Hitachi 27GX01B I have a Hitachi 27GX01B bought it new in 2002, I now have all the telltale symptoms of a bad Pump up cap, I can provide schematics, if some body can point out the offending caps number {c????} I am fully aware of the 50Kv in there, and the danger involved, and know what im doing, just not too sure which cap it is. I have the PDF schematics, or they can be downloaded here, "Its in 3 parts" not sure why.
  • 1 more comment
  • Christopher Peckham
    Christopher Peckham Nov 22, 2007
    it seems that sometimes when you click the above link it can dl part3 and not take you to the page if thats the case then here are all 3 parts NOTE you need all 3 parts before you extract, its a multipart file, the 3 files unzip into a single PDF document, which is the service manual and has a complete circuit diagram at the end, Im trying to learn and would very much like to know how to identify the pump up capacitor on the vertical output circuit,"which one is it". Thank you, Please help.
    Christopher Peckham Nov 27, 2007
    thank you so very friggin much, great!!!!! :)
    P.S. it was c454 FYI
    Christopher Peckham Nov 28, 2007
    Been on for 36 hours straight, picture is perfect, hasn't been this good in a long time, I had a compression problem at the top of the screen "credits compressing as they get to the top of the screen" for a couple of years, only had the white lines for a month or so, but it fixed both problems, im very happy, again Thank You. :)
  • 87 Answers
Check c458; (100/16) c454; (220/35) c453; (470/35); c451 (2.2/50) all are electrolytic capacitors located near IC 451 (la7845) If you have an ESR meter it would help out greatly to identify the weak cap or caps.
Posted on Nov 25, 2007
  • Anthony Wilson Nov 30, 2007
    Glad I could help. The picture of your symptom was helpful in diagnosing the problem. I wish more people would attach a photo when they have a video issue. Thank you.
Hitachi nr83a leaks air at new g.asket between head cap and body. screws are tight
If its constant leaking inside the nailer (not between cap and body to outside feeling an airstream in front or on one side )then there is an problem between top seals VALVE and seals o-rings on top of the piston cilinder the parts on the top of the cilinder Seals and in the top in high priority must all be replaced because of the building up heat overtime the gaskets seals and o-rings are getting hot and hardened out over time there are only separate parts selled one by one to get I have not seen hitachi gasket/o-ring kits for nailers there where only complete kits for the older range of demolition hammers , but in the new models not anymore outside the States m,aybe but in Europe not. replacing the piston bumper could sometimes help extra because of the little height difference of the cillinder .
If leaking between cap and body with a palpable airstream and before the seal was closed tight , retapping the treaths some greater in the magnesium body and place helicoils inside it could be bad treath in one of them , it must put firmly fixed that will not fasten enough that was with the Brand Dutack Pro a high priority problem for a few years ago exact the same a few years now its modificated and that problem is gone.
Hitachi NR83A 3 1 4 34 Full Head Nailer Parts
Mar 21, 2017 | Hitachi Tools & Hardware - Others
Yep, I agree with REV, The is a big one near the center of the plenum on the backside. A couple of them by the throttle body. Since the EGR is on the side, check the tube for it also. On occasion I have found a hole right behind the throttle body on top of the plenum. It was caused by bad catalytic converters getting to hot. All that heat went to the EGR and melted a hole threw the plenum under the wiring harness.Also make sure the air filter duct is tight on the throttle body. One other thing, If you have an exhaust leak on that side at the head, this too could pop a lean code. If all that is good, Replace the O2 sensor on the back side of the engine.
Jan 03, 2015 | 2002 Pontiac Bonneville
2002 chevy truck v6 not getting gas why has new fuel pump new inline filter and new relay
Check your fuel pressure regulator, when they go bad you get 0 pressure. Also check you connections and grounds
Nov 06, 2014 | Chevrolet 2002 Chevrolet Silverado 1500...
How do I disconnect the warning chime?
Key in ignition chime ?
Saturn L-Series ?????? L what ? L100 ,L200 , L300
Audible Warnings
The body control module (BCM) will provide an audible warning for various events relating to the vehicle. The functions that provide an audible warning are the key in ignition, the lights on, the occupant restraint (seat belt) and the park brake.
Key in the Ignition Audible Chime
The BCM will provide an audible chime if the key is left in the ignition in either OFF or the accessory position with the driver's door open. The chime rate for this is 150 chimes per minute. The key in the ignition chime has a higher priority than the lights on chime.
Lights on Audible Chime
The BCM will provide an audible chime if the park lights are on and the driver's door is open. In addition, 1 or 2 other conditions exist. The key is out of the ignition, or the key is in the ignition in the OFF position, and has not been turned. The BCM will chime at a rate of 200 chimes per minute until the conditions are removed.
