Question about GE JD900WK / JD900CK / JD900BK Electric Kitchen Range
Was useing the oven and then everything stopped
Was using the oven and then everything stopped working - No Display or anything?? Thought it was a Main fuse as everything went off. But the fuse was not the issue. When I turn on a Burner it does not heat up - But the display will come back on - until I turn off the burner again. there seems to be a Hum or a slight vibration when I turn on the Burner??
What is going on??
  • 145 Answers
Sounds like a house wiring problem or terminal block on the back of the unit. You seem to only have 110 volts to the unit. One of our connections may have burnt.(the clock thing I have seen many times, it is feedback.) Unplug the unit and check the wires from the unit and and to the house.
jim
Posted on Jul 27, 2009
Can you diagnose the fault & advise me how to fix my hotpoint electric cooker please?
This video shows how to test and replace the faulty heater element on the fan oven on a Hotpoint double oven.
Sep 26, 2015 | Hotpoint Ovens
Microwave not heating anything? everything else work
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fgshg
Jul 28, 2010 | LG LMH1517 1000 Watts Convection /...
Turntable stopped working
Most of these are belt driven. You need to uncase the unit and check the belt.
Like anything with high voltage, use good safety practices.
Dec 15, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
No Heat but everything else works
Magnetron and diode most likely. Need more info.
Nov 02, 2009 | GE XL1800 1100 Watts Microwave Oven
Oven shows stop on display and cant be used
I don't have a solution but a thought. Sometimes the main circuit board can be corrupted during a power surge or outage. You may need to have the circuit board re-set by a professional tech or replace it. Can you try going to the breaker box/pannel and flipping the breaker off for about 30min. to let the circuit board re-set. If that doesn't work then see if someone else has any suggestions or call a tech.
Apr 26, 2009 | Kitchen Ranges
Westinghouse Freestyle 668 oven not doing anything , just blinkin
Yes I can help.Hold down the buttoms on the far left at the same and then set the time using the + and - buttons.Cheers
Apr 20, 2009 | Ovens
Power outage issue
You unit is stuck in the "Display Model Mode". Hold the stop/clear button for at lest five seconds in insure the interlock activates. If it does not activate then the electronic range control (erc) is not functioning. Replace the erc (Clock/Display.)
Jan 10, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Sanyo Super Showerwave out!
Sounds like a bad connection inside. unplug the power, take off the cover, look over all the connectors closely.
Dec 31, 2007 | Hotpoint RVM1435 Microwave Oven
Oven is not working
Both elements are controlled by a common relay on the ERC (Electronic Control Card) and cannot be repaired. The ERC needs replaced. This is also referred to as the Clock/Display.
Aug 17, 2007 | KitchenAid KESC300 Electric Kitchen Range
Kitchen Ranges Logo
66 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
