Question about IBM ThinkPad T60 Notebook
Power Button wont do anything
My T60 machine was working fine last night, when i started it today the screen went blank. The fan is on and light is also on with a circle and Z, is it on sleep! the small light at right side also wont start. please help me as i have tried removing the battery, restarting and also waiting fr almost 1 hour
  • tech_shekhar Oct 13, 2009
    how to refix the key on keyboard of compaq presario cq60 laptop?
    Sergeant:
  • 173 Answers
First check your num lock key on key bord if it is on off when you press num lick key then your dispaly is working fine means you need to change screen resolution.
For that when you power up the computer press F8 key then enter in enable vga mode.then go to display property and change screen resolution to 1024*768 or 800 *600.
Also when you power up the computer press F1 or F2 or 'del" key to enter in bios then load optimal defaults also check your harddisk is detected .Disable your satat option in bios .then save settings then check.
I f you not able to enter in bios then Refix your ram.If still face problem you need to reset bios .
For that you have to open laptop cover in back then pull cmos cell from mother bord for 5 minutes then refix it then check.
Posted on Jul 27, 2009
I turn on my Mitsubishi WD-73833 TV and it turns itself off
Lessing of brightness on a DLP set is a sign of imminent bulb failure.
A new bulb is in order.
Nov 23, 2013 | Mitsubishi WD-73833 73" HDTV
I turned my smart book on today and it came on then went blank
try rebooting in safe mode and do a restore if that doesn't work probably going to have to reinstall your OS,,, if it does let you in run scan disk under properties by right clicking on hard drive under my computer. if any of this works make sure your anti virus is up to date
Nov 01, 2012 | Sylvania Synet7wic-bk-z2 Netbook
My HP DV5 1159se was working fine last night and then this morning I go to turn it on as usual and a blank white screen comes up. The start tones are the same and I could even type my password in to log on...
If the inverter board or the back light behind the screen were bad your display would be blank, "but windows would be visible barely" the white screen indicates a bad LCD and must be changed. It is also possible the video cable from the motherboard to the screen has come loose and will need to be reseated back into place to fix it.
Mar 23, 2011 | HP Pavilion dv5-1159se Laptop
Toshiba regza 47" flat screen last night i was
Check your power cable. Unplug it from both ends and plug it back in
Mar 05, 2011 | Toshiba REGZA 47HL167 TV
Blank screen although power light on and fan running.
Please force shut down the unit if it still is on. Then, press the power button and see if it starts up.
If that doesn't work, then please disconnect everything from the unit (Battery and A/C) and Reseat the RAM and recheck.
May 22, 2010 | Acer TravelMate 2300 Notebook
Screen went blank and orange light is on
fiona_sheeha, If ACER warranty service not an option, then unit will need local tech to troubleshoot unit's power supply/inverter circuit for possible COMMON and repairable printed circuit board fix. You must read more of my fixya profile and visit the web links you find there so you will know and understand what ALL your options are!!! Some units require less than $5 in parts to refurbish them to working status. Your "cold-cathode-fluorescent-lamp" backlit LCD monitor isn't any different than any other brand of monitor in it's basic operating principles!! I hope this helps. 12fixlouie
Dec 30, 2009 | Acer AL1916W 19" LCD Monitor
The input function is not working and the t.v. is on but no picture. Blank screen. Was working last night just fine we tried to hook up Xbox and when the input button was pressed screen went blank. any...
Perform Reset From Front panel of Tv, wait until green light stops blinking, set is running self diagnostic. If that doesn't work, it could be something in the DMD Panel containing the Digital Micromirror Device
Oct 10, 2009 | Mitsubishi Diamond WD-65831 65" Projection...
Emachine wont start up
nope..that's not an issue...is the power button showing a solid color, if applicable?
Feb 20, 2008 | E-Machines (T2958) PC Desktop
LAPTOP WONT TURN ON OR DO ANYTHING
Remove all the cables etc inc the power lead
Remove the battery
Hold the power button down for 20 seconds
Replace battery & Re-start. If you are as lucky as me it will be 'Hey-Presto' and lots of happiness.
Dec 03, 2007 | Computers & Internet
No picture on screen
MYGR8-YOU HAVE TO LIST BRAND NAME AND MODEL #. JOE TV
Nov 30, 2007 | Televison & Video
IBM ThinkPad T60 Notebook Logo
282 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
