Question about Creative Labs Inspire 4400 Computer Speakers
I lost the adapter so i need to noe what is the
I lost the adapter so i need to noe what is the Amper?
    President:
  • 627 Answers
The ampere is the SI unit of electric current. The ampere, in practice often shortened to amp, is an SI base unit, and is named after André-Marie Ampère, one of the main discoverers of electromagnetism.
In practical terms, the ampere is a measure of the amount of electric charge passing a point per unit time.
Posted on Jul 27, 2009
ANDROID TABLET
Not really, you can damage the power supply from android tablet,to due the amper draw for the adapter
Use the same charger for the same manufacurer.
God bless you
Jul 29, 2013 | Computers & Internet
I lost my 12 V 3A DC adapter for my LG Flatron E2360V-PN What kind is compatible
have you been tried to find at the shopjimmy.com or at the amazon.com?. you can replaced it with other adapter even not LG, the only need to considered is the same voltage and amper rating as will as the size of the output jack and polarity of the adapter you will replaced. which will fit and same polarity to your monitor .
Dec 11, 2012 | Computers & Internet
The AC power indicator light does not torn on when the adapter is plugged. The adapter was tested and it puts out 19 volts. At first the prolem was intermittant, but now it is not working. The battery...
The AC adapter have two measure:
Output volt: 19 volts
Amp:
the Volt output can be tested and show 19V, but can`t leave the correct Amper.
I see these failure in anothers AC adapter. I measure the Volt and show 12 V, but don`t work the survellaince camera. I recommedn replace the adapter
Sep 14, 2011 | Computers & Internet
Pavilion DV3 not working on a car charger That is working flawlessly on other hp nc6400 laptop they both work great on the 220v standard adapter! Why isnt my laptop charging?? Please help
the 220 v power of cities has 25 Amper
has your inverter 25 A . of course not
so this is right that tow power sources have 220 VOLTS but the important matter for working
a device by power source is the out put AMPER plus output Voltage.
good luck
gorbesia
Jun 29, 2011 | Inverter 175 Watt Power Car Adapter for...
My compaq 6730s is not powering rather, the charging light will blink amper four times
Possible that the charging is bad , check the adapter voltage and the battery voltage. If this is below the threshold level then the PC will not boot up. If the voltages are good , then the memory orr the main board can be a suspect.
Jun 29, 2011 | HP Compaq 6735s Notebook
Lost power, now fridge won't work.
check all the fuses maybe blown up due to high amper of sudden power resume.
Aug 15, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Where can I buy a new adapter to plug it into the wall?
hellow dear
your product adaptr is normally
  • 9V, 2.2A
  • you can buy from ebay or online shoping
  • if you cant do this try to buy 9v adapter from your nearest market and check amper it is higher then 2.2 amper that should work fine not more then 3.5 amper
  • Aug 10, 2009 | Disney D7000PD Portable DVD Player
    No power on Edimax br-6104k router
    First, try to check if AC/DC adapter is O.K. (should not be under 12V). If you don't have such instrument, try to power any other device that need 12V (even small car lamp).
    If you don't have power on it, than try to find another adapter, but with same voltage, and same or higher strenght (Amper), otherwise, something is broken in your router and you can't repair it by yourself.
    Dec 09, 2008 | Edimax BR-6104K Router (br6104k)
    Ethernet
    I have an Armada E500 and its a Intel(R) PRO/100+ MiniPCI Ethernet Adapter.
    Hope this helps..please rate me!
    May 03, 2008 | Compaq (198721-001) Modem
    Creative Labs Inspire 4400 Computer Speakers Logo
    321 people viewed this question
    Top Creative Labs Audio Players & Recorders Experts
    Carlos L. Burgos
    Carlos L. Burgos
    Mohamed Ismail
    Mohamed Ismail
    Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
