Drop the battery yet, disconnect it.
the service manual shows how.
see that yet?
screen 100% black all time even with ESC key pressed, power on>
if totally dead and power pack reads 19vdc then
remove the battery.
no full service tag shown so no exact answers possible.
lots of x360 made , many.
if this scares you doing repairs get it fixed in a shop, like 99% do.
SOURCE: HP Pavilion zd8000 wont turn on, just blinks on and off
They are trash period and even though its an old post I feel the need to complain about this model.. Video circuit issues, Adapters, And charging circuit problems are coming out of the woodwork for these monsters.. If you go to www.hpnotebooksettlement.com you will find out who we are and how we got involved.. (Althogh we are not listed).. (Better this way..
Ken
SOURCE: laptop won't turn on
I am facing a similar problem with 5160 and my power button will not power up the laptop. I presses the shift key, it got powered up (offcourse only fan started but the screen is black)
Try pressing shift key to power up.
The blinking orange battery light generally indicates that the battery isn't working properly, usually going out and not charging properly. In this case, since the adapter will not power the machine without the battery, and it should, I'm going to say that the adapter is going out and not getting the proper amount of power to the system. Try replacing the adapter. Be sure to replace it with a Dell replacement, the Targus brand universal adapters do not work well with Dell machines, and in most cases won't work at all.
SOURCE: Blinking power up button
Its a powersupply problem in your LCD screen, i had the same thing happen to me- i found a site where you can fix it yourself- heres the link. http://computerguru365.blogspot.com/2008/01/fix-that-lcd-flat-panel-monitor.html I did it and it works.
SOURCE: hp pavilion dv5-1125nm does not turn on just led blinks
Sounds like it may have locked up during the restart, try doing a full power cycle. Remove AC cord, remove battery, then hold the power button down for 30 seconds. Plug just the AC back in and try powering it back up. f this works you're done, if you get the bios screen but windows fails to start you may have a failed repair on vista, btw, what exactly were you repairing when this happened.
Try the power cycle and if it doesn't work reply back to me and let me know what happens.
Chris
