SOURCE: loose stitches every 1
test it out on 2 pieces of material by rotating the wheele by hand. pay close attention to the 1" area. when you turn it by hand you can feel the area of question. is your bobbin spooled correctly. if all fails read the directions.
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
SOURCE: How do I change the stiches?
You can do all of these stitches by using different combinations of your stitch selector, stitch width and stitch feed knobs, for instance, on the panel I can see on your machine:
http://www.jo-ann.com/joann/product/images/52659.jsp?CATID=cat3122&PRODID=prd11333
Stitches 1, 2 & 3 are straight stitches, centered, left and right. Really basic stuff, not different stitches at all. 4,5,6,7 & 8 are zig-zag stitches of different widths. 9 is the widest zig-zag (no. 8) on a finer stitch length, etc...
I think you should try and get an instruction manual for your machine. After a lengthy search of my usual manual sources, I've determined that that this may not be so easy. I think you should contact White on their 800 number and let them try and help you... 1-800-331-3164.
If you found this helpful, please vote generously as I receive nothing other than acknowledgement for my time.
SOURCE: needle stuck in right position, will only sew tiny,tiny stitches
oil it. down the shaft if you can get to it. and where ever there is a hole it always helps.
SOURCE: I was using a basting stitch and sewing along and
Hi this is a common problem with Berninas 930 - 1630. The problem is that there is a small pin that electromagnetically engages and disengages the needlebar when in basting stitch. If the basting stitch is not used much (or ever) the oil will harden or dirt will get in it and cause the small pin to stick. Therefore the needlebar will not engage. Possibly by softening it up with a blowdryer in the needlebar area (the slot in front) and tapping it etc. it might free up. Otherwise it jneeds to have a tech look at it. Its 50/50 whether it can be freed up from the outside. If a tech has to go to the inside and take it apart and clean it it could be more expensive. I always tell people to excersize their basting stitch. Use it or lose it. I hope yours will free up easilly. Time to have it serviced maybe. Good luck.
Rick
Bernina tech
