Splendid 2100 will not let us open the door to remove clothes
Splendid 2100 washer/dryer combination. Can't open door machine does not seem to respond to reset
broke handle trying to open door, refuses to unlock, lock light flashes really fast and never slows down.
  • ray2614 Jan 04, 2013
    Problem solved< someone brole in and stole the wash machine,Geuess the jokes on them
2 Suggested Answers
  • 3 Answers
SOURCE: Broken door handle on Splendid 2100 RV Washer/Dryer Combo
The Splendide distributor in OR sells handles for about $45.
Posted on Jan 28, 2009
Clicking noise in splendid dryer
We did not get a book. It washed the clothes BUT water still in washer. we don't no how to put it on to dry the clothes?
Mar 05, 2014 | Splendide 2100 Vented Washer-Dryer
Splendid 2000s washer dryer door won't lock
Possible that the door lock is jammed and needs to be replaced.
please check this link;
Replacing door lock
Jun 06, 2012 | Splendide Washing Machines
Door locked
THE CAPACITOR IS FAULTY that discharges so door can be opened safely it should be at the rear of mc inside attached to the side of mc make sure u get correct microfarfad replacement
Jan 13, 2010 | Splendide 2100 Vented Washer-Dryer
Splendide 2100 washer/dryer now fails to dry -
Remove the top - two screws in the back then slide forward
In the front right top you will see the air box and the terminals for the heater coil along with other wires and sensors. Start the washer on a dry cycle and check the voltage to the heater terminals. You will be looking for 120 AC. If voltage there but no heat the heating element is bad. If no voltage there follow the wires to the overheat switches and check the voltage on the other side of these switches (round devices with two terminals on top). If there is voltage there then the switch has tripped. Unplug the machine. Look for a spot of paint on this switch, scratch it away and you will see a small hole. Insert a strightened paper clip into this hole and push to reset the switch. Re-power and test the results.
No power to these switches probably means a bad circuit board $$$.
Sep 19, 2009 | Splendide 2100 Vented Washer-Dryer
Doesn't completely dry clothing
Make sure lint filter is clean and vent pipe and outlet are not clogged.  If the clothes are getting warm then the element is working.
May 30, 2009 | Splendide 2100 Vented Washer-Dryer
Wet clothes in splendide 2000 S door won't open
drive motor or belt came off or broke take off top
Mar 23, 2009 | Splendide 2000S Vented Washer/Dryer
Jan 27, 2009 | Splendide 2100 Vented Washer-Dryer
I have a Splendide 2000 s vented washer and dryer. I started a load and there was water leaking all over my floor from the washer, so I immediately turned it off. Now I'm trying to get those clothes out...
Unplug it. Door latch has thermal delay. Unplug, let cool 3 minutes, open door.
After door is open, you can kill the delay: with door open remove rubber boot to access gap between door & drum, remove door catch from cabinet, glue, break or unwire delay parts & replace all. Do this with safety glasses, the spring holding rubber boot can be a bit jumpy.
Your leak I know nothing of.
Jan 26, 2009 | Splendide 2100 Vented Washer-Dryer
Splendide 2100 no longer dries clothes
We had the same problem with our splendide 2100 top loader. If you remove the top cover, you will find 2 circular like black discs (the size of a dime) on the right hand side about 6 inches from the front. You need to push those down (with a very small blunt object) to reset them. Please make sure that you unplug your washer/dryer before you attempt this. Good luck.
Aug 24, 2008 | Splendide 2100 Vented Washer-Dryer
Broken Handle
Contact this person and his company. They have the handle kit for the WD-2100
Darrell Klein National Service Director
Westland Sales /
Splendide Combination Washer Dryers
15650 SE 102nd Ave.
Clackamas, OR 97015
503-210-3914
darrell.klein@westlandsales.com
Jun 30, 2008 | Splendide 2100 Vented Washer-Dryer
Washing Machines Logo
75 people viewed this question
Top Washing Machines Experts
