SOURCE: Oven blew a fuse
The POP sound normally indicates a short circuit fault (as opposed to overload) you need to have it looked at by a competent person.
SOURCE: Baumatic B180ss Electric oven problem
It sounds like the overheat safety stat is cutting the oven off.
This is prevent the oven overheating and catching fire.
They can go faulty and operate prematurely, causing the prob u are experiencing.
If it is built in , make sure it has adequate ventilation, as this can cause the prob.
Also check to see if it has an external cooling fan fitted, these can fail, and again cause the prob.
They are usually fitted under the top cover of the oven, and designed to keep the oven cool.
It should come on shortly after turning the oven on
These things are the most likely cause of the prob.
plz rate my solution.
Thanks.
SOURCE: I have a baumatic bc3510ss double oven. everything
Tthere are a couple of possibilities for your prob, the thermostat, or the oven element is faulty.
Disconnect the oven element, and try it again, if it does not trip, replace the element, if it still trips, replace the stat.
Please rate my solution.
Thanks.
SOURCE: bottom oven failed
It sounds as if your bottom oven heating element has 'blown'. You will need to replace the heating element.
