Question about Dell V305w All-In-One R840635AU InkJet Printer
Dellv305 printer scanner copy
I bought this 4 months ago and i am very disapointed in it paper does load i have to put one sheet at a time i have to keep working with it to get it to work i have to unplug it plug it back in i have thrown all of my paperwork away is there anything i can do it is the worst printer i have ever seen
    Scholar:
  • 40 Answers
Hi : mommagreen19 ,
one common problem faced (not by all )...with this printer model is  not able to feed the paper thro .
if u have sure the paper has been fed properly as instructed in the manual ., then , open the front cover of the p[rinter ., u should see the cartridges .,
r the cartridges located in the centre ?
if yes : then the machine is ffine .,
if no : its carrier jam .,
for  carrier jam : simply oull the carts to the centre and restart the printer .
again ., if u think that the printer keeps giving to probs ., call dell @ 18006249896 and check if it still in warranty ., and if so get a replacement .
hav a gooday !
Posted on Jul 27, 2009
Printer is saying manual feed insert paper. Will not print
To load paper or other media in the Manual Feed Slot (directly above the Paper Tray)
You can load envelopes and special print media one at a time into this slot. Use the manual feed slot to print or copy on labels, envelopes or thicker paper.
1. Slide the paper guides to fit the paper size.
2. Using both hands put one sheet of paper in the manual feed slot until you feel the front edge of the paper touch the paper feed roller. Let go of the paper when you feel the machine feed the paper in a short distance.
Note: When you put paper in the manual feed slot, please remember the following:
■ The side to be printed on must be face up.
■ Put the leading edge (top of the paper) in first and push it gently into the slot.
■ Make sure that the paper is straight and in the proper position on the manual feed slot. If it is not, the paper may not be fed properly, resulting in a skewed printout or a paper jam.
■ Do not put more than one sheet or envelope in the manual feed slot at a time or you may cause the machine to jam.
■ You can remove smaller sizes of printed paper from the output paper tray more easily if you lift the scanner cover using both hands as shown in the illustration.
You can still use the machine when the scanner cover is raised. You can return the scanner cover to its home position by pushing it down with both hands.
If you would like to disable Manual Feed Mode, check that the manual feed mode is not selected in the printer driver.
Here is a copy of the User's Manual for the Brother MFC-7820N.
Jul 07, 2010 | Brother MFC-7820N Laser Printer
Epson stylus DX3800 All in one printer, scanner Unable to print
Open the printer cover and look closely for tiny paper shreds that might got stuck between the rollers. If you have a canned air, try blowing out the paper path as those tiny piece of paper might be blocking the paper sensor.
Sep 20, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Printer says paper jam, now scanner wont work
you will need to open it to remove this piece of paper.
Aug 14, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Paper use
Unfortunately this is a common problem but one thing you can try might help.
I'd recommend learning how to fan-apart your paper before you load it as this puts air in between the sheets and creates less friction so it's easier for the printer pickup wheel to grab just one sheet of paper.
There's a quick video help guide I put together here
The other approaches to try are:
  • try a few other brands of paper to see if they are more compatible
  • adjust the paper guides so they don't hold the paper too tight or loose.
Hope that helps solve your problem
Mar 20, 2009 | HP Office Equipment & Supplies
Can't Print on Card
I had the same problem with my 3 year old HP Officejet 5610. Feeding heavy paper or white card stock would result in a paper jam. The card stock would start to feed, but then stop half way. The pinch rollers seemed to spin without advancing the paper, even if the paper was fed one sheet at a time.
Solution: Clean the rubber pinch rollers with isopropyl rubbing alcohol. Partial disassembly/reassembly required.
To access the rollers, remove the scanner plate:
1. Disconnect power, USB, and phone cables.
2. Open up the scanner sheet feeder by tilting it left.
3. Unlatch the scanner scanner feeder so that it opens completely vertical. Latch is on front hinge only.
4. Remove the 4 corner hex screws on the scanner plate. Remove the 2 hex screws on the sheet feeder. (I used a small flat blade screw driver in the hex heads)
4. Lift the plate and sheet feeder away from printer box. Disconnect the 2 flat cable wires from the circuit board.
5. Scrub rubber pinch rollers with alcohol on a swab. Dry thoughly.
6. Reassemble. (NOTE: This is a good time to clean the underside of the glass plate and the scanner head)
Oct 18, 2007 | HP Officejet 5610 All-In-One InkJet...
Pohot paper jamming in Brother DCP-115C printer
This is a common error of this printertype. Please use only paper of max. 220g. There is no problem reported with that.
Jan 14, 2007 | Brother DCP-110C All-In-One InkJet Printer
Dell V305w All-In-One R840635AU InkJet Printer Logo
181 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
