Back to:
Tags:
Hawking 10/100M Internet Print Server PN7127P Print Server
Print Server & TCP/IP
By man1 - usenet poster
Is anyone using any of the individual print servers like the $50 Hawking
unit with OS/2 and TCP/IP?  Since there are no OS/2 drivers, I could use
some help in configuring OS/2 using the OS/2 implemenation of TCP/IP.
Thanks
George Barrowcliff
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 07, 2005
Not Rated (0)
Chandler
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
FYI, I got a second Hawking PN7127P last week for my new color printer, the Canon
S800. Fry's had raised the price from $49.95 the week before to $69.95 :-( But I
got it anyway, figuring I would be able to use the "price matching" thay Fry's
has. Unfortunately, it seems everybody else raised their price on it too. It was
too good to be true.
Anyway, once I got my S800 printer thursday, I hooked it up through the print
server. I found that color prints were fast in OS/2, but low-quality (see my other
article about S800 vs OMNI). In Win2K, they were perfect prints, but very slow. In
fact about 5 minutes per 4x6 photo, when the doc claimed 1 minute for that ... I
know the manufacturers exagerate, but still, that was intolerable. So something
was obviously wrong with the print server. I tried both TCP/IP and NETBEUI to the
print server in Win2K, but they were equally slow. I then tried connecting the
printer directly via parallel port to the PC. It worked fine and the print time
for the 4x6 photo in Windows was more in-line with the doc (about a minute and a
half). That was pretty odd.
I was happy to find out when I rebooted to OS/2 that printing through the parallel
port was still fast, and didn't seem to peak both CPU and stall everything else on
the SMP system like it did before when I printed to my Okidata printer through the
parallel port. That seems to indicate that the IBM PRINT01.SYS problems with SMP
systems are specific to some printers, which is rather odd. FYI my Okidata has
18.5 MB of RAM, while the Canon has only 80 KB. Perhaps that's part of the problem
too, but you'd think the bigger buffer in the Oki would make things easier on OS/2
rather than so much worse ...
In the end, I have the Canon S800 color inkjet hooked through parallel port, and
the B&W Okidata laser connected through the $49.95 Hawking PN7127P print server I
got two weeks ago. I returned the second $69.95 PN7127P print server to Fry's
yesterday.
Now, if I could only find good OS/2 print drivers for the S800 I would be really
happy, but that's another topic.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Print Server & TCP/IP:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Powe33
Rating: 0%, 0 votes
Sir:
Thanks for the recomendation.
Set the LM Announce switch to on in the print server.  OS/2 does not
assume something is there.
Cannot help with the <snip> stuff.
Bill
<Have a Happy Valentines Day>
Thank You!
Solution #3
Not Rated (0)
Jimmy NY
Rating: 0%, 0 votes
George,
FYI, I bought the exact same PN7127P print server at Fry's today on your
recommendation.
I am unable to set the IP address from OS/2 using the above procedure.
Yes, I am using an IP address on my LAN, and the NodeID printed on the
back of the print server.
[c:\]hawk
arp -s 198.144.199.92 00:40:01:80:27:2C
ping 198.144.199.92
PING 198.144.199.92: 56 data bytes
----198.144.199.92 PING Statistics----
1 packets transmitted, 0 packets received, 100% packet loss
[c:\]arp -a
          ARP table contents:
interface     hardware address         IP address   minutes since
                                                      last use
  lan0       (incomplete)       198.144.199.92            0
[c:\]
The weirdest thing is that if I use the same procedure under Win2K, it
works, and properly sets the IP address. It appears to be an OS/2
specific problem. I can reboot to OS/2 and then the IP address will
respond... Until the print server is powered off, at which points it
forgets about all the settings.
I'm curious what version of TCP/IP you are using, since you got it to
work in OS/2. I'm using TCP/IP 4.3 under WSEB
Thank You!
Solution #4
Not Rated (0)
Bouncy
Rating: 0%, 0 votes
I gave up trying to figure out what was wrong with the OS/2 stack and
ARP. I just did the setup with ARP under Win2K. Then, the web management
interface became available, and I could save the IP address setting into
the print server permanently - even if powered down. Since then, the
Hawking PN7127P has worked fine with OS/2's TCP/IP.
I'm not using OS/2's built-in lprportd which is excruciatingly slow and
buggy. I was getting lots of delays and lost jobs with it. Instead, I am
now using Serge Sterck's excellent lpr32 package, which is available
from Hobbes. With it, the jobs go to the printer over 100 Base T
instantly, there is no delay, and it just works as a network printer is
supposed to be. I'm very happy. This is particularly true because my
main machine is SMP (dual Athlon MP 1500+) and to this day IBM has not
resolved the major printing problems in PRINT01.SYS that caused the
computer to be completely useless during printing. With the TCP/IP
printing it all works smoothly and transparently, without any CPU usage.
I think Serge should sell his great package to Hawking to bundle as an
OS/2 driver.
The Hawking PN7127P is also supposed to support NetBEUI. The doc is very
thin on that support. It does work in Win2K though, after updating the
software. But the printer remains invisible to OS/2's NetBEUI for some
reason. I'm not going to bother pursing that problem, since TCP/IP was
successful for me.
