Question about Hardware & Accessories
EDAPT timer cannot set
Can set current time but cannot set to turn heater on and off twice a day. Instructions complicated. Don't know where from as it's my mums'.
Any ideas appreciated.
SOURCE: Grasslin Digital wall mounted timer programme setting instructions please
pdf file link, instructions will say it is for a topica500 also known as a logica 500.
Hope this helps.RoyG
Posted on Mar 09, 2009
  • 760 Answers
SOURCE: Wiring of Intermatic T8845pv
I believe the number you gave is fir the 14 day timer. Here is a link to the manual for it. Notice the not to use only one silver pin.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t8845pv%20-%20english.ashx
Posted on Aug 10, 2010
jyackle5
  • 8197 Answers
SOURCE: I have a Malibu 8100-9045-01
Go to the link below to see how to set. Click on the 5th one down to set time and day.
http://www.malibulights.com/customer_service/knowledge_base/transformers_faq.aspx
Good Luck
Posted on Sep 06, 2010
SOURCE: i need to know how to set my timer, I've had it
Open following link to identify timer for sure.
http://waterheatertimer.org/Woods-timers-and-manuals.html#Brinks
Several companies sell a similar timer, and there is a manual for Westek version.
http://waterheatertimer.org/pdf/Westek-TE05WHBL-manual.pdf
Add a comment if this manual is correct for the Timex also.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Feb 01, 2011
SOURCE: Instructions to set Woods indoor timer 59377
Open following link to identify timer and download manual
http://waterheatertimer.org/Woods-timers-and-manuals.html#59377
To set current time, press and hold clock button while pushing hour and minute buttons.
Then release clock button
Posted on Feb 12, 2011
I have the UPM ETW 350 user manual. It is easy to follow up to and incl. setting on time BUT setting off time is a mystery. Is there a 1-800 nu. I can call to be waled thru?
http://waterheatertimer.org/UPM-timers-and-manuals.html
This line of timers has mostly disappeared from market... I do not know who is offering tech support for the product.
If you purchased the timer recently, it may be previously used or non-functioning.
The manual is complicated and incomplete ... probably because they have built-in or intuitive steps that display when you program the timer... or they assume you want to fiddle around with their product.
It appears the timer must be wired correctly prior to programming.
http://waterheatertimer.org/How-to-wire-timers.html
- you set the current time first... you toggle through menu choices using arrow keys... go to clock...press set.. toggle to find current day (today) and then press set button... then do the same for hour and minute... pressing set button to confirm each selection.
- to program... you toggle through menu choices using arrow keys... when 1 ON appears on display... press set... select day or days for program 1 on using arrow keys... press set... select hour and minute... and press set after each to confirm selection.
These steps confirm setting for program 1 ON ...the day hour and minute that program 1 turns ON
Each ON program requires OFF program..
Probably the timer automatically displays program 1 OFF as soon as program 1 ON is set... then you follow same steps to select day, hour and minute for program 1 off.
Repeat steps to set up to 20 programs.
Do not touch buttons for period of time, and the timer probably displays current time and is ready to go, but manual is unclear about setting the mode..
http://waterheatertimer.org/How-to-troubleshoot-timers.html#in-wall
Gene
Water Heater Timers Save Money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 06, 2015 | UPM Hardware & Accessories
Can I put my central heating on a different time from my water horstmann didam 425
It appears there are 4 trippers on the daily time dial that control all timing. 2 On and 2 OFF
On the right side are override switches for Hot water and Heating
You can only separate Hot water and Heater programming a little bit.
You can choose to have Hot water ON all day, or turn on-off once per day or turn on-off twice a day. Or OFF all day.
The Heater has the same options and the same on-off times as the Hot water.
