Question about Daewoo Heating & Cooling
How do I program my daewoo silver nano air conditioner to cool? All it does is blink and lets me know what the room temperature is.
bobotfel
  • 236 Answers
SOURCE: Portable Room Air conditioner will not cool
You need to call for for a qualified technician oil residue is a sign that your unit have leaking, your unit is out of refrigerant.
Posted on Dec 31, 2007
  • 50 Answers
SOURCE: Danby Portable Air Conditioner DPAC120068 - room temperature
Maybe, the compressor isn't starting? I'd take it back to where you purchased it.
Posted on May 18, 2008
  • 44 Answers
SOURCE: adjusting thermostat temperature
nope. Try bouncing the air off the ceiling instead of pointing it towards the floor. You know the vent grille should be adjustable. The air is just recirculating back into unit and short cycling stat. Create a barrier between supply and return!
Posted on May 28, 2009
  • 24 Answers
SOURCE: Room temperature reads 95-99 degrees F, not cooling the room
one hose is the heated condensing air and one hose is the intake air. if this unit is not working correctly and u just purchased it take it back. if the landlord will replace it tell them. do not call a service tech to check this unit out if u know 4 sure the temp is set right and it continues to blow hot and the exhaust hose blows outside and the unit is set to cool you are money ahead to replace it. hopefully a landlord or recent purchase can bail you, you can find these units at home depot lowes and get them 4 about 400 dollars. hopefully it's covered somehow by warranty or landlord but the cost for checkout and service will exceed the cost for replacement. have you tried to unplug the unit leave it unplugged and try again. have u cleaned the filter. have you noticed ice anywhere. maybe a light that tells you the drain is plugged i don't wan't to get you're hopes down when you are burning up but check these things and let me know if u see any abnormalities. do you leave the unit running in hopes that you will come home and it works? check for ice is there air blowing constantly? if u dont get air flow you could have a fan thats out or its iced up. let me know.
boysor2933
  • 293 Answers
SOURCE: LG LWHD8000RY6 Air Conditioner Not Cooling Room
Remove the front cover of the unit to expose the cooling coil. Put the unit on and observe if there will be formation of frost (ice) on the coil. If there's frost formation, the common cause is dirty cooling coil. Have it cleaned using an alkali base coil cleaner. If the coil is clean, then the problem is the fan motor. It might be turning slow due to copper loss. Have it replaced.
Posted on May 29, 2009
Why is my portable air conditioner blowing out room temperature air?
Make sure the filter(s) have been cleaned (Washed) and that the thermostat is set to the correct temperature. If the room temp is the same as the setting on the air con, it wont cool or heat. Just the fan will be operating.
Sep 10, 2014 | Heating & Cooling
How do i get my portable haier air conditioner cool off my house below 73
Air conditioners can only drop the temperature of the room temperature a maximum of 15 to 20 degrees F. A 95 degree F room temperature can drop to a maximum temperature of 75 to 80 degrees F. If the room temperature drops from 95 to 85 degrees F, Then the problem is having too small of a btu rating on the air conditioner or refrigerant has leaked out the sealed system which can affect the amount of cooling performance. You will have to buy a higher rated btu rated air conditioner if the temperature of the room drops by only 10 degrees F. Air conditioners are rated by how much heat that can be removed each hour. The more humid it is, the more work an air conditioner has to do. They cannot do more work than the btu rating that is listed on each air conditioner.
May 26, 2014 | Haier Heating & Cooling
The air conditioner cools the room but it shuts of. The power light doesn't come on while unit is on. Can I replace the plug?
"The air conditioner cools the room but it shuts of." -- Temperature reached, but does not turn back on automatically? Stops short of reaching temperature? Shuts off for a period, but will come back on only to shut off again later?
Most importantly, how do you get it to turn on again?
"The power light doesn't come on while unit is on." -- If the unit is on and the power light is not, then the power light must not be operating (is burnt out).
Actual answer: "Can I replace the plug?" -- Of course you can.
What is causing you to feel that the plug needs replaced?
:o).
Jun 04, 2011 | Daewoo DWC-056CL Air Conditioner
Daewoo dbs-182lh starts and stops by itself.
If it's cooling to the temperature that you have it set for or the comfort level you have it set for, it's normal for it to cut off, once it reaches that temperature and holds it for 5 minutes. When the room temperature rises above the comfort level you have it set for, it turns back on. If this is what you are describing, it's functioning normally.
