s
sadegh parsi Posted on Jul 22, 2017
My s8 setting is defect how can return to previous setting
My brand new Orbit 3 outlet digital water timer did not shut off and the well ran for 3 hours and now i don't have any water. How do I fix and why did this happen?
it may be defective, return to store for a new one
water won't turn off. check if:
watering duration is set to desired time.
start times begin after previous
watering cycle has run
through all stations and set duration's. https://www.orbitonline.com/site_files/manuals/27922-24_rI_web.pdf
Nokia model c5 c6
Internet: manual configuration
Nokia C5
*Menu
·Settings.
·Choose Connectivity.
·Choose Destinations.
·Choose Internet.
·Choose Options,and then New access point.
·Choose No
·Choose Packet data.
·Enter Proximus Internet, and choose OK.
·If Proximus Internet has Priority 1, skip the next step.
·If not, go to the next step.
Previous
·Choose Proximus Internet for a second, until a popup window is displayed.
·Choose Change priority, and choose the highest position.
Previous
·Choose Proximus Internet.
·Choose Connection name, enter Proximus Internet, and choose OK.
·Choose Access point name, enterinternet.proximus.be, and choose OK.
·Choose User name, enter nothing, and choose OK.
·Under Prompt password, choose No.
Previous
Next
·Choose Password, enter nothing, and choose OK.
·Under Authentication, choose Normal.
·Choose Homepage, enter http://m.skynet.be, and choose OK.
·Under Use access point, choose Automatically.
·Return to the Main menu.
Previous
·Choose Web.
·Choose Options, and then Settings.
·Choose General.
·Choose Access point.
·Choose Internet, Options, and then Select access
·Choose Homepage, and then User defined.
Previous
Next
Step 22 of 24
·Enter http://m.skynet.be, and choose OK.
·Return to the Start screen.
Previous
·Start screen.
·Switch off the C5-03 and restart it in order to activate the settings.
·You can now start using the internet.
Previous
My list of emails has changed I want the former format please
If you are using Internet Explorer: click tools at the top, then internet options, then security. Click "Custom Level" button, go to the scripting section and disable active scripting. Then Log in to your yahoo mail. Select "Return to a previous version of Yahoo! Mail" Once done you can return to the previous settings. Log out and login again.
If you are using Firefox go to tools > options > content. Click on disable Javascript. Then Log in to your yahoo mail. Select "Return to a previous version of Yahoo! Mail" Once done turn it back on. Log out and login again.
Aug 13, 2011 • Yahoo Mail
2helpful
2answers
On start up it blue screens. HD check gvies Return Code 7
The hard disk is dead. To recover some of your files from it just boot from a Linux Live-CD like   http:pclinuxos.com/  and copy whatever you can recover to a USB memory stick.
1helpful
No steam on Capresso Impressa S8
Most likely problem is over temp cut out switch. Small diode attached to the boiler to prevent damage during boil dry, or fault in the heating element itself. Difficult machines to repair and best handled by a service technician.
CARD LOCKED ON PANASONIC NV-GS40
I have exactly the same problem - but very occasionally, it returns to normal, I can take a few pictures then up comes the message 'CARD LOCKED' . I change for different cards and the problem is always the same. Nobody seems to have a solution and Panasonic do not answer any questions about their defective products. I am very disappointed having bought this camera. All my previous cameras were Sony with no problems whatsoever experienced.
k24674
ADMIN Andrew
ADMIN Andrew