Manual:
http://www.horstmann.co.uk/files/2513/9867/2118/user_guide_425-TiaraDiadem1.pdf
For fully separate programming, where Hot water and Heater can each be programmed differently, you would need a 2-channel controller like the Grasslin QE2
http://www.grasslin-controls.co.uk/towerchronqe2.html
http://waterheatertimer.org/pdf/Grasslin-QE1-QE2_GB-instructions.pdf
Gene
Oct 11, 2014 | Water Heaters
I need instructions of Melnor 304F timer for watering
From the Melnor 304f actual instructions:
Use 9V alkaline batter only! Flashing lighs indicate that the battery is low and needs to be replaced.
1) To start: Turn Dial to Off position and press ENTER
2) Set Time: set the current time and press ENTER
3) Start Time: set the time to start the first irrigation cycle and press ENTER.
4) Frequency: Set the frequency of the irrigation cycle e.g. twice a day = 12h and press entere.
5) Duration: Set the duration of the first irrigation cycle and press ENTER.
-- to change the duration
Turn the dial to the new duration and press ENTER
--to turn the water on manually
Turn dial to ON position.. The water will turn off automatically after 30 minutes.
-- to turn the water OFF
Turn the dial to the OFF position
Do NOT press ENTER when dial is in OFF position, otherwise the unit will clear the program, and you have to Reprogram the unit following the steps 2 through 5.
Jun 29, 2014 | Flotec Garden
My Kenmore side by side is fine, except for freezing everything in the crisper drawers.
The coldest place in your fridge is in the crisper drawers, manufactures know this and they even put heaters under the floor of your fridge to try to heat it up a bit in there, if you set your freezer temperture to low there will be less cold air current that flows into your fridge but it will flow in over a longer period of time, that air is about -22C so it will be blowing on your items in your crisper for a long time and it will probably freeze them, all very confusing and complicated but it may help to turn your controles for your freezer to a warmer setting, on the other hand if you only open your fridge a few times a day the cold air being denser will settle in the bottom of the fridge and freeze the crisper area, not much you can do about this, except eat more food... :-)
Aug 26, 2011 | Kenmore Side by Side Refrigerator
Have just bought an Elonex ebook colour 705EB and been trying to reset date and time as they are wrong... done as said on Manual go into Settings choose Time and Date setting... change the date and time...
Hope you read this message. I just noticed your message today on this site.
I bought an Elonex 705EB for my mum and had the same problem. It's not pressing the select key that changes the time. You must correct the time then press Menu button on yes (I had to press twice in row before it worked). I don't know why it works different from the manual. I found this out through a lot of trial and error!
Jul 26, 2011 | Computers & Internet
We bought two heaters right before Christmas and have returned both of them for replacements and the problem continues. The heater burns great for about three weeks then the wick starts to burn low and...
What you described, usually occurs when the heater runs out of kerosene or the wick is not turned up gradually, as it burns away from normal usage.
If what you described had only happened once, I would say, the wick may have been originally installed improperly by the manufacturer. But, for it to happen twice in such a short period of time, discounts that idea.
Back, before we went exclusively the selling gas heaters, gas fireplaces, gas logs, etc. We stocked, sold & serviced these heaters. They were very reliable and had only minimal problems with them. In those few cases that we did, the majority were caused by operator error ( they didn't read & follow the Owners Manual instructions) and were easily solved.
The only other thing that "may" be causing your problem is contaminated kerosene. In which case, buy your kerosene form a different supplier. And properly dispose of what you currently have.
Hope this helps solve your problem.
Mar 02, 2011 | Dyna-Glo Heating & Cooling
Lost directions to set timer Melnor 604 F
Melnor 604F Instructions (from Label on unit)All indicator light flashing - replace 9V battery inside unit
1. To Start - turn dial to Off and press Enter.
2. Set Time - set current time and press Enter (Yellow ring).
3. Set Start Time - Set time to start first irrigation cycle (Yellow ring) and press Enter.
4. Frequency - Set frequency of irrigation cycle; e.g., twice a day set 12 h. (red sector ring) and press Enter
5. Duration - Set duration of cycle (Green band) minutes and press Enter.
To change duration - turn dial to new duration and press enter.
