SOURCE: Alarm activated everytime I use the key to open the door.
very common issue with the vigor, it`s the power door actuator or something...there are 2 ways to fix it:
- the harder way (unless you`re half-decent at DIY car stuff, which I`m not), all you really are doing is cleaning the contacts..a detailed guide is here
http://www.acuravigorclub.com/Timely-Topics/Timely1202.htm
- OR the easy way is to just trick your car into thinking the hood is open so the alarm will never arm itself. Taken from another post:
You can effectively permanently disable the alarm (who actually bothers to respond when they hear a car alarm anyways?) by opening up the hood and finding the little switch that detects whether the hood is closed. Just bend this so that the alarm system always thinks the hood is open and the alarm system will never arm even if you lock the doors.
SOURCE: trunk won't open in 1994 lincoln towncar
You can get a good locksmith to make a key...last time I check it ran about 30-$50.
SOURCE: have a 2006 beetle convertible with several
inside the mechanical lock (The part that actualy holds the door shut when you close it) there is a switch that informs the control unit that the lock is either locked or unlocked.
These switches fail sometimes, when this happens the control unit is not aware that you have opened the door, and therefor will not wind the window down slightly.
This is also likely to be the cause of problem # 3 , door will not lock. I fthe faulty switch is not informing the control unit that the door is closed, the central locking will not try to lock the door (because it thinks the door is still open).
The switch is integral with the lock unit, and they are not easy things to replace either.
as for the wipers and engine fault, there could be a number of different possible faults here, would have to be looked at.
SOURCE: how can i open nissan primera's door,
i have Nissan Primera s manual,03 reg. Battery went dead two days ago, today i tried to open the car with my remote key, it didn't respond as battery was totally dead. I tried to open the door manually with the key,it wont open. Can any one help me please.....?
SOURCE: '91 LS400, trunk will not
If you hear the sound of the electric latch switch, then it's working but stuck somehow. Just put the key in the switch and turn it to the right and then pull up the trunk or ask someone to help you. it will open. I tried it today and it opened with me. It was stuck from inside by some kind of a broken plastic pieces. Just removed it and now it's working fine. good luck
