Question about IBM Lenovo ThinkCentre M55e PC Desktop
Boot sequence problem while booting
Boot sequence problem in IBM lenova and IBM desktop systems.After shutdown and restarted the system it is showing some error while booting.we entered the BIOS changed the boot sequence it is working in couple of days.This is the frequent problem in IBM PCs.any permenant solution for this problem?
    Sergeant:
  • 173 Answers
Your mocs cell waltage goes down.
CMOS cell gives power to bios flash memory when it goes to low bios forgot settings after power off.
So purchase new CMOS cell it is on motherbord change it then save settings then it not forgot settings even after power off.
Thanks for using fixya.
Posted on Jul 27, 2009
Why does my computer on bootup ask for system password then locks up too many attempts?
If you mean Bios password try this:
Resetting the BIOS PSSWRD, Open the computer case and look inside on the motherboard. Dell has diagrams of this. Locate the Little Jumper. It should have small print if you can read on the mother board indicating PSSWRD CLR. Boot the computer to Setup. Carefully remove jumper, becareful of static, and then once removed hit enter. Shutdown the computer, and restart and enter Setup again F2. The password should be CLR. Turn OFF and PUT Jumper back into place and Turn Back ON. You should be able to access Setup.
If you then boot to setup-check your hard drives and floppy that are seen. You may solve those issues in setup.
If you mean the windows password: boot to F8 safe mode and log
on to the ADMINISTRATOR not your log in that has admin rights.
Disable all passwords and restart.
Aug 16, 2014 | Dell Dimension 4600 PC Desktop
Change boot cd rom bios300
Your IBM 300 series desktop computer is normally set to boot its operating system directly from the installed hard disk drive.
There are some cases where you may want to boot from a different device, such as loading from the floppy drive to install a new operating system.
In order to change the boot order on the IBM computer you need to access the Basic Input Output System (BIOS) menu.
Close any applications that are still running.
Turn off the IBM 300PI computer and then turn it back on again.
Tap the "F1" key when the "Configuration/Setup Utility" prompt appears at the bottom of the screen.
Tap the down arrow key four times to highlight the "Start Options" entry.
Press the Enter key.
Highlight the "Startup Sequence" entry and then press Enter again.
Scroll down and highlight "First Startup Device."
Press Enter. Scroll through the list of available boot order devices.
Highlight the device you want to use, such as "CD Drive" or "Floppy Drive," and press Enter.
Press the "Escape" key twice.
Highlight "Save Settings" and then tap Enter.
Power off the IBM computer and then power it back on.
May 06, 2013 | IBM 300PL (PC 300 PL 733) PC Desktop
How set boot sequence for ibm mother board
Restart your computer
During the boot process you will see on the screen for a very short time to press a certain key to enter setup usually the Delete or F2 key the F1 key for IBM PC 300GL
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
or this will set the boot order
the using arrow keys navigate to advanced bios features press enter change which drive you want to boot from
hope this helps
Sep 06, 2012 | Microsoft Windows XP Professional
How can i change boot sequence of my desktop
You have to change the boot order at the bios settings. Just after the screen comes up, before windows start up press (repeatly) the F2 key (depending on the model, maybe F1 or del key) and go to the boot sequence. Here change the boot order as you wish.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Mar 15, 2011 | IBM Lenovo ThinkCentre M55e PC Desktop
Ibm not boot from usb
When the system starts up there is usually a key to hit for SETUP, usually ESC, F1, F4, or DEL
Find it, and hit it at the right time.
You will enter the CMOS or BIOS setup.
Once there, locate the BOOT SEQUENCE section and allow a USB boot or external component Boot to be placed int he sequence it it MIGHT work.
Not sure what you're trying to boot from USB for.
Oct 19, 2009 | IBM NetVista M42 PC Desktop
Ibm netvista trying to boot from a non-existant lan system.
With my netvista I was able to get boot options with F12 when powering up. I don't know if this will help you because I was installing a new hard drive. Larry
Mar 06, 2009 | IBM NetVista A40 PC Desktop
TO CHANGE THE BOOT SEQUENCE FROM HARD DISK TO CD
before you see the logo screen when you boot up, you should see press f1, or delete to go to system settings etc, thats where you change the boot sequence
Jan 19, 2009 | IBM ThinkCentre M50 PC Desktop
Steps to configure system boot sequence
try to slave your hardisk to another computer, perform a scandisk with it, and if the scandisk completes then your hardisk is just ok, format it using windows xp bootable disk
Jan 14, 2009 | IBM Lenovo ThinkCentre M55e PC Desktop
Restarting while formatting
Hi, try to check your pc's cmos setup on boot sequence, you would be needing to set the sequence to boot the system on CD drive first then your hardrive; then disable boot virus protection - this will make your OS installation with no interruption. Then save your cmos changes. you have to put your operating system program installer on your cd drive then watch the message to boot from your cd drive. hope this helps.
Dec 19, 2008 | HP Compaq Business Desktop dx2200 - P4 524...
IBM Lenovo ThinkCentre M55e  PC Desktop Logo
731 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
