Question about Compaq Armada E500 Notebook
Black screen My cousins daughter owns an E500. When the PC is turned on nothing happens. Some lights above the keyboard turns on, that's all. The light indicators are battery, "1", "A" and arrow down.She is using the correct AC adaptor. Please?
  • 2 more comments
  • ravi chavan Nov 26, 2007
    got a same e500 armada.. when power switched, all led's glow once, but no display, i checked opening it, the cooling fan is also off but the cpu is getting warm, i have not checked the ram yet as there is no response from the cpu fan.. not sure, please help me..
  • Anonymous Nov 28, 2007
    same problem
  • ravi chavan Dec 05, 2007
    hello there..
    ya there are two ram modules, i removed one by one and checked, but in vain, i also tried it without the ram where i thaught it would give long beeps like on desktop boards, but no beep.. is the board faulty???i dont have spare working ram to check, what do i do???
  • Anonymous Dec 07, 2007
    Problem Solver:
  • 15 Answers
You say the LCD display is black on power up. Are you absolutely sure? Sometimes the backlight on these LCDs burnout and the display is very very dim. If this is the case then it's an LCD issue. If not then connect the laptop to a monitor and toggle the screen to monitor. If the E500 video displays correctly on the monitor then I say you have a 95% chance of an LCD issue.
Posted on Dec 04, 2007
  • 181 Answers
I'd reseat the memory first. If there are two pieces, take first one, then the other alone in the system. Possibly bad memory. If that's not it, the lcd cable could be unplugged. Try connecting to an external monitor. If that works, it's the lcd somewhere.
Good luck
Posted on Nov 22, 2007
Blank screen will not turn off
You turned on your laptop and horrors upon horrors, the screen is BLACK! You see that the laptop has power but besides that nothing is happening. I want you to know that there is a very good chance you can get out of this situation quickly and without any cost. This fix works on all brands of laptops:
• 2) REMOVE YOUR AC ADAPTOR CORD, that's the wall power, remove it.
• 3) NOW HOLD DOWN THE POWER BUTTON FOR 30 SECONDS That will drain any static electricity that has built up on your laptop system board and many times fixes the problem of a black screen. After the 30 seconds re-connect your laptop to the wall power and hit the power button normally and see if the laptop comes back up. Replace your battery.
A blacked-out screen doesn't necessarily indicate a broken monitor.
If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on. To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard. Press the power button if the screen remains black. Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue. Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue. Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases.
Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop.
Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment. Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard. Wedge the edge of the keyboard bezel off of the top cover.
Work your way along the edge of the keyboard bezel to loosen it.
Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel.
Reconnect the display cable to the motherboard if the cable has come loose from the connector.
Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place. Turn the computer back on.
If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective.
If the external monitor works, the LCD screen could be broken.
If the monitor doesn't work, the motherboard or video card might need to be replaced.
Dec 27, 2012 | Computers & Internet
My daughter's ASUS Eee PC 1015PX shut off by itself last night and now it won't reboot. When I tried to turn it back on it said system is recovering but nothing ever happened. Just a black...
May be this some conntact in the motherboard or chip heating because in this notebook the cooling system is not so good.
Or, may it be from adapter because in the jack cable when I mesaure the voltage is about 14,2 V approximatly. And I don't understad why is this voltage when mY adapter is 12V. The cable I put it my self becaus the old one is damaged but adapter is the same.
Sep 25, 2017 | ASUS Eee PC 1015PX Netbook
the monitor lights may have burnt out
Jan 03, 2012 | LG E500 Express Dual Series Notebook PC
My dell vostro 2510 won't power on, when i press power button to turn on the pc , the power light turn on for about 5 sec then it turn off itself,
Try this to see if can give us some codes with it's on board diagnostics. Hold down the function button of your laptop and then the power button while still holding down the Fn/Function button on the left side of the keyboard. See if this gives you either an error message on your screen or, flashing lights above your keyboard. Pay attention, write down what lights where lit up what ones flashed, etc. This is to diagnose if the LCD isn't working. Comment back if you get either the light code or the error code on the screen. IF nothing happens try holding the Fn/Function button on the left side of keyboard and holding the F4 button, see if that makes any lights flash above your keyboard.
Jun 18, 2011 | Dell Vostro 2510 Laptop
Can i put pc133 in a compaq armada e500,it turns on but nothing on screen
you can put on compaq e500, because e500 Pentium 3 and use DIMM PC133, but not show on screen you must sure your DIMM no broken.
Apr 08, 2011 | Compaq Armada E500 Notebook
LG e500 won't boot up, black screen!!
I think this is a bios problem. Locate the bios lithium cell and replace it and try again
Oct 22, 2009 | LG E500 Express Dual Series Notebook PC
Wont turn on
take it back to the place that you bought it. Sounds like you are having a issue with your motherboard.. If you can take it back i highly recommend it. A replacement motherboard could cost a high price depending on what computer you own.
Dec 27, 2008 | Compaq Armada E500 Notebook
open the window you have a recovery disk handy
Oct 09, 2008 | Compaq Armada E500 Notebook
DS lite, power is on but nothing happens
Ditto... except my daughter is 10. Both screens remain black, are fully charged and green light stays on for more than 4 minutes.
Sep 14, 2008 | Nintendo DS Lite Console
Computer wont start
Nothing is booting ......when in earnest I say that is the BIOS screen at the beginning not going too. When you say the lights all go but the computer does not BOOT can you clarify please what goes. Now you say the processor fan does not work I imagine you are INSIDE the unit to know this try pushing down on the CPU firmly with your hands it may have dislodged slightly it can do this sometimes.....Ive seen it happen. Now for the not booting I need to know what is if any?.
Sep 05, 2007 | Compaq Armada E500 Notebook
Compaq Armada E500 Notebook Logo
89 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
