Question about Panasonic BL-C1 Network Camera
Diver problem - Panasonic BL-C1 Network Camera
  • jitendra singh
    jitendra singh May 11, 2010
    give the model number and name of your product i will help you
  • 64 Answers
How to set?& manual required invicta.15343 pro dive
Invicta Pro Diver - View model
invictawatch.com/collections/view-model/15342-pro-diver
INVICTA COLLECTIONS click to view models · AKULA ... Instruction Manual Print. More models of the same style. 15343. Invicta Pro Diver · share watch. 15341.
Sep 25, 2015 | Watches
Tip
The Rapid Diver System
Lightweight Scuba System Goes From Tactical to Practical
RAPID DIVER™ is a lightweight, all-inclusive scuba system that mates a tank, regulator and buoyancy module to a uniform-fit, load-bearing harness. It was created in response to public safety and military needs for a universal fit, compact, versatile and easily deployed scuba system.
Mission requirements called for a system that is universal fit, could be stored in a small space, donned and activated quickly, and worn in situations such as helicopter and boat operations in which conventional scuba gear would prove too cumbersome and restrictive. Comfort was also of great importance, as some operations would require the user to wear the gear for extended periods of time while engaged in complex, task-loaded missions. With an overall weight of just 25 pounds, the Rapid Diver stores in a compact hand-carried pouch, and readies for use in less than a minute. It provides sufficient air duration for the average dive a 20 to 25 minutes at moderate depths. The Rapid Diver can go from duffel to dive in 15 seconds.
Though designed for professional use, many of the Rapid Diver's performance characteristics make it equally suited to a range of civilian applications. It is the preferred system for shore diving, due to its user-friendly design, universal fit capability and ease of transporting and storage. Persons who are unable to wear heavy conventional scuba gear, or who simply feel uncomfortable with the associated bulk and weight, appreciate the light overall weight and wearer comfort of Rapid Diver. In addition to a low overall weight, the Rapid Diver features a unique load-bearing harness that distributes the weight of the tank evenly over the diver's torso, making it well suited for difficult shore entries and is also beneficial for long walks to the water or water entry from ladders or small boats. Rapid Diver's small size allows it to be stowed aboard a boat, where it can be deployed for underwater boat maintenance, anchor checks, and fast response to emergencies such as a fouled prop or suspected hull damage.
Also unique to the Rapid Diver system is the ability to configure the rig for a wide variety of mission profiles. In it's simplest form, the Rapid Diver can be configured to become a PFD by removing the tank and life support system, beneficial in most boat operations (Tactical Swimmers Vest TSV). For extended dive profiles, the Rapid Diver can be configured with standard sized tanks (80 cu ft) mounted on the innovative back pad. If mission requirements call for an even longer diving profile, the Rapid Diver can be used in conjunction with surface supplied air or in a traditional side mount configuration. Other custom-configurable gas management options allow the user to configure the rig with a redundant air supply, and to use full-face scuba masks in conjunction with a gas switching block. To extend duration and stealth, a rebreather module which clips onto the existing Rapid Diver Tactical is in the works and will be made available for military applications.
Rapid Diver is a premium product and was created by dive equipment developer and long time diver, Christopher De Felice. The Rapid Diver is manufactured in the United States, constructed using materials selected for extreme durability and wear resistance.
For the latest information about the Rapid Diver system come and join us at the Official Rapid Diver Forum:
rapiddiver.board-directory.com
www.RapidDiver.com
on Jul 08, 2009 | Zeagle Rapid Diver System - Buoyancy...
A diver swims horizontally 8 m below the water surface how much pressure acts on his back?
given: h=8m
row=1025kg/m^3
=75cm Hg
dHg=13,600kg/m^3
g-9.8 N/kg
P=8mx1025kg/m^3x9.8N/kg and then cancelled kg
P=8,200N/m^3
P=8,200Pascal (Pa)
Aug 03, 2011 | Eagle Medallion Cars & Trucks
Diver problem
> diver problem
Is your diver using a mix of compressed nitrogen and oxygen, or pure oxygen?
How deep are they diving? How long do they stay at depth?
Do you have a decompression chamber?
Or, are you looking to hire a diver?
How much per hour are you willing to pay the diver?
