SOURCE: Thetford fridge type C11[fitted to caravan]model N80 PL R
This Caravan is a recreational vehicle? If you have an ammonia absorption refrigerator in the unit, and you smell ammonia, your fridge is leaking. This can be a health hazard. Park the unit and get the fridge serviced, they are repairable by independant service personnel. There are only 2 in Ontario Canada. If you go to an RV shop, the will only want to sell you a new fridge.
Good luck, try a search in your area for ammonia absorption refrigerator repair in your area.
Peter.
SOURCE: 2000 dodge grand caravan rear heater core tubes need replacing
a lot of pain and heart ache. even on a rack they are a pain . check with your dealer there wae a recall on them for failing its worth the phone call to see kdc744
SOURCE: Cleaning drip tray.
I have just removed the drip tray from my fridge freezer and it was relatively easy.
Do not remove the compressor unit.
The drip tray is held in place by a metal clasp which is welded to the top of the compressor. The clasp is a flat piece of metal which must physically twisted to align with the key way in the plastic drip tray. I used thin pair of pliers to grip the clasp and twist it clockwise to line up with the tray key way. The tray then has to be carefully manouvred off the compressor so as not to cause damage or spill it foul smelling contents. This I managed to achieve fairly easily.
Clean out and install then twist the clasp to clamp the tray into position. I don't know what would happen if you didnt lock the tray back in position as it does not seem capable of falling off on its own and it would be easier to remove next time.
Hope this makes sense
Mark
SOURCE: ice build up
I had the same problem but fixed it recently. The problem originates with the drain trough mounted on the back interior wall of the fridge that slopes down into the middle. The drain tube is attached at this point and runs to the pan under the unit. This drain trough is screwed to the interior and sealed with silicone caulking. Over time the caulking breaks free from the interior wall of the fridge allowing the defrosted water to leak past the trough, collecting in the bottom of the compartment under the veggie drawer. It freezes there building up an ice ***** that eventuallly wraps around the drain tube. Any water that now runs into the tube freezes in place over time forming an ice plug preventing any drainage at all. Now the defrosted water begins to flood the interior of the fridge eventually leaking out which it did in our situtation.
There are two solutions. One is to take off the drain trough, clean it up and the interior wall of the fridge. Also thaw out the ice plug in the drain tube and make sure it is clean and drains freely. I used hot water and a syringe to inject it into the tube until the ice melted. Dry everything off. Reattach the drain trough using silicone caulking approved for kitchen/bath use. You may have to shut down the fridge and warm it up to meet the application temperature limit of the silicpne. The other solution is simpler. After cleaning and drying the drain trough, I applied an adhesive backed closed cell foam rubber gasket (3/16" thick automotive) to the back surface of the trough that sits against the interior wall of the fridge when in place. When screwed back in place, the gasket is compressed preventing water from leaking past. The fridge does not have to be warmed up for this fix. It has been in place for a few months now with now problems.
SOURCE: thetford caravan fridge freezes all food in fridge
Thats a Norcold compact fridge. The most likley problem would be the thermister. Need to do an ohms reading. From inside of the fridge remone the thermister from the fins and unplug the wires. With a VOM set it on Ohms, touch the wires with the probes/ does not matter which probe to wire/ hold the bulb end of the thermister between your fingers, your reading should stat at about 7000 Ohms. Stick the bulb end of the thermister in a glass of ice water, reading should start climbing and go to about 22000 Ohms. If this happens the thermister is good and you need to look elsewhere. If it does not test out you need to replace the thermister. The thermister is a thermostat that controls the heat source that makes the fridge cool. If the thermister reads good you may want to get the circuit board tested.
Hope this helps
Thank you for using Fixya
Jerry