Occupant Restraint Audible Chime
The BCM will provide an audible chime based on the class II message received from the SDM if the driver's seat belt is not buckled when the ignition is turned to run or crank. The chime rate for this feature is 50 chimes per minute.
Park Brake Audible Chime
The BCM will provide an audible chime for park brake when the park brake is applied and the vehicle speed is higher that 3 mph. The chime rate for this feature is 200 chimes per minute.
You can't disconnect anything . The problem has to be fixed .
Audible Warnings (Chime)
Chime Rate Per Minute
Occupant (Seat Belt) Restraint Audible Chime
Content Theft Pre-Alarm Audible Chime
Telltale Chimes
The body control module (BCM) will provide 4 chimes for each telltale activation per ignition cycle, at a rate of 150 or 200 chimes per minute. The chimes are limited to 1 chime event per telltale for each ignition cycle. The power up telltale function will not activate the telltale chime function. If the telltale becomes active during a cycle then the chime will sound.
The following telltales will activate the chime function:
• Low Washer Fluid
• Change Oil Soon Indicator
• Brake Fluid Low
• Oil Pressure Low
• Coolant Temperature Hot
• Low Coolant Level
• Low Fuel Level
• Antilock Brake System
• Volts Light (Generator)
• Supplemental Inflatable Restraint System (Air Bag)
• Trunk or Hatch Ajar
Having the vehicle checked for DTC'S - diagnostic trouble code's in the BCM would be the first step in the diagnostic procedure .
DTC B2965
When the ignition key is seated in the ignition switch, the key-in-ignition switch contacts the close, grounding circuit 80. The body control module (BCM) monitors the state of the key-in-ignition switch, the state of the ignition switch (OFF, ACC, or RUN) and the driver's door to control the key-in-ignition chime.
Nov 28, 2017 | 2002 Saturn L-Series
I bought 2006 kx250f without starting it when I put coolant in it leaks out my oil filter
probably not cooing out the oil filter, possibly coming out the water pump telltale hole, to let you know it needs a new water pump seal
Sep 26, 2011 | 2006 kawasaki KX 250 F
Idle surges when cold for about 3 minutes until it starts to get warm then acts completely fine.,.,, nobodyknows whats wrong ,, diagnostics have beenr un it just shows misfire temp sensor replaces new...
check the idle air controller, it may need cleaning or replacing-I'd also look for any vacuum leaks, especially before the throttle body-classic symptoms
Jan 26, 2011 | 2002 Mitsubishi Eclipse
Leaking water pump how to fix
When the water pump leaks, it is time to go. You need to get a new one on there. That is the telltale sign of a bad pump, all cars, trucks, even washing machines have the same pump. Check it out, hope this helps.
Oct 05, 2010 | Saturn SC1 Cars & Trucks
Im pretty sure the pip module in my mitsubishi vs-50605 has gone bad is it a real hard fix or is there some way i can bypass
yeah you can use two caps to bypass and pull out the whole pip module. You'll have to find schematics because I cannot find my documentation, if you can't find the schematic, then let me know I can dig some more.. Basically you pull out the pip module and then add in 2 10uf caps to just pump the signal back into the signal board.
heres something i found, not positive its credible but should be safe to try
pull the module out and just push the caps into the connector
if it works, then you can solder in, i usually broke off the old connector to have an easy pop in fix.
oh.. the symptom is usually a black or bad pic, but the pip looks good = bad pip module caps (too many to fix unless you really want pip)
heres your pic
i've seen it work with many diff sized caps, this says to use 4.7uf instead of the 10uf I suggested, either will prob work.
Jul 13, 2010 | Mitsubishi VS-50605 50" Rear Projection...
Wont start
you likely have a bad cap and rotor when the weather gets humid and or very cold moisture can get into the cap and cause a crossfire condition(firing on mulitple/wrong sparkplugs) and will prevent it from starting.My 1996 chev silverado has done this to me 2 years in a row on one of the coldest nite of the season and both times a cap and rotor fixed the problem.(the first time i bought the cheapest one I could find...not so cheap now though!)
Hope this helps!
Jan 05, 2009 | 2002 Chevrolet Astro
Hitachi 27GX01B pump-up Capacitor, vertical output
I have the same problem with a Phillips Model: 32PT5441/37
ISo far all I can find on this TV is the pump-up capacitor for the vertical output circuit may be bad but I can't find very much information on this model.
I do high end PC system builds and PC repair but have no expertise in TV repair so any help or a solution to my problem would be appreciated...
Nov 10, 2007 | Televison & Video
Televison & Video Logo
365 people viewed this question
Top Televison & Video Experts
