Question about Akai LCT3201AD 32 in. LCD Television
Akai 3201ad tv won't turn on? what size for replacement.......
What size capacitors should I replace the melted ones with, so the tv doesn't shut down again?
    Problem Solver:
  • 7 Answers
All 1000MF 16V on power supply
Posted on Jul 27, 2009
TV won't turn on
It sounds that, the memory IC to your TV has damaged. This IC can be located very near to main system control IC. A very small one, with 8 solder terminals. Even though it is very small, function of it while the TV works is great. The work is a semi-skilled one, and you must have some knowledge in electronics to proceed.
Jul 09, 2012 | Akai Televison & Video
The red led on the front of the unit flashes. unit will not turn on and led doesn't turn green. is this a power supply issue?
The power supply board of the Television is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem.....
May 06, 2011 | Akai LCT3201AD 32 in. LCD Television
My akai dlp tv turns itself off then it flashes
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Feb 17, 2010 | Akai LCT3201TD 32 in. LCD Television
I fixed the power supply but don't have a
akai LCT2715 keeps shutting off or making a loud screaming noise that can only be turned off by shutting it down at the the tv
Dec 21, 2009 | Akai LCT2715 27 in. LCD Television
My Akai pdp4225m does not turn one green light is on but no pic or sound..There is a double clicking sound when I try and turn it on also when it does work it shuts off after and hour or so..Any info would...
Power supply filter capacitors and smoothing capacitors have warped. There will be some bad FET's, Diodes, and pull-up resistors too that need replacing. You can send us the board and we can repair it for you if you like.....
Your having a DC switching and regulation problem, its very common in these Akai models. I have repaired over 800 Akai LCD tv's so far since 2006. they all seem to have had the same fault scenario related to a similar problem like the one your having....
circuitworld@comcast.net
http://www.corkin.com/Profile/view.cfm?userid=77703
http://www.google.com/profiles/circuittvrepairs
http://circuitworldrepair.com/cwr.html
-Contact Us 443-802-7251
CWR-on_line Tech Rpt
Oct 29, 2009 | Akai PDP4225M 42 in. Plasma Television
I just replace convergence board on my akai tv and
There is a burnt capacitor somewhere in the unit. Look for any burnt or swelled up capacitors. You can also usually locate a bad cap if there is burn marks on the system board. Also test power supply with voltmmeter to make sure it is a constant volt reading.
Jul 11, 2009 | Akai PDP-42TD1 42 in. EDTV-Ready Plasma...
Akai flat screen lcd tv.. turns itself off after about 10 min
had a very similar situation with my Phillips 42 in. LCD TV.
Here was my Problem. The Power Supply Board. I opened it up( Warranty was Expired) and found several faulty capacitors on the PSB. Its pretty common. Major Electronic companies were sold faulty capacitors that fail in 2-5 years instead of 10-20 due to a lack of preservatives. It wouldn't surprise me if you have the same problem. TV will work fine for a few years and then just fail completely or slowly deteriorate.
Here are the solutions
1. Have it Repaired
2. Check for faulty caps and if you find some(budged or leaking) you know you have located a problem
Remove the board and replace the whole thing.
3. If you have some soldering skills you can replace the faulty caps.
Caps are very inexpensive, under a dollar in most cases. I replaced 4 for about $5.00
Hope this Helps.
Good Luck
Jun 06, 2009 | Akai LCT2715 27 in. LCD Television
Model LCT2721AD problem showed 5/11/09 about 24 hours ago. TV will not turn on with or without remote. It won't turn on with start button on the side of the unit. If I pull the power plug from the hou
No did not get it fixed I am in the process of moving from NJ to SC and don't have time this couldn't have happened at a better time.I will just move it broke.
Cheers William Ash
May 13, 2009 | Akai LCT2721AD 27 in. LCD Television
Tv doesn't turn on
power pack probably has blown capacitors on it. need replacement of those and the tv should be fine.
Apr 03, 2009 | Akai LCT2715 27 in. LCD Television
I have akai hd tv model # LOT 3201AD And fter 2 years of use , just yesterday started when i turn on the tv the green light lasts for 2 secends wand the back to red without turning on the tv
akai is not the best brand of tv to own mine did what yours is and it cost me 400.00 to fix it and i promised myself id never buy another one. there are 4 capaciters in the back and at least one possibly 2 of them are bad.
Dec 28, 2008 | Televison & Video
Akai LCT3201AD 32 in. LCD Television Logo
292 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
