Question about Asrock GE PRO-M2 Motherboard
Screen not showing anything
My Asrock GE PRO-M2 computer does not show anything when i turn it on
-it doesn't beep
-the cpu and power fans are okay
-i tried inserting a different ram module but it didn't work
-i inserted a video expansion card and still nothing worked
can you pliz help !
  • my Asrock GE PRO-M2 computer does not show anything when i turn it on
    -it doesn't beep
    can you pliz help !
  • Anonymous Nov 24, 2008
    -it doesn't beep
  • 304 Answers
Some time the system will work due to insufficient power source this problem may occur replace SMPS and check the CPU heat by touching it. If it warm then the CPU is functioning. Else contact your nearest hardware vendor.
Hope this will solve your problem.
Posted on Nov 22, 2007
Hello can i connect 2 fans to the motherboard? 1 is at the rear,,can the other 1 go anywhere else with 3 pin connectivity??
Hi, this link will show you the manual to your Motherboard, Page 12 section 1.4 Motherboard Layout. this page will show the layout and you may need to zoom in to see it clearer, there is No.5 CPU Fan Connector (CPU_FAN1) next to the CPU slot and there only seems to be 1 more Fan connection No.15 Chassis Fan Connector (CHA_FAN1), this seems to be the only additional fan connection, normally you would connect a side door/panel fan, the rear fan connections direct to the PSU.
Sep 17, 2010 | Asrock 775Dual-880 Pro Motherboard
Asrock ge pro-m2 whats the best spec i can upgrade to?
According to the downloadable manual on the manufacturer's web-site:
the maximum RAM supported is 2GB, and it is a Socket 478 CPU interface.
Since you don't have the "GE PRO-HT" motherboard,
you cannot use a "hyper-threading" CPU.
So, you can use any non-hyper-threading Pentium/Celeron that has a Socket 478 interface.
Dec 08, 2009 | Asrock GE PRO-M2 Motherboard
Cpu no up, monitor shows
could be the whole pc is fried :(
Jul 10, 2009 | Computers & Internet
Computer sounds like its on but no display
Remove all plug-in cards including the memory and clean the contact points with a pencil eraser... Insert them back and try... You should hear 2 short beeps, which means Okey... Long beep means that there is a problem with the memory or one of the memory... Keep me posted if not solved...
Happy Fixya...
May 21, 2009 | AOpen AX4B-533 Tube (91.8A210.102)...
I am having sound problem my pc is show to install asound driver
Follow that link above, download the drivers for your sound and install them, hopfully that will help you get the sound back
Good luck to you
If you find my answer helpfull, dont forget to vote
Dec 17, 2008 | Asrock GE PRO-M2 Motherboard
Drivers sound
Hi gallardolagu,
You can download the sound drivers for your motherboard at the following location:
Hope that helps,
Take care,
Nov 19, 2008 | Asrock GE PRO-M2 Motherboard
Asrock P4i65G Motherboard
If the CPU is dead the problems can be
  1. no power
  2. no fans etc or
  3. power, no beeps (errors)
If the Ram is not compatible it would be constant beeping.
With the board in, and power supply 20pin + 4pin Pent 4 power attached,(#2 and #7 of motherboard layout) remove power cord from power supply.
CLRCMOS0 allows you to clear the data in CMOS. The data in CMOS includes
system setup information such as system password, date, time, and system
setup parameters. To clear and reset the system parameters to default setup,
please turn off the computer and unplug the power cord from the power
supply. After waiting for 15 seconds, use a jumper cap to short 2 pins on
CLRCMOS0 for 5 seconds. Remove the jumper. Remove heatsink and fan from CPU. disconnect cpu and reseat it. Re-install heatsink and fan. Plug in the power cord. Try to boot up. If it still does not boot and (no power, no fans etc.) problem would then be cpu is fried.
Jun 02, 2008 | Computers & Internet
No Post
I always suggest this and many times I get yelled at, but I'm just trying to help...
Did you plug in both power cords? There are two, one is rectangular and one is a smaller square shaped connector.
If that's not it and you've tried pulling all the cards and devices (RAM, HDD, CD/DVD) then you most likely have a bad motherboard.
Good luck.
Dec 28, 2007 | Asrock GE PRO-M2 Motherboard
Seagate harddrive diskread error
go to bios and see there whether it is showing showing your hard disk or not if it is showing then re-install your XP again format your hard disk with the slow formating option,while re-installing it.
Nov 23, 2007 | Asrock GE PRO-M2 Motherboard
Asrock GE PRO-M2 Motherboard Logo
124 people viewed this question
Top Asrock Computers & Internet Experts
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
