Question about Motorola Mobility ROKR E6 Smartphone
The tuoch screen does not work and after clicking once the navigation keys also gets stuck
    Problem Solver:
  • 6 Answers
Hey Sachin. Try to align the screen using Start> Settings> System> Screen> Align Screen. If this doesnot work, try doing a hardreset of your device
Posted on Jul 27, 2009
I have a mobiwire cell phone and need to know how to change the ring tone please?
Find "Customize"
Press the Navigation key.
Select Profiles.
Highlight General.
Press the Left selection key.
Select Customize.
Select ring tone
Highlight the field below "Incoming call".
Highlight the required ring tones to hear them.
Once you've found a ring tone you like, press the Navigation key.
Return to the home screen
Press Disconnect to return to the home screen.
Sep 26, 2017 | Cell Phones
I bought secondhand PC with o/s still on it, however the mouse pointer is still on the screen, got a new mouse but its not working, puzzled!
The computer should recognize the mouse and install it automatically if it is not you might have to go into add new devices. Use the tab and arrow keys to navigate if it is connected to the internet you might be able to down load and install a driver .if the mouse came with a driver disk even better.to navigate click the tab key and watch what gets highlighted when the start button is highlighted click enter then usr the up down arrow keys to go to
control panel then use tab to navigate to add new device manager you should be able to get windows to search for the device. If this doesnt work you may have to shut the computer down and go into bios and check that usb is enabled you can use the key board to do this also .Depending on what type of computer you might have to press the delete key on start up or somtimes the f2 or f 12 key some times it tells you on the bottom of the screen when it it booting up. which key to press. I hope this helps. If you aren't sure of these steps then let me know if you need more help.
Nov 22, 2014 | Dell Dimension 2200 (A-D0601) PC Desktop
How do I get my prtscn to print straight
Instructions
  1. Use PrintKey2000 to Direct Print
    • 1Download and save PrintKey2000 or PrintKeyPro from the "Resources" section. Save the file in a folder named "Printkey" on your "C:" drive. Double click the .exe file and follow the onscreen instructions for a problem-free installation.
    • 2 Access the Print Key program by double-clicking the hand icon in the bottom right hand corner of the task bar.
    • 3 Double click the "Options" tab in the upper right hand corner. Click on "Define Hot-keys." Set a hotkey for printing the full desktop and for printing the active screen you are in.
    • 4 Navigate back to the "Options" tab and select "Direct Print (No Dialog)" so that it has a check mark next to it.
    • 5 Select the "Printer Options" function on the main program screen. Select the printer you want the print jobs sent to.
    • 6 Select a screen to use as a test. Press your hotkey for printing the full desktop and then the hotkey to print the active page. You want to make sure both functions work properly.
    Use the Print Screen Function Without a Plug-in Program
    • 7 Press the "Print Screen" key on the keyboard to print the full desktop. Press the "Alt" key plus the "Print Screen" key to print the active window.
    • 8 Click "Start" in the lower left of the taskbar. Navigate to "Applications" and choose the Microsoft Paint program.
    • 9 Click "Edit" in the program screen and click the "Paste" option. You will now see a copy of your screen capture.
    • 10 Navigate to "File" and save the screen capture as a .jpeg file. Navigate to "File" again and click "Print" to send the job to an installed printer.
    Using the Print Key Function with ScreenShot 2 Print
    • 11 Download and install ScreenShot 2 Print. ScreenShot 2 Print has a free trial option, and as of May 2010, costs $7 for the full version. Configure the program to print to a designated printer from the onscreen commands. The screen captures will print automatically when the required keys are pressed.
    • 12 Hold down the "Control" key (Ctrl) and the "Print Screen" key to capture a screen shot of the full desktop. The image will be sent directly to the designated printer.
    • 13 Hold down the "Shift" key and "Print Screen" key to take a screen shot of the active window, which is sent directly to the printer.
May 21, 2014 | Microsoft Computers & Internet
The wrong key got stuck in the ignition of my 2003 lincoln navigator. Now the right key will not turn over. The ignition is locked
Try turning the steering wheel to the left and the right while trying to turn the key , you may have set the steering lock after installing the wrong key , you may have to turn it kind of hard each way untill the the key turns once it starts you shouldn't have any problems after that.
May 08, 2011 | 2003 Lincoln Navigator
Cursor stuck
If the mouse cursor is stuck, try looking for the mousepad toggle. Most models of notbooks have one or two ways to toggle the mousepad off. They are generally either a button right above the mousepad or a function key.
Look for a button that has two icons that appear to be mousepads, one with a line through it. If you press it (You might have to hold the Fn key located in the lower left corner if it is a function key), it should toggle the mouse back on if it was disabled in this manner.
If this doesn't fix the issue, try pressing the windows key to see if it pulls up the start menu. If so, try navigating to restart to see if that fixes the problem.
Lastly you can also try navigating to the device manager to see if the mouse drivers are missing etc. To do that press the windows key, navigate over to computer and press the alternate menu (directly left of the right Ctrl key) and choose properties. Use the tab key to navigate to the hardware / device manager tab. Once there look for the mouse driver.
If that doesn't help please post your laptop model, version of windows and any other relevant information you can think of.
Please leave feedback if this was helpful. Thanks.
Mar 21, 2011 | Computers & Internet
When typing numbers< signs are appearing instead of numbers>>>it"s like it"s stuck in caps!
need to do the two procedure:
  1. Go to Start>> Run. Type in: regedit [Enter] or click OK.
  2. Navigate to the following registry key:
    HKEY_CURRENT_USER\Control Panel\Keyboard
  3. Click the "keyboard" entry once to empty its contents into the right pane.
  4. Find a string entry titled "InitialKeyboardIndicators".
  5. Double click this entry and change the Value to either '2' for on,
  6. Exit the Registry Editor and reboot your system for the changes to take effect.
    HKEY_USERS\.DEFAULT\Control Panel\Keyboard
    InitialKeyboardIndicators = 2
Mar 26, 2010 | Fujitsu Siemens AMILO Pro V7010 Notebook
Sansa 260 Won't Let Me Navigate Back to Main Menu
The power button is also the Menu button - click and release once while the player is on, and see if it gets you back to the main menu. Or press the left arrow key and see if it will get you back to hte previous menu.
-Tha Mp3 Doctor
Feb 21, 2009 | SanDisk Sansa e260 MP3 Player
I have a dell XPS M1210 it is about 3 years old. It has Vista. I downloaded the latest Vista updates today and now my mouse pad is stuck. The arrow is in the middle of the screen pointing slightly to the...
try shutting it off, remove the power cord AND the battery...let it set for about 5 minutes, put the battery in, turn it on ...see if that clears the issue.
Jan 15, 2009 | Toshiba Satellite L10 Notebook
My Canon MP510 scanner won't scan - the printer works fine, but I can't get it to scan. It used to work just fine.
Try using your scanner from your computer, I'm using windows XP and when i go to My Computer and the printer is connected i see a section that says Scanner and Cameras, your printer should be there, click on it and follow the easy step to scan a document.
Nov 28, 2008 | Office Equipment & Supplies
1st Gen. Ipod Nano wheel control wont work
Greetings,
For instructions too long to post in here - click on this link
fxnlogo_s.png Technical Support, Instructions & Repair Service
Aug 01, 2008 | Apple iPod MP3 Player
Motorola Mobility ROKR E6 Smartphone Logo
71 people viewed this question
Top Motorola Mobility Computers & Internet Experts
AJMAL KHAN
Tom Chichester
Abby Carter
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