Apr 01, 2011 | Daewoo Heating & Cooling
I have a DaewooDC Nano silver Mod.# DWC060CL I need The side panels and Thermostat Dial Where can I get/order them?
ring castel electronics on 03 9484 3788 and order parts.they import daewoo into australia
Feb 08, 2011 | Daewoo Heating & Cooling
I have an LG AC and the lowest temperature setting is 60 degrees
Lowering the temperature setting doesn't change the temperature of the air coming out of the unit it just lets it run until the room temperature gets colder. Check the temp of the air coming out of the unit. If it isn't as cold as it used to be the charge could be low. First though you should make sure the filters are clean and the coils.You should also check the actual room temp. It's also possible the unit doesn't have enough capacity to keep up with the cooling load of the room.
May 02, 2010 | LG Heat cool Window Air Conditioner
Frigidare window air conditioner with remote control about 3 yrs old. All controls seem to be working except when the energy saver mode is suppose to shut down the unit / the display goes dark but the...
Hello, I can assist you.
If the unit is supposed to turn off and it doesn't, it will be necessary to check several things.
  • First, is the unit cooling properly? See the section entitled "The air is cool but doesn't seem cold enough."
  • Next, is the temperature of the room adequately cool? If the room temperature is cold enough try setting the thermostat to a higher temperature. If the unit then seems to work properly leave the thermostat set to the higher temperature.
  • If the unit is cooling properly when it is turned on and the room is not cool enough the problem is probably that the unit is trying to cool an area that is too large for its capacity. Use the following chart to find the appropriate size air conditioner to use:
AREA TO BE COOLED / CAPACITY (BTU/HR)
100 to 150 square feet = 5,000
150 to 250 square feet = 6,000
250 to 300 square feet = 7,000
300 to 350 square feet = 8,000
350 to 400 square feet = 9,000
400 to 450 square feet = 10,000
450 to 550 square feet = 12,000
550 to 700 square feet = 14,000
700 to 1000 square feet = 18,000
If the room is heavily shaded, reduce needed capacity by 10%
If the room receives a lot of direct sun, increase needed capacity by 10%
Add 600 Btu/Hr for each person in the room if there are more than two people
If the unit is for a kitchen, increase the capacity by 4,000-6,000 Btu/Hr.
If the room size is too big for the air conditioner you have two possible choices. Either decrease the room size by shutting some doors or partitioning off an area of the room. Or, increase the BTU of the air conditioner for that room by installing a different air conditioner with a higher BTU rating.
Aug 02, 2009 | Heating & Cooling
Haier room air conditioner doesn't cool maximally at "Hi AC"
You should have at least 5,500 BTU's for that size room. Clean the filter. Turn it on and let it work for a few hours.
Aug 02, 2009 | Haier hwr10xc6 Air Conditioner
Daewoo airconditioner doc-9rh
One sure way to tell if your unit is doing what it is suppose to is using the box temperature method. Meaning inside the space your house and the supply coming from a/c. Take the temperature of the space take the temperature coming from the supply vents. Should be a difference of 18 to 22 degree's. Example the house is 75 F degree's the supply should be 55 degree's. Now if it is coming out 60 or 62 then you have a overcharged a/c and need to adjust the pressure's. It is a very fine line to get it perfect only a tech. guy could do that. Let me know how it goes. ken
Feb 07, 2009 | Daewoo DWC063R Air Conditioner
Thank you. there are some other signs i don't know about.
The black triangle means AUTO, means the fan speed adjust by itself from high-mid-low speed depending in room temperature but the unit is cooling for this function the same COOL mode. Plasma is in the remote control but it never mention in the manual.
If the unit dont cool check your temperature setting and mode setting it should be in cool mode and temperature setting should be 18C. But if still don't cool check some error code like blinking light at the indoor panel check how many blink appears to get the correct error code.. If the light is blinking 3 times it means that the room air or coil sensor is defective.
abc4048.jpg.
Apr 28, 2008 | LG LSC121PMA Split System Air Conditioner
Heating & Cooling Logo
419 people viewed this question
Top Daewoo Heating & Cooling Experts
Tim Whalen
Craig Hill
Steve
Are you a Daewoo Heating and Cooling Expert? Answer questions, earn points and help others
