Question about Sony VAIO PCV-L400 PC Desktop
I have a sony vaio pcv-L400 that is running extremely slow i started the cleanup utility and 3 hours later its still running and its only about 20 percent done, when i try to remove programs from the computer nothing happens. what could be the problem
    Sergeant:
  • 175 Answers
There are some Tips and Techniques for smooth and fast working of Windows.
Re-boot your system, press F8 for boot menu, select Safe Mode, Try to Uninstall any Useless software from Control Panel.
Go to;
C:\Documents and Settings\Administrator\Local Settings\Temp (Administrator Login Should be your user name)
Delete all files of the Temp folder.
Go to;
C:\Documents and Settings\Administrator\Local Settings\Temporary Internet Files
Delete all files.
Empty Recycle bin.
Go to;
Start>Run>Regedit>HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run Delete every value except Default
Go to;
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run Delete every value except Default
Go to Start>Programs>Startup> Delete all shortcuts.
Reboot system and now check.
Regards;
Hassan
Posted on Jul 27, 2009
  • 3,267 Answers
Now that you have started this application, try disabling the antivirus and disconnect from the net. If the operation finishes in a couple of hrs, its OK, 'cos it must be busy defragmenting your HDD and the larger the capacity of the HDD, it will take that much more time. If the PC hangs, then no other option but to manually restart, and might need your recovery disc to boot properly. Let it do its work as long as the laptop does not hang. It will sort itself out.............sodeep
Ram upgrade pcv rs402
Perform these simple tips given below to make your start up fast & reliable:-
- Disable Firewall.
- Uninstall unnecessary programs and files.
- Run disk cleanup through system tools.
- Turn ON Windows updates and update device drivers.
- Limit start-up items and manage background running services (must use reliable program RegInOut to manage it properly.)
Nov 12, 2013 | Sony VAIO PCV-RX370DS PC Desktop
When pc is star windows is slow respond and touch patch also then i am pressing any of the key pc is working normally
Improper computer maintenance may result in slow PC. To fix computer running slow you are required to clean junk and windows errors from your PC using a System Utilities program.
To download a reliable System Utilities, go to famous website download.cnet and search there Reginout. Which I personally use and recommend the friends.After downloading run all of its tools one by one except Internet Optimizer, to clean all the junk and error files from your computer.
Jul 30, 2013 | Sony VAIO PCV-RX370DS PC Desktop
Power cable at rear of sony vaio pcv desktop sparking and not starting up
Stop using it. Bring it to a repair shop ASAP. You need your PSU replaced and if you keep using it you'll need your motherboard replaced as well. In fact if you keep using it you could burn all of your internal components out.
Jun 09, 2012 | Sony VAIO PCV-V200G PC Desktop
I have a sony vaio pcv-L400 when I turn it on it says: disk boot failture, insert system disk what can I do I dont have the system disk
That message means that, for one reason or another, the computer can no longer see it's hard drive. The hard drive may have failed, or it might just not be firmly connected (especially if you recently moved the computer).
Sep 15, 2010 | Sony VAIO PCV-L400 PC Desktop
PC runs slow. Only has 512 RAM. Is there space for more? Machine is a Sony VAIO, about 7 yrs old. Model PCV 2234
1. Wait the long 5 minutes for your computer to boot. Once you're on the desktop, go to the start menu. Select "run..." Type "msconfig" (no quotes) into the box. The Microsoft system configuration utility should pop up (if you're on Windows XP, Windows 2K users visit: www.techadvice.com/win2000/m/msconfig_w2k.htm
Once this handy tool pops up go to the "Startup" tab...
You will see a list of every process that runs on system startup. Some of these should look familiar; if you know what a program on this list is and you know you don't want it loading on system startup, uncheck it. There will probably be items on the list that you don't recognize. Any of the things on this list can be googled; you'll find a page which explains what a process is, and if it's vital to the system or not. Anything non-essential or unwanted should just be unchecked. Without having to load all that additional garbage your aging computer should boot up much faster (depending on how many processes you disabled). When you exit the msconfig utility you'll see a message about restarting now or later; you are not required to restart right after you do this.
Aug 26, 2010 | Computers & Internet
My friend has a Sony VAIO Digital Studio PCV-RX850 desktop that is not online yet, but has very slow startup issues. What can be done?
The best thing to do is remove as many "Startup" programs as you can. START>>RUN>>msconfig & enter, then go to the Startup Tab, and disable, as many things there, that you absolutely do not need, you really do not need many things starting, as you can simply start them later, also go to Services, and check Hide Microsoft Services. Here too, disable anything and set to manual. Now RAM the more the better, also ensure you have at least 25% of your hard drive free. Defragment, and do a disk cleanup too. this should help a lot.
Mar 09, 2010 | Computers & Internet
The vaio runs slow when trying to get to the
download and install Tuneup utilities and fine tune you pc for registery errors. use all the features available there for speeding up the laptop.
You can even speed up / optimise your inetrnet connection there.
chose the correct speed depending upon the max speed provide to you by your service provider.
Dec 07, 2009 | Sony VAIO Digital Studio PCV-RX550 PC...
My partitioned Vaio harddrive is almost full - less than 3% space in C:/ and slightly more in D:/. I run cleanup and defrag utilities at least once a week and have uninstalled several programs as well as...
Go to my computer, C drive and D drive will appear. Put curser over C drive and press right finger on mouse. Menue will pop up select properties at bottom. View of drive will appear. In middle disk clean up. Select disk cleanup and run. The other area is at bottom of properties menue, Index or compress. This might squezz more space by compressing data.
Nov 08, 2009 | Sony VAIO PCV-RX741 PC Desktop
Problem Sony VAIO PCV-W510G
maybe this can help you,please try to replace the fan or you can also clean it.. http://www.docs.sony.com/release/PCVW510G.pdf
Jul 05, 2008 | Sony VAIO PCV-W510G PC Desktop
PCV-W20 Partition sizes
Have yout tried to recover without any partition defined? Try to execute with your hard drive clean.
Dec 17, 2007 | Sony VAIO PCV-W20 PC Desktop
Sony VAIO PCV-L400 PC Desktop Logo
65 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
