Question about HP Pavillion dv9740us Notebook
Monitor will not turn on
Used laptop this afternoon. Shut it before completely logging off. Now trying to use & lights come on, but monitor will not come on. Tried turning off & on again, and still no response from monitor.
It was working fine this afternoon before I closed it
  • loricoggins Jul 27, 2009
    This did not work. The monitor is completely "dead". Nothing at all comes on it. Only the lights indicating the computer is on & I can hear it coming on, but no activity on the monitor.
    Sergeant:
  • 173 Answers
First check your num lock key on key bord if it is on off when you press num lick key then your dispaly is working fine means you need to change screen resolution.
For that when you power up the computer press F8 key then enter in enable vga mode.then go to display property and change screen resolution to 1024*768 or 800 *600.
Also when you power up the computer press F1 or F2 or 'del" key to enter in bios then load optimal defaults also check your harddisk is detected .Disable your satat option in bios .then save settings then check.
I f you not able to enter in bios then Refix your ram.If still face problem you need to reset bios .
For that you have to open laptop cover in back then pull cmos cell from mother bord for 5 minutes then refix it then check.
Posted on Jul 27, 2009
  • Amit Jul 27, 2009
    If it is in warrenty it is good advice to take it to service shop they replaced it free.
    or if it is not in warrenty take it to any repair man
I was on Facebook this afternoon and shut down the computer. Returned at 6 PM and couldn't get into Facebook. Message was Navigation was canceled. I also tried logging in on my laptop and got the same
Contact Zynga games through facebook. They will help you get restored. In the meantime while you wait make sure that you adobe flash player is up to date as well as your Java. Both are needed for words with friends.
Oct 15, 2014 | Computers & Internet
Not true colors and now complete blue screen
contact the vendor and get it repaired .... or try changing the vga cable
Mar 31, 2014 | KDS Radius Computers & Internet
Dell Studio 1558 - No post/boot
maybe is the hard disk... u must try to log in with a live usb linux (or windows or hirens boot cd ) and watch if it logs.. if u want to check fan if its covered of dust ill let u a link of how to open it http://www.youtube.com/watch?v=Hn_RX56oGqI
Feb 28, 2013 | Dell Studio 1558 Notebook
If i am on the phone when the monitor is running I get a loud bizz on the phone, this only happens when the monitor is on.
This may not be an absolute fix but your monitor is connected to the PC, so you may be getting some type of feed from the PC through the graphics part of the system which only becomes prevalent when the circuit of the graphics signal is completed with the monitor on.
Is you system grounded?
How about your system not being shut off for long time. Are you the type to just leave it on and just log off instead of turning off?
Try turning off both the PC & the monitor, and unplugging them for about 10 minutes, While they are unplugged, push the power switches on/off a couple of times to discharge any kind of residual charge in the capacitors. I know with my tower PC if I unplug it then later hit the power switch, the red power & green hard drive light would come on for a split second.
DRAIN any kind of charge in them and be sure they are grounded good to each other as well as the buildings ground.
Sep 27, 2010 | X2Gen MG19MY 19" LCD Monitor
My notebook Asus W7J BLANK when is turn on
Screen not working
are you able to hear the windows log in?
if you do but no image, most likelly your video card is ruined. overheated or dropped maybe? don't worry is bad but not that bad, there is a way to fix that by a professional.
take it to a computer repair shop and have them check the video card ask if they have a rework station or someone who may. they have to unsolder about 50 pins at the same time get a new card and solder it again.
sometimes they apply heat to it and it will work again but for just a few days maybe weeks but it goes bad again. so replacement is the best option.
I used to charge about 200 bucks but you may be able to ask for a rebate.
do not take it to a major computer store they would tell you there is no repair so you can go in and get a new computer
May 30, 2010 | ASUS W7J Notebook
Laptop is on but Monitor is off...was working fine earlier today. Opened back to change memory card. Turned laptop back on and the monitor did not light up. Tried checking cables, turned laptop off and...
connect external Display and check if working.
Circle through main display > Main dsply + extnl Dsply > external Dsply using the appropriate Fn key combination (Fn+F4 on my HP).
If only external dsply is working check every connection you possibly affected or bring to a repair shop.
Aug 02, 2009 | HP Computers & Internet
Blank Screen on HP Laptop
HP has identified a issue with the DV6000Z and monitor. I just reported the same problem to HP and even though off warranty, they will fix free. Power up of DV6000Z you will get 3 beeps and no monitor display. External monitor does not work either. This is a known issue woth the DV6000Z.
May 06, 2008 | HP Pavilion dv6000z Notebook
HP Pavillion dv9740us Notebook Logo
127 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
