Question about OKI MICROLINE 520 Matrix Printer
Oki 520/521 logic boards
Alarm light flashing,utility and prop light stays on.
  • tuka shivekar Dec 14, 2007
    not moving the carriage assembly and alarm led is blinking
  • 40 Answers
Check if the Pico fuse is blown ? next to the heat sink on the transisitor array with the number 2025.if the fuse is gone than the fuse plus the 2025 transistor must be replaced.
Posted on Dec 31, 2007
Printer Throws Alarm, HSD, Prop error and Head Problems
Most likely, you need to lubricate the shaft the head moves on and clean the positioning tape (carefully, the marks on it can be dissolved).
Unplug the printer while it's moving the head, so you can manually move the head around. Use light oil, such as used in sewing machines.
Oct 17, 2014 | OKI MICROLINE 321 Turbo Matrix Printer
Printer prints one line, then alarm light comes on and stops printing.
Sir the printer is giving line because the cartiage or toner is not of good quality so it does not melt properly and produces line while the alarm comes and stop printing is due to the problem in charging cathode or gutter
Jun 03, 2013 | OKI MICROLINE 321 Turbo Matrix Printer
Alarm flashing goes to prop
This is a "spacing alarm". check that the printhead moves freely from left to right. If not, remove the ribbon and try it again. If it is moving freely then it should be ok, if not it will need most likely the space motor or the main board replaced. In some cases it is also possibly the white carriage cable that runs from your main board to the space motor. Hope this helps.
Feb 22, 2011 | OKI MICROLINE 321 Turbo Matrix Printer
Remove the ribbon it may be jammed and if this does not work your printer has a problem with either main logic board or carriage motor.
Aug 14, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
TV does not turn on/red led flashes 7 times in front
this is common issue with this model and through your troubleshooting is tied to y main board. blinking led on logic main in normal operation. when replacing y main always good idea to replace y upper and lowe buffer boards as they complete a circuit and sometimes replacing one without other could cause additional failure on remaining boards
Aug 10, 2008 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
Is the front cover on the printer(ifs its not the alarm light will keep flashing as there is a sensor that will trigger the alarm if the cover is not on or not on properly.Hope this helps?
Jul 16, 2008 | OKI MICROLINE ML-395 Matrix Printer
Printer won't print labels
What driver are you using ? the default driver should be IBM Proprinter.
Hope this helps
Jan 24, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Oki 520/521
Cover on these are often broken causing the two little switch's to not close on left and right of lid
Nov 22, 2007 | OKI MICROLINE 520 Matrix Printer
OKI MICROLINE 520 Matrix Printer Logo
813 people viewed this question
Top OKI Office Equipment & Supplies Experts
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
