My student number is 43852831 my cell numbers have change so that i receive my new password and user number
SOURCE: when i receive messages on my i9 the number appears not name
I have the phone and have had the same problem. I found I have to add the "1" before the area code to all the saved contacts or at least the ones you use most and that should fix it... when the text message is received it has the "1" normally we don't save the number that way...
SOURCE: How do you get a telephone number for facebook
Facebook does not offer telephone support. The number for their office is 1 650 543 4800
press line---> someone will answer: 1 650 543 4811
good luck my friend
SOURCE: 2wire 585 forgot password and need 2 config
f you don't know the system password for the twowire it has a factory reset button near the lan ports
* Hold down the reset button on the back for 30+ seconds.
* Upon releasing the reset button, the router resets itself to factory settings.
* Connect a computer to the 2700HG-B and browse to the URL http://192.168.1.254/
* Enter a new password, confirm it and enter a password hint at the bottom of the page, in case you forget the password.
* At this stage you might receive a "Page Not Found" error, but the password appears to be set successfully.
* To continue, manually browse to the url http://192.168.1.254
* Home Page (summary)
* Run System Setup Wizard
* Enter key code 5225 2374 WG62 22AS BJ7P (from http://www.2wire.com/?p=268) to set up manual config
-> Next
Choose TIme Zone -> Next
* Enter ISP set up details
* For most UK ISPs this will be
Connection type = PPPoA
VPI = 0
VCI = 38
ATM Encapsulation = VC-Mux
For Be /O2 users only
VPI = 0
VCI = 101
ATM Encapsulation = LLC
Exit Registration when connected to Internet
If this helps you plese rate and vote
SOURCE: unlock password code samsung b3210
If you have forgot your password or just want to reset your phone follow these steps.
1. Remove your battery (and sim card if your phone has a sim card.)
2. Replace just your battery and power the phone back on.
3. When the phone powers on type in *2767*3855#
Your phone will power off then back on with the out of box settings,
Keep in mind that doing this will also clear any information including contacts and pictures
SOURCE: forgot user name and password need to add new
Just "reset" the Linksys router to its "factory" settings.
This will restore the "default" logon ID and password.
Login to the router, and rerun the "Wireless Networking Setup Wizard", to:
* set an SSID
* set an encryption-level, e.g., 'WPA' or 'WPA2'
* set a password for your network.
