Question about Carrier 38CKC060 Air Conditioner
Carrier Comfort Zone 2 Master is flashing E5
System seems to be working OK but continues o flash E5. Should I be worried?
  • 614 Answers
Check float switch. E5 is loss of 24 volt power on some models.Russ
Posted on Jul 27, 2009
I have a older comfort zone thermostat. It is flashing program and says heat?? We are trying to put the ac on??
Change the system selector to cool. Press hold if applicable and then set desired set point.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Aug 11, 2017 | Comfort Zone Heating & Cooling
Wipers in up position in off. 94 lincoln town car. How do the wipers return to rest position?
Do you know how to do electrical testing ?
PINPOINT TEST E: WINDSHIELD WIPERS WILL NOT PARK AT PROPER POSITION E1 CHECK WIPER MOTOR GROUND
  • Disconnect connector from windshield wiper motor.
  • Check continuity to ground at Circuit 57 (BK).
Is ground OK? Yes No GO to E2 . SERVICE open in Circuit 57 (BK). RESTORE vehicle. RETEST system. E2 CHECK FOR POWER AT WIPER MOTOR
  • Place ignition switch at RUN and multi-function switch at OFF.
  • Check for battery voltage between Pin 1, Circuit 65 (DG) and Pin 4, Circuit 57 (BK) at the windshield wiper motor connector.
Is B+ present? Yes No GO to E3 . SERVICE open circuits. RESTORE vehicle. RETEST system. E3 CHECK MOTOR CIRCUIT CONTINUITY THROUGH WINDSHIELD WIPER CONTROL MODULE
  • With multi-function switch at OFF, check continuity between Circuit 28 (BK/PK) and 56 (DB/O) and between Circuits 61 (Y/R) and 63 (R).
Is continuity OK? Yes No GO to E5 . GO to E4 . E4 CHECK CIRCUITS TO WIPER CONTROL MODULE
  • Disconnect wiper control module connector.
  • Check continuity of Circuits according to the chart below from the wiper motor to the wiper control module.
    Wiper Control Module Connector Wiper Motor Connector Pin Circuit Pin 6 Pin 2 28 (BK/PK) Pin 8 Pin 6 56 (DB/O) Pin 12 Pin 5 61 (Y/R) Pin 13 Pin 3 63 (R)
Is continuity present? Yes No REPLACE wiper control module. RESTORE vehicle. RETEST system. SERVICE open circuits. RESTORE vehicle. RETEST system. E5 CHECK WIPER MOUNTING ARM/PIVOT SHAFT
  • Check that windshield wiper mounting arm and pivot shaft and linkage is not bent, cracked or mis-positioned.
Is windshield wiper mounting arm and pivot shaft linkage OK? Yes No REPLACE windshield wiper motor. RESTORE vehicle. RETEST system.
Nov 14, 2016 | 1994 Lincoln Town Car
Comperasor running e5 problem
Change capacitor motor and outdur working almost
But 3 minute working ok
After E5 error show display screen on indur with outdour fan stop but compressor sound
Apr 23, 2015 | Haier HSU18VC7-G Mini Split Wall A/C Unit
Carrier Comfort Zone II Thermostat is blank and the 3 companion thermostats are all showing Error Code C1. What does that mean?
Hi Anonymous,
For all wall mounted and Artcool split system codes
Error code = C1 or CH1
Flashing Light = 1
Fault = Indoor temperature sensor open or closedcircuit.
Display = Indoor.
Indoor Operation = ON
Error code = C2 or CH2
Flashing Light = 2
Fault = Outdoor temperature sensor open orclosed circuit.
Display = Indoor Outdoor.
Feb 14, 2015 | Carrier Heating & Cooling
Daijitsu split system unit flashing E5 and Fan symbol what does it mean?
Maybe the surge capacitor on the fan or fan motor is faulty?
Jan 15, 2018 | Frigidaire Heating & Cooling
My carrier comfort zone II thermostat is flashing E1. What does this mean and why am I having trouble setting my temps?
I suspect that if you change the battery in the thermostat. All will be right again.
Thanks for choosing FixYa.
Aug 27, 2011 | Carrier Heating & Cooling
Hi, I have a nokia E5-00 and i downloaded and intalled all version of fring but its not working i am so worry about that because i have to experience video call on E5. plz send me sulotion of...
The problem is the type of file you downloaded. nokia phones use java applications so you need to download files that end with '.jar' NOT '.sis' or '.rar'. try that again.
Jul 17, 2011 | Nokia E5 Cell Phone
My Nokia E5 is not getting started
chek betry chek shot thats ok you do it flash first check charging its charging ok you check power switch
Dec 11, 2010 | Nokia E5 Cell Phone
Our Carrier Comfort Zone II thermostat, which has 2 zone readouts, currently shows a temperature of 00, as in zero zero, on one zone. That is the main zone for our home. Zone 2, for spare bedrooms, etc....
This .pdf file may be of help to you:
www.brivis.com.au/.../Carrier%20Comfort%20Zone%20II%20Owner's%20Guide.pdf
Perhaps you could get some help from Carrier Support here:
http://www.residential.carrier.com/support/index.shtml
I noticed they have an option of talking to an engineer, and perhaps they could explain how to reset or set the unit.
Hope this helps.
Sep 25, 2010 | Heating & Cooling
Carrier 38CKC060 Air Conditioner Logo
732 people viewed this question
Top Carrier Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
