving freely .
Also, Have you changed cartridges lately?
Reseat the cartridges.
Jan 08, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
Place align paper on scanner glass
1,Unplug the USB cable
2,Place the allignment paper in the right bottom corner of the scanner glass
3,close the lid
4,Press the Start scan button
You will find the light blinking wait until it completes.
Then connect the cable and the issue will be resolved.
Hope works well for you
Apr 29, 2008 | HP PSC 750 All-In-One InkJet Printer
Troubleshooting on hp printer/scanner/copier
This looks like either there is an paper jam or carriage jam on the unit,
Check the rare access door weather there is a paper jam.
Remove the cartridges and try moving the carriage( the cartridge hold) left to right and right to left and check if its moving freely.
After these try disconnecting the power cable without turning off the unit and hold the On button for 15 secs and then plug in the power cable while your hold the on button.
This should probably fix the issue.
Please do let me know if there is still an issue.
Feb 19, 2008 | HP PSC 1315 All-In-One InkJet Printer
Noise on my printer HP psc 2410
I have experienced this problem numerous times since owning theprinter, and usually a full reset (# and 9 on power-up) has resolvedit. Not this time, however! Following Guest's advice above, I visitedwww.fixyourownprinter.com and found the solution: cleaning the glass. Thank you, Guest!
Freddy
Nov 08, 2007 | HP PSC 2410 All-In-One InkJet Printer
HP cp1700 Color Inkjet Printer Logo
50 people viewed this question
Seeker5211
Seeker5211
