SOURCE: White lines & inverted picture at top of CRT TV image
This problem is normally the Vertical filter capacitors. You need to have them changed before it burns out the Vertical Chip.
Good Luck
Ed
NC Electronic
Mills Wyoming
SOURCE: Smeared image
Try removing signal cable and refitting at both ends.
Signal cable also could be faulty.
Samir
SOURCE: Samsung 40 inch LCD LNS4092D No Picture
I had a very similar problem, TV was 1 day old! Samsung engineer came out and replaced the motherboard - all sorted now.
SOURCE: Samsung HPR4252 with red horizontal lines accross the screen
I just had my HP-R4252 repaired on 12.05.09 with a similar problem. The picture is covered in horizonal, broken lines and the color is predominately red. They lines are grouped together in large bands across the screen.
The tech replaced the Y-Buffer boards (Up) and (Low) in about 20 minutes.
Samsung BN96-02034A BOARD, Y BUFFER UPPER ASSY
Samsung BN96-02216A BOARD, Y LOWER BUFFER ASSY
SOURCE: LCD TV has dark smears on picture
This not repairable,it a LCD screen have minor pixels cracks in the LCD screen itself,some body hit the LCD Screen with somethings.