Nov 13, 2010 | Computers & Internet
What is the dial around the crown?
mcdevito75 here, That dial is used mainly on Divers watches for Divers, by setting this dial, you can tell how much air time tanks that divers use have in them. It"s main purpose though is to hold the crystal asssembly to the watch case. A specialized manual can tell how to use this outer dial, it can be used as a measure of distance and time.
Jul 21, 2010 | Invicta Terra Military "Lefty" Chronograph...
Looking for Neoprene Valve US Divers Mask
They're not available separately on cheap masks like US Divers.
You'll have to either fabricate a new valve yourself perhaps using a piece of bicycle inner tube or permanently block your current one (purge the mask by lifting the lower skirt instead) if you wish to avoid purchasing a complete new mask.
Sep 27, 2009 | U.S. Divers Scuba Diving & Snorkeling
How and why scuba gauges give a diver critical information while scuba diving?
Scuba gauges give a diver three very important pieces of information: 1. Time 2. Depth 3. Air Consumption This information enables a diver to stay within safe time and depth limits and avoid running out of air. There are many different devices on the market to help with this, from simple gauges to complex digital consoles. Time If a diver is not using a dive computer to monitor their nitrogen, they dive according to approved dive tables. To use dive tables properly, a diver needs to track their downtime. This can be done with a good dive watch. Two things make a good dive watch: water resistance and a rotating bezel. 1. Water Resistance. Good dive watches are rated to a depth in meters or feet (e.g. 200 feet) or a pressure rating in atmospheres (e.g. 4atm). Even though most divers probably won’t dive below 130 feet (the recreational dive limit), a good dive watch should be rated to 200 feet. Note: There is a difference between “water resistance” and “waterproof”. A “waterproof” watch is what you would wear in the shower, but would probably start leaking at 15-20 feet. 2. Rotating Bezel. A bezel is an adjustable ring on the face of the dive watch with a pointer indicator. At the beginning of a dive, the pointer on the bezel is aligned with the minute hand where it stays though out the dive. At the end of the dive, you compare the difference between the bezel and the minute hand to find out the length of the dive. The bezel should only move “counterclockwise”. It is possible to accidently move the bezel during a dive. Because of this, watchmakers make sure any accidental movement will turn the time in a conservative direction, making the dive longer rather than shorter. Depth Another important part of scuba gauges is a depth gauge. A depth gauge enables a diver to keep track of their depth even if they cannot see the water’s surface. Gauges can be either an analog (needle-and-dial) device or a digital device. Both work in the same way. They measure the surrounding water pressure and convert this into an accurate reading of your depth. Another feature of a good depth gauge is a maximum depth indicator. This tells a diver their maximum during a dive and must be reset after each dive. Air Consumption Another equally important part of scuba gauges is a submersible pressure gauge (SPG). This is connected to the first stage with a high-pressure hose and measures the pressure of the air in the tank. The SPG is much like the gas gauge on a car. At the beginning of a dive, a diver starts with a full tank. This should be about 3000 psi or 200 bars. As the diver breathes during the dive, the gauge will move slowly downwards. This allows the diver to have enough air left in the tank to: 1. Make a slow, safe ascent 2. Make any necessary decompression stops 3. Inflate their BCD once at the surface 4. Breath from the regulator if the surface conditions are rough A submersible pressure gauge also allows a diver to stop diving with air still in the tank. This keeps contaminants from entering the tank due to no air pressure. Wrist Depth Gauge Scuba gauges come in two basic styles. Stand alone gauges or gauge consoles. Stand alone gauges such as a wrist mounted depth gauge or a submersible pressure gauge attached to the first stage of a regulator are great backups when using digital gauges. Gauge consoles allow divers to have all their gauges in one place. Although less easy to read, analog gauges sometimes give slightly more accurate readings than digital gauges, particularly at shallow depth. Submersible Pressure Gauge Choosing Scuba Gauges When choosing scuba gauges, remember to look for: 1. Easy-to-read numbers 2. Luminescent dial or back lighting options 3. Rotating/swivel mounting 4. Easy disassembly for cleaning or replacing parts 5. Good warranty
Dec 01, 2008 | Aeris Max Depth Analog 2 Gauge Console
Invicta pro diver strap length
ur supose to leave that one open and the rest u can tightin
Jun 10, 2008 | Invicta Pro Diver 9321 Wrist Watch
Panasonic BL-C1 Network Camera Logo
189 people viewed this question
Top Panasonic Computers & Internet Experts
micky dee
Computer Repairing
Computer Repairing
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
