Question about Microsoft Windows XP Professional
Win xp fils missing. how to re install - Microsoft Windows XP Professional
  • 3,267 Answers
Run your bootable OS CD and then run the option of repairing the existing OS. All the original files will be replaced with the correct system files and you should get the same looks as it was, originally...................sodeep
Posted on Jul 27, 2009
Dell bootmgr is missing
Most likely cause is that the boot order in the BIOS is set up for the HDD first. When turning on the unit, press the key needed to enter setup. Once in setup, search thru the menus for the boot order. Choose the CD drive as the first boot device, then the hard drive as second. Save and exit the setup. When rebooting, ensure the WIN XP CD is in the drive. When the screen says, "press any key to boot from CD", press a key and the WIN XO CD should take over and start the install. Once WIN XP starts installing, follow directions. On each restart after that, DO NOT press the key to boot from CD. WIN XP setup will handle everything until the reinstall is complete. After you are done, you may choose to go back to setup and change the boot order back, but it is not really necessary. The only time you will get the "press and key to boot from CD" message is when there is a bootable CD/DVD installed in the drive. Otherwise, it overlooks it and goes to the next boot device (HDD).
Sep 07, 2014 | Dell Inspiron 2600 Notebook
Boot mgr missing
Have you tried hitting F8 while powering the unit up and selecting "last known configuration"?
If that did not work, do a repair. I am assuming this is XP:
XP repair
When you boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your Applications or data; it just reinstalls the Windows files. This is great because when it works you don't need to reinstall all your software.
If it is not XP, let me know.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 14, 2009 | E-Machines (T2958) PC Desktop
Bootmgr is missing
Run a Chkdsk:
Take the Windows XP disk. Boot from it, then DO NOT select F2 (automated system recovery) but continue through the procedure until you get to the point where you can choose between installing Windows XP and entering the Recovery Console. Once you get into the Recovery Console, do chkdsk and fix potential errors on your disks! Chkdsk C: /R
OR:
Perform an XP repair:
Thanks, Joe
May 07, 2009 | Gateway MT3705 Notebook
Heat sync fan stopped working
Did you replace the fan?
Is it XP:
If so do a repair on XP:
XP repair
Thanks, Joe
Mar 08, 2009 | Computers & Internet
NTLDR missing
In XP, you can load your XP cd and do a repair:
When you boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your applications, it just re-installs the Windows files. This is great because when it works you don't need to reinstall all your software.
In Vista , it is tricky. Let me know.
Thanks, Joe
Nov 02, 2008 | E-Machines eMachines Desktop PC
Missing or corrupt win/sys32/config/ sys file
The best thing to do is borrow a Win XP cd from a friend and do the following:
When you boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your applications, it just re installs the Windows files. This is great because when it works and you don't need to reinstall all your software.
Thanks, Joe
Oct 13, 2008 | Computers & Internet
Missing dll since XP sp3 has been installed
It means : SP3 introduced a new wireless lan application programming interface (windows program that interacts with your wireless card/device driver)
solution : check your wireless device or computer manufacturer for updated (works with SP3) driver.
Aug 28, 2008 | D-Link AirPlus DI-524 Wireless Router
Installing win xp from external hard drive
Umm...is your laptop crashed??? Usually ntlldr issues ****. try to delete the former installation so a new ntldr file can be installed so as to not conflict with the damaged ntldr file that is on the pc blocking the install. It sounds like your setup is ok...at the very least get another xp cd to make sure the disk is not damaged that you are loading windows from.
Aug 01, 2008 | Computers & Internet
Medion pc keeps rebooting just as starting to load win xp home
Sir your useing windows xp os ok your Probalm finaly turns off & reboot some .dll fils are missing so your install new software for your pc ok by .
Mar 15, 2008 | Medion MD-1704 PC Desktop
Missing hard drive space
Simple problem you made the partions using FAT 16 file system and 80 GB cannot be partition using win98 10 will limit the disk to 10 GB.
Remove all Partions And Use Windows XP to create partition during Installion.
Fix Ya
Best Of LUCK.
Jan 07, 2008 | Computers & Internet
Microsoft Windows XP Professional Logo
70 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
