Question about Microsoft Windows XP Professional with Service Pack 2c Full Version OEM for PC
My (Win XP SP2) command prompt does not work
My (Win XP SP2) command prompt does not give the any response
when I enter the command cmd in run window
Run window does not appear
pl help!
    Scholar:
  • 41 Answers
First off, lets try a few things. This will help us narrow it down:
  • Try typing other known commands to see if they work (ipconfig for example)
  • Do a search on your computer for cmd.exe (you should only have 1, and it should be in the system32 folder.)
  • try typing cmd.exe instead of just cmd.
Give those a shot and report back. Depending on which one of these give you a problem, it could point to the correct fix.
The reason I say this is that your easiest solution may be to upgrade to SP3. The only times I've ever heard someone having this problem was also in SP2.
Posted on Jul 27, 2009
  • 805 Answers
It occure for virus affected 2 ur system. as a result it can not run. so u need reinstall ur windows sp3. then it will work. thanks
Cant find my mac address
Assuming this is a Microsoft Windows system...
Click on Start
Then either Run (Windows XP)
Or just type into the dialogue box above the Start button (Windows 7)
Type in: CMD and press Enter
In the black window next to the >
Type in ipconfig /all and press Enter
In the output look for the Physical Address in the 12 character alpha-numeric format of:
xx-xx-xx-xx-xx-xx
This is the MAC address
Jun 02, 2011 | Computers & Internet
Toshiba a100 how do I go to command prompt ?
There are two ways on getting to the command prompt:
*click start
(depending on the OS)
*XP: click run and type "cmd"
*Vista or Win 7 type "cmd" search window
or
*click start
*all program
*accessories
*command prompt
Good Luck!
Apr 13, 2011 | Toshiba Satellite A100-S2311TD Notebook
How i can download afree cmd.exe
cmd.exe, also known as the command prompt, is the command-line interpreter on Windows PCs. You do not need to download it it is already a part of Win XP.
All you need to do is click on Start, select Run and in the dialog box that opens type "cmd" and press Enter. A command prompt window will open.
Jan 10, 2011 | Microsoft Windows XP Professional
Windows explorer not responding
Insert operating system disk in drive.
Click Start. Click Run. Type
cmd
Hit Enter.
type in command prompt
sfc /scannow
Hit Enter
System file checker will replace the missing files. and run reg in out registry cleaner also
Sep 20, 2010 | Microsoft Windows XP Professional SP2
Windows explorer
Try this. Open Start>>Run and type cmd and press enter. This will open a command prompt window. On this command prompt window type the following steps.
type cd
type attrib -r -h -s autorun.inf
type del autorun.inf
now type d: and press enter for d: drive partition. Now repeat steps 3 and 4. Similarly repeat step 5 for all your hard disk partition.
Restart your system
Dec 23, 2009 | Microsoft Windows XP Professional SP2
Win 32
seems there is a infection in your system.
Run this command from command prompt and paste the putput here.
1) to start command prompt .
start => run => cmd.exe
2) type below command the copy the output.
cd \
dir /a auto*
3) paste the output here.
Jul 12, 2009 | Microsoft Windows XP Home Edition English...
Command prompt not working properly
  1. Select Start>Run...
  2. Type cmd
  3. Click OK
  4. The Windows Command prompt screen appears
  5. Type cd\
  6. Press [Enter]
  7. You are now at the C: root directory
  8. Type Time
  9. Press [Enter]
The system will show you the current system time and ask you to edit the time entry. If you press Enter without typing anything, it will keep the current time.
Jun 12, 2009 | Microsoft Windows XP Professional with...
How to find ip address
click on the start menu, then go to run and type in cmd and press enter.
after doing a new screen will pop up. in that screen type in ipconfig press enter and your local IP will be posted. If your looking for your router IP or the one that your ISP is giving you click on
http://whatismyipaddress.com/staticpages/index.php/lookup-results
and it will give you your external IP given to you by your ISP.
Mar 23, 2009 | Dell Dimension 1100 PC Desktop
Firewall settings
This usually happens due to missing or corrupt SharedAccess reg key, which represents the Windows Firewall Service.
Resolution
Download sharedaccess.reg (for Windows XP SP2 only) and save to Desktop. Then double-click the file to merge the contents to the registry. The Services entry will be created. Restart Windows (mandatory step, otherwise the following NETSH command will display an error message).
After restarting Windows, run the following from Command Prompt (cmd.exe)
NETSH FIREWALL RESET
Launch firewall applet from Control Panel, and then configure your Windows Firewall settings.
If nothing helps, as a last-resort solution (before reinstalling Windows XP Service Pack 2), give these two commands a try. Click Start, Run and type:
rundll32 setupapi,InstallHinfSection Ndi-Steelhead 132 %windir%\inf\netrass.inf
Restart Windows, and then run this command (from Command Prompt):
Attempt to start Firewall applet. Start the Windows Firewall service if prompted.
Apr 21, 2008 | Microsoft Windows XP Professional With...
My folder option is not working.
1. Open Start>>Run and type cmd and press enter. This will open a command prompt window. On this command prompt window type the following steps.
2. type the drive name which is nt opening ...
   for example : if  "C" is not opening means ..
                      type    :    C: "press enter"
3. type   attrib -r -h -s autorun.inf
4. type   del autorun.inf
5. now type d: and press enter for d: drive partition. Now repeat steps 3 and 4. Similarly repeat step 5 for all your hard disk partition.
Restart your system and your trouble will be fixed
Mar 31, 2008 | Microsoft Windows XP Professional With...
Microsoft Windows XP Professional with Service Pack 2c  Full Version OEM for PC  Logo
517 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
