Back to:
Tags:
Magic Chef CAV2000 Top Load Washer
Washer wont spin
posted by lisaprice113 on Nov 22, 2007
my magic chef model cav2000awn will not spin, it sounds like it is but will not turn. not even manually.
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Nov 22, 2007
Helpful (85)
chris72
Rank:Guru Guru
Rating: 93%, 396 votes
if the belt under the washer is intact then the transmission is bad. generally its time for a new washer unless its still under warranty
Rating Locked! (?) lisaprice113 has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on washer wont spin:
I don't want to Accept this solution
Can you Help with these Washing Machines problems?
The cold water runs constantly whether the machine is on...
it kept running until well ran out...the push in...
We are replacing an ancient Magic Chef top loading washing...
Went down to check on the wash and could smell a rubbery...
the washing stage doesnt work but all the stages spin...
Loading problems.
Repair Service
Find Washing Machine Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