On the topic of printing. I'm using an Okidata 610E/PS printer, which
isn't officially supported in OS/2. I use the LASERJET.DRV Okipage 6/6ex
driver from IBM which gives 600 dpi and works very fast. This printer
also supports Postscript - which works when I use the PSCRIPT.DRV
drivers and select HP4MP (that also gives 600  dpi). The results for
graphics are noticeably better with PS than with PCL.  But the
Postscript processing in the printer is very slow - I'm talking minutes
per page in PS, instead of 6 pages per minute in PCL -  even with the
maximum amount of printer RAM (18.5MB); so I'm using it primarily in PCL
mode. In addition, the emulation autoswitch (PJL) doesn't work right, so
I have to switch the printer from Postcript to PCL manually on the
control panel before I submit a job to each PS / PCL printer object in
OS/2 ... Not practical. I think I could possibly solve that one with a
"separator" file containing the right switch commands to put in the
printer object, if I could obtain them from Oki or reverse engineer them
from their Windows drivers. Unfortunately the switch commands for Oki
are slightly different from HP's printers - the HP drivers' autoswitch
doesn't work. The Oki is a very good PCL printer though, just not a
usable PostScript printer. It is a 6 year-old black & white LED printer;
and I'm considering replacing it sometime soon. Can anyone recommend a
good laser printer that could process Pos
Thank You!
Solution #5
Not Rated (0)
Ross
Rating: 0%, 0 votes
Bill,
There are no NETBEUI settings whatsoever on the print server side. Not even a
way to enable/disable NETBEUI support for it. The web management interface has
settings for AppleTalk, TCP/IP, SNMP, IPX, just nothing on NETBEUI. Yet it
does work in Win2K by "creating a network printer port" on the NETBEUI stack.
The print server ends up with an odd queue name, but it's there. If it can be
made to work with NETBEUI on OS/2, I don't know how ...
Thank You!
Solution #6
Not Rated (0)
Melissa
Rating: 0%, 0 votes
Julien:  I'm not sure why the arp setting the IP address failed, but
the print server will remember its IP address after power down by
setting up a tftp session, 'get'ting the config.txt file, editing the
IP address and then 'put'ting it back.
  This particular model also allows setting all of these parms with a
web browser.
  As for the versions, I am running:
   Inetver reports 4.02w
   TCP/IP Stack is 5.12.2 WR08423
Following your advice, I downloaded Serge Sterch's LPR32 but have been
unable to get it to work.  The print queue just shows OffLine, but it
is accessable on the network to other systems.
George Barrowcliff
Thank You!
Solution #7
Not Rated (0)
Luisa_K
Rating: 0%, 0 votes
Try http://www.haynes97.freeserve. co.uk and follow this links to the
LPR page.
Hope this helps.
Colin.
On Sun, 27 Jan 2002 21:38:13 GMT, "GW Barrowcliff"
Thank You!
Solution #8
Not Rated (0)
herself
Rating: 0%, 0 votes
You may need to set the IP address under Windows or DOS or via a
telnet connection to the box depending on what it will accept to make
it address compatible with your network.
Following on that, set it up using the LPR method. You will need to go
to thwe TCPIP setting notebook and enable lprd which must be running
to support LPR.
Regards,
Hugh
On Sun, 27 Jan 2002 21:38:13, "GW Barrowcliff" <Barro @prodigy.net>
Thank You!
Solution #9
Not Rated (0)
Ross
Rating: 0%, 0 votes
Sorry I missed the commencement of this thread.
What is this hardware and where did you find it?
$49.00 (even in US $ from Canadian loonies) is a good deal for a print
server.
Geoff
On Mon, 4 Feb 2002 23:57:24, z @bergenbrunswig.com (George
Thank You!
Solution #10
Not Rated (0)
Reynolds
Rating: 0%, 0 votes
Follow up on my success with the $49 PN7127P Print Server Install.
This model of print server plugs right onto the Centronics connector
on the printer, uses an external power supply and connects to the
network with an RJ45 connection.
After hooking it up, I set the IP address from the command line in
OS2:
1.)  arp -s 192.124.155.203 00:40:01:80:25:DF
2.)  ping 192.124.155.203  [successful]
3.)  followed Colins LPR instructions at
http://www.haynes97.freeserve. co.uk/lpr.htm using lp1 as the printer
name [this is critical]
4.)  This gets object printing on the desktop
5.)  Redirecting LPT1 to this port:
     SPOOL /D:LPT1 /O:HawkingL
Works good, I recommend it.  Easiest and cheapest way to add a
printer.
George Barrowcliff
Thank You!
Solution #11
Not Rated (0)
Peter1
Rating: 0%, 0 votes
Sir:
Fry's had one in that price range when I was there last week to replace
the almost one month old flat pannel monitor with a CRT. :-(  Try their
on-line store.
Bill
Thank You!
Can you Help with these Print Servers problems?
Print Servers
examples of graphs of the fundamental functions and...
Print Servers
I've changed the cartrige and I did remove the tape before...
Print Servers
code sc990
Print Servers
We have the card. What else do we need
Print Servers
When I copy a paper the copy comes out with one third of...
Loading problems.
Repair Service
Find Print Server Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