To turn water on manually - Turn dial to ON position, water will turn off in 30 min.
Do not press enter in the OFF position as the unit will clear program. You will have to reprogram unit
via steps 2-5 above.
Jan 31, 2010 | GARDENA Melnor/Gardena 101 Flowmeter Water...
We have a timer on our tankless hot water heater-how do I set it to reflect the current time? It is a large dial with tiny pins to pull/push backward. I understand the on off function of the pins but need...
very simple you push the middle and turn to set it to the timing you want current timing. the best times to set a recirculating pump in a water heater is 20 to 30 min before you take a shower in the mornings 15 min is adeal and dont leave the timer on for more than 15 min which represents each pin. Remember you are trying to recirculate the cold water out off the lines and replace it with new water so next time you open your faucet you get instant hot water. ones hot water is in the line you do not need the pump. i also recomend to set the pump 15 min before you get home or before you take a shower int he afternoons there is really no pint to leave the pump all day or for longer than that because the objective is to replace cold with hot water you can even set it to turn on and off every hour for 15 min at a time if someone is home all day but remember usually the recirculating pump is there for the faucets that are far away from the water heater so if you do not used them all day and only in the morning and at night before going to bed then there is really no point to leave the pump on and waste more electricity.
Sep 28, 2009 | Noritz 7-9.4 Adjustable Tankless Wtr...
Honeywell HZ-705.....HELP!!!!
Should have oil in it. I don't think you can refill it. If it has leaked out, it's probably no good. Anyway, here are the instructions.
Press the *power button* once to start the heater on high power, continuous run. If left at this setting, the unit will run continuously on high power (1500 watts, 12.5 amps) and will not shut off until the unit is manually turned off.
Press the *power button* again, to change to low power, continuous run, (900 watts, 7.5 amps) and will not shut off until the unit is manually turned off.
Set temperature:
Press the temp/timer button until the temperature icon blinks. Use the up and down arrows to set the desired temperature.
The temperature icon will stop blinking and the current room temperature will reappear after the desired temperature is set.
The heater will turn off and on to achieve the desired temperature.
Set timer: (auto off)
Press the timer/timer button until the timer icon blinks. The hour display will appear. The auto off icon will also appear.
Use the up and down arrow buttons to set the heater operation time between 1 and 10 hours. This function will activate once the timer icon stops blinking. The heater will automatically turn off whn the times runs out.
Set timer: (auto on)
Press the temp/timer button until the timer icon blinks. The hour display will appear. The auto on icon will also appear.
Use the up and down arrow buttons to set the heater start time between 1 and 10 hours. This function will activate once the timer icon stops blinking.
The heater will automatically turn on when time expires.
Hope this helps!
Aug 17, 2008 | Heating & Cooling
Clock radio, small
This little guy has the most complicated date setting procedure I have ever seen! From the manual: "Manual Time and Date Settings 1. To change your time setting, press and hold the J Time Set Button so that the clock display begins flashing. 2. While the display flashes, press the 1 Reverse and 6 Forward Buttons to set the time. Hold a button for a few seconds to set the time rapidly. Be sure to set the correct AM/PM time, shown by the PM Indicator. 3. After setting the time, press the 4 Enter Button or wait about ten seconds for the clock to beep twice and the setting to lock into place. 4. To change the calendar, press and hold the 9 Date/7-5-2 Button until the display shows the flashing year. 5. Press the 1 Reverse and 6 Forward Buttons to set the current year. When you have selected the year, press the 4 Enter Button, then use the 1 Reverse and 6 Forward Buttons to set the month/day. 6. After you have set the date, press the 4 Enter Button or wait for the display to beep twice and lock into place." You can download the manual from the link below: http://www.timexaudio.com/pdf/T307_IB56281_07.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 24, 2007 | Timex (T307S) Clock Radio
Hardware & Accessories Logo
696 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
