SOURCE: Harmony 880 Logitech tv remote - won't change channels on direct tv
you may need to reprogram your remote, or, if you have your profile setup on the harmony website, reload from there
SOURCE: I cannot set the time, my 880 remote want allow me to set the time!
I saw these posts recently and decided I would try and figure out the time on my Harmony 880.
First, using your Logitech Harmony remote software, version 7.5.0, log on using your login ID and password.
Next, select the remote settings tab, and go to display settings. Select time/display format and check the 24 hour format. (Note: the assumption is that you have already set the 12 hour time before hand, even though is says A.M.) I made this change to my own remote when it was actually was 7:30 P.M.
My remote actually reported 7:30 A.M. at this point. Save your changes online and plug in your remote to your USB port and let the Harmony update your change. Now your remote should be in 24 hour format.
Finally, log back on using the same procedure above only this time, click the check box for 12 hour format, save your changes and update your Harmony 880 one last time. Your finished, your remote should now be displaying the correct time in 12 hour format.
SOURCE: Harmony 880 universal remote re-charging problem
I took the rubber feet off(4) from the underside of the cradle - removed the four screws and separated the top half of the cradle from the bottom. This exposes the two long thin charging arms and points All one piece). I then took some doubled sided tape, similar to what you use to put up temporary 3m picture hooks and cut four small pieces about 1/8th in square. Join two of the pieces back to back to make one piece (double original thickness), then raise one of the long charging arms gently and place the piece of double sided tape under the head of the arm (ie under the very end where the rounded point is, that sticks though the cradle when reassembled (there are two of these). Do this to the other arm.
Why - by inserting the doublesided tape you permanently raise the arms without bending them - ie they will now stay in that position and not bend out of shape, losing contact again . With the cradle reassembled, put the remote back in the cradle you will have more direct contact with the two charging pins. FIXED!!!!!!!! Good luck1
SOURCE: Non functioning "zero" button on Logitech Harmony 880 Rf remote
I have this exact problem. Unfortunately, disassembling the remote doesn't fix it. It's either programmed obsolescence or a design issue.
SOURCE: how do i reactivate a disabled logitech harmony
Unless you work for Logitech, it will be really tough to get the answer to this one! Seriously, though, there is probably someone who has hacked the software to do this, but it is certainly not being advertised. There are a couple of alternatives that I can think of:
1) If the remote is in good shape and you have all of the accessories, then you could purchase just a new Logic Board on Ebay. I have seen them for about $25 free shipping. I have done this kind of fix and it works out well.
2) If you're really a good hardware techie and you have a steady hand, you might be able to find an even cheaper 880 on Ebay that is being sold for parts and swap out the ROM chip. Not sure if this is possible, but if you are adventurous......
