Question about Fender Passport P-51 Consumer Microphone
Pluged into the wrong voltage
I have the Fender P-250... on the back it has a switch that allows you to plug the speakers into either 110v or 230v, well I forgot to change the switch to 230v and pluged into 230v and it was set to 110v. now it does not work.
    Scholar:
  • 57 Answers
The Fender Passport P-250 has a switch on the back of the unit that allow the unit to work with 120V or 240V systems. If you connect the unit to 240V when in the 120V setting, the fuse should blow without damage to the power supply. This is not 100% safe, but the intended design uses a spark gap device to absorb the overload for this condition with the intent to blow the fuse.
If you replace the fuse, and it blows again or does not work, you will need to replace the power supply module which is a custom part specific to the P-250.
I hope this information helps with your repair.
Posted on Feb 18, 2015
    Sergeant:
  • 175 Answers
You have to replace the power supply with exact voltage and amperage.
Be careful next time.
Regards;
Hassan
Posted on Jul 27, 2009
Hi, I stupidly plugged my Pioneer DJM 500 mixer
You could have quite easily have blown something internal.
Sep 03, 2013 | Pioneer DJm500 Professional DJ Mixer...
DRYER: Switched a 3 prong to a 4 prong and heard a pop when pluged into the wall. I then noticed my hot and cold wire were mixed up. Fixed the switch and nothing works now. Breaker switched off and on many...
Hi - why did you convert the plugs in the first place? In elctricity theres no such term as hot or cold wires. Besides what do you mean by a 4 prong or 3 prong? electrical equipments are designed to operate on 3 pin single phase power or a 4/5 pin three phase systems.
the voltages in both systems are totally different pending on where you live - 110v or 230v for a single phase or 230v - 415v three phases.
A single phase cannot be converted to the three phases or vise versa unless you use sophisticated electronics to do so. Unless you know what you are doing you can modify the 3 pin to opertae safely on a 4 pin by choosing the correct conductors in relation to the three wire conductors in the 3 pin plug.
The sad story for you is this will be a rather expensive lesson - I wont be surprise if the extra voltage has zapped some of the components in your machine.
THE BEST ADVICE I CAN OFFER YOU RIGHT NOW IS TO EMPLOY THE SERVICES OF SOMEBODY TO HELP YOU OUT - ALTERNATIVELY AS YOU STATED "BUYING AN OVER $1000 DRYER"
Jul 09, 2011 | Dryers
If the power supply has a voltage selection switch, set this switch to match the voltage in your area
230v for the UK and 110v for the USA.
If you live in a different country then you can Google the required voltage for your country
Regards
Jan 05, 2011 | Computers & Internet
MMP2 seems to have no voltage selector. Manual states power as 230, 240, 110v. I am reluctant to plug my US 110v unit into UK 230v mains. Would appreciate any info?
Check the manual..It's on the Roland site
In that unit , it's most likely an auto-switching power supply ie; universal 105 - 230 volts AC 50-60 hz
Aug 07, 2010 | Roland MMP-2 2-Channel Amplifier
I have the passport 250 on mic 1or 2 when pluged in microphone goes in and out 3-4 no problems
Read the section of the manual dealing with the voice over function for paging. Available here:http://support.fender.com/manuals/manuals_elec/fenderaudio//PassportP250.pdf Note pages 7, 8 and 9 especially 9 under VIP subject.
Jun 09, 2010 | Fender Passport Deluxe 500watt Sound...
What do I need to use my Touchsmart tx2 in France. Do I need an adapter or transformer or both
You live in the US, right?
First check the voltage rating on your power supply / charger's primary voltage range. If it states around 110V only, then you need a transformer from 230V to 110V with an euopean plug. Make sure it's a real transformer (rather heavy, rated at ~100VA will be OK), and not a lightweight high-power adaptor, used for lamps, pressing irons, heaters and similar appliances.
If on your charger it states something like "90-240V", then it will cope with the standard european voltage of 230V, and the only thing you need is a travel adapter that will have an european plug on one side and an american socket on the other.
Oct 25, 2009 | HP TouchSmart tx2-1270us Tablet PC
I mistakingly switch the voltage to 110v instead 230V
You are going to have to replace it....obviously. Here are some places that popped as having the supply you need. I have never used any of them personally.
Dell Optiplex Gx1 Gx110 145w Desktop Power Supply 5554t
$14.99 used - eBay Dell 11VTW Optiplex GX110 SFF 110W Power Supply (See 1728P)
$35.00 refurbished - Used-pcs.comNEW Dell Dimension XPS OptiPlex Power Supply, 200W, Dell 824KH
$19.97 new - TXcess Surplus
Oct 07, 2009 | Dell OptiPlex GX110 PC Desktop
What voltage will a HP 6715b accept?
hi no need of transformers.. ur lappy is ready to accept 230v-240v...
Feb 07, 2009 | HP Compaq 6715b Notebook PC
Mitsubishi MSH12TH heat pump air handler 110v
Wireing this type AC with the wrong voltage, will damage more than the circuit boards. I think the installer wil need to be responsible for the damage he created. The factory will also try to get out of the replacement because of the installers lack of know how.
Oct 20, 2007 | Mitsubishi Mr. Slim MXZ30TN Air...
Fender Passport P-51 Consumer Microphone Logo
371 people viewed this question
Top Fender Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Vito Vacirca Jr.
Rick Moore
Rick Moore
Are you a Fender Audio Player and Recorder Expert? Answer questions, earn points and help others
