Question about GE Washing Machines
The mechine doesn't drain - GE Washing Machines
  • 30 Answers
KINKED WATER HOSE OUTLET OR PUMP IS BLOCKED
Posted on Jul 29, 2009
I want to know how can i cleare the erro f21 about siemens washing mechine.
Error f21 happens when the machine does not drain in an appropriate time. This can be caused by a blockage in the drain or a faulty pump. There is a previous post in relation to resetting this error. have siemens washing machine that says f21 what does that mean
Jan 14, 2017 | Siemens Washing Machines
Where is filter to drain pipe please
I think its up inside the flutted black hose going from mechine to pump
Feb 28, 2015 | Hotpoint Ultima WF865 Front Load Washer
Samsung wt8202
Were did i get the front pannel in blue colour because my washing mechine wt 8202 drain knob is not working .Technician says change the front pannel board white colour is awailable but blue is not get yet.
Apr 05, 2012 | Samsung Washing Machines
The trigger on the spraygun for my Magnum SR7 sprayer is slack - doesn't operate at all and won't release any fluid from the nozzle.
This is a contractors gun its a vary good gun worth about 200 hunderd dollars . The problem is eigther the spring that returns the trigger _neddle valve to seat pisition is eighter stuck or broken. But if you are haveing this kind of problem it means the gun was not cleaned correctly . Im a perfinial spray painter and if the gun isn;t clean then the mechine wasn;t cleaned as well it goes hand in hand . So what kind of mechine are trying to opperate its an airless acording to the picture and that makes sence . You may be able to clean the gun or get a kit to rebuild it its about a hunderd dollars but the mechine most likely needs to be cleaner at best if no completely rebuild and repacked . If the seals in the pump can put out pressure and the trigger on the gun is slack then you shouldn't be able to shut the paint off because the trigger would be open at this point
Jul 10, 2011 | GRACO INC 255109 SGPRO Paint Spray Gun
Washing mechine disorder
You have posted washing machine in printer forum and that is a disorder.
have your machine power, prgram controller and outputs to the motor drains, sensors checked, it will get you machine in order.
Sep 28, 2010 | Samsung CLX 3160fn All-In-One Printer
Hi i have a whirlpool duet sport front load wash mechine that give me a code (Sd) it locks the mechine door it dosn't ring the clothes dry when this happens i would have to reset the circuit breaker for it...
"F21" (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Aug 21, 2010 | Whirlpool 8572546 Duet Sport Stacking Kit
MECHINE MAKES HUMMING SOUND, IT WON'T SPIN, WON'T
THe motor coupling or belt is likely failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 08, 2009 | Kenmore Washing Machines
Drain pump for Kenmore Elite top loading washing mechine
This will not be in the owner's manual.
If you search inside the cavity of your washer, however, you will find the service manual taped to the wall in a plastic bag.
Aug 07, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
