Question about Grilling
What are the bad effects of smoking?
How smoking is making harm to our health and how can a smoker give up it?
  • 7,054 Answers
***** is a good one. just quit.
Posted on Jul 21, 2017
3 Suggested Answers
  • 4 Answers
SOURCE: smoker will not reach heat of 250 to 300 to effectively smoke meat
I have heard that the "new" propane tanks have a saftey valve that closes if they are opened too quickly, try opening the valve very slowly. When you say it has been cleaned that means you have checked the venturi and the burner for spiders?
Posted on Jun 08, 2009
richard_m44507
  • 101 Answers
SOURCE: Why smoking is injurius to health and in which of our body smoke is effect
Cigarettes have multiple dangerous toxins that you ingest when smoking, the tar builds up coatings on your lungs that damage cells, they cannot repair the damage and become leather like and fatty making it harder for your body to process oxygen, cigarettes contain multiple poisons including cyanide that also damage cell structures, but the worst thing is it damages the heart and ventricles, narrowing arteries restricting blood flow. Cigarette smoking is also directly linked to numerous aggressive cancers that thrive due to damaged cell structures. I am a lifelong smoker and cant stop, I wished I had never started, so if you have a choice dont smoke.
Posted on Aug 01, 2014
Are E-Cigs Really Healthier than Cigarettes?
Yes, they are far healthier than traditional cigarettes. E-cigarettes contain no cancer causing carcinogens and far less harmful constituents than that of regular cigarette smoke and tar. Secondly, using e-cigarettes eliminates secondhand smoke and is better for the environment and the people around you, in general.
http://eliquiddepot.com
Jul 21, 2017 | Health & Beauty
Why is plastic bad for the environment?
Some of the harmful effects of plastics on our environment are :
1. Soil pollution-Plastic is a nonbiodegradable waste, it cannot be decomposed by the microorganisms present in the soil and hence cause soil pollution.
2. Air pollution- Burning of plastic materials releases many toxic and dangerous gasses like carbon monoxide, and cause extreme air pollution.
3. Dangerous for water organisms- Disposing plastics on water bodies can harm water living organisms. Also, they cover up the surface of the water and not allow sunlight and oxygen to enter on water which can cause ***** of many water organisms.
4. Water pollution- Plastic also cause water pollution as plastic materials cannot be decomposed by the microorganisms present in water.
Jan 04, 2017 | Green Living
WHAT'S THE DIFFERENCE BETWEEN ELECTRONIC CIGARETTES AND TRADITIONAL TOBACCO CIGARETTES?
The most common difference between e-cigarette and traditional cigarette is that e-cigarette do not contain tobacco. Tobacco is the main ingredient in a cigarette, which cause Cancer. Traditional cigarette contains lots of harmful chemicals.
The body's reaction to many of the chemicals in traditional cigarette smoke causes long-lasting inflammation, which in turn leads to chronic diseases like bronchitis, emphysema, and heart disease.
E cigarettes are completely different. They use liquefied nicotine and produce less-harmful water vapor instead of harmful smoke.
E cigarette comes with various flavors. It contains e-liquid, which adds flavor to it. You can refer Shake N vape for more details.
Nov 24, 2015 | Computers & Internet
My 1998 Lincoln Continental Will crank up but didn't run smooth. She goes dead. I it is a vacuum our air hose. Others say it's a 2.0 sensor. Can u help me define the problem?
Lots of possible problems can cause a rough idle. Vacuum hose is particularly common. Shops want to charge an exorbitant amount to do a smoke leak test too which makes most people leave it and deal with a rough idle. I'll address that in a moment. Check to make sure everything is connected...no extra hoses or no extra ports that look like they should have hoses. Make sure you have a good air filter and that the breather filter isn't clogged (if you're breather uses the intake filter and lots of newer cars do, make sure the hose that goes from your filter box to the valve cover isn't hard, cracked, or disconnected). May be worth replacing the PCV valve (they're usually fairly cheap and easy to swap). Once you've eliminated that...
DISCLAIMER: I do NOT in any way advocate smoking of any kind. If you are a non-smoker find a friend that smokes for this if you decide to attempt it. DON'T START SMOKING JUST TO DO A SMOKE LEAK TEST. No car is worth the prolonged health damage. As a former smoker I can tell you quitting is a nightmare and its just not worth it. ALSO I am not responsible if this somehow damages your car. I've done it a fist full of times and found my own vacuum leaks every time with this method but that doesn't mean your car will be as happy about it as mine turned out to be. Keep the cigar away from under the hood at all times! Its common sense here people, there's fuel hiding in a few places that will readily ignite and give you a very bad day. I AM NOT RESPONSIBLE!
BUT:... if you can find a smoker, buy them a cigar. Non-flavored cigar is preferable as there are less tars to deal with. Disconnect a vacuum hose that has a bit of length to it that runs into the intake manifold. Have your resident smoker take a good heavy pull from the cigar and blow the smoke into the vacuum line. Look for smoke trickling out from any of the other vacuum hose connections. If you find smoke at all, you've found your vacuum leak. No smoke, do it again. Do it a few times. Its a quick and dirty smoke test that has worked for me every time.
Failing all of that, I'd start looking at sensors. Vacuum lines are fairly cheap...check the cheap first.
Hope this helps someone in some way! Best of luck!
Apr 13, 2015 | 1998 Lincoln Continental
Why smoking is injurius to health and in which of our body smoke is effect.
Aug 01, 2014 | Health & Beauty
Toxic fume
I think it is similar to smoking cigarette.
Jul 02, 2014 | drugs.com Computers & Internet
Should smoking be banned in the paciifc islands?
Smoking should be banned everywhere, I think. It causes too many health problems.
But smokers could be allowed to smoke in the special rooms/places for them. Those would be closed places (Only for smokers and in a building, not outside).
May 01, 2013 | Computers & Internet
Can smoking cause dental diseases?
Smoking and chewing tobacco are both strongly linked with multiple dental diseases and should be avoided in order to maintain a good oral health.
Feb 03, 2013 | Health & Beauty
Grilling Logo
180 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
