I have a trane 1000 1997, I try to turn it on at the wall but nothing happens. I have looked for fuses in the independent power box put can't find anything.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,810 Answers
Check the basement and look over your lines to see if there is a kink or break in them there is a low preasure switch if coolant too low it will not allow the unit to start to avoid damage or over heat
Posted on Jul 27, 2009
Power outage happened now power is on and no power to mr, slim .. main unit and wall mount no power ,, fuse box has no tripped fuses
Check the disconnect at the outside unit, little box on the wall. If not, turn power off and remove top to outdoor unit.
Apr 15, 2017 | Heating & Cooling
Nothing happens when I push the power button on the front panel of NAD917 Preamp. Any idea why? Is there a way to reset the box?
Probably a fuse in the unit. Unplug it and open it. If you see a blown fuse, take it out and look at the writing on the metal part. buy a fuse with the same power ratings.
Apr 11, 2016 | NAD Audio Players & Recorders
Hi :) I have the Trane Furnace that just turn on
on older tranes if 120v power is reversed it would do that try switching leads on pigtail to board. make sure to unplug first!
Oct 31, 2013 | American Standard Trane Ge Gas Furnace...
Sharp Aquos lc52d77x went to turn it on and nothing happened there is nothing wrong with the power cable or the fuses
it maybe the main board fuse has blow. check that and also look for capacitors with damaged tops (rounded) the will need to be changed to. after full check try to turn on again. if comes on. then turn off and put the back, back on
Oct 02, 2013 | Televison & Video
I have absolutely No Power To My76 Chevy Custom Deluxe.no Lights Wont Crank..does Nothing Fuses Good Battery Is Charged ..what Could It B
Check your "GROUNDS" first. Or you could try this. Under the hood you will find another fuse box with non-typical looking fuses. I believe there is a main fuse in this box. The box itself is probably located on either side-wall, (over the fender) should have a plastic cover over it. I would pull this cover off and look for the "main" fuse and pull it. if you have a light-tester or a multi-meter, check if you have power to here. I have to run for now good luck. 1976 huh? Cool Van-man!!!
Sep 18, 2013 | Cars & Trucks
2001 suzuki gsxr 600 ignition problems
Sounds like you have a short in the electrical system possibly around your fuze box. Best thing to do is to just pull off all your plastics and trace the electrical system, looking for exposed wires or damaged wires.
Mar 06, 2012 | 2001 Suzuki GSX-R 600
I'm putting a new adition on and am wiring it. I have two rooms with ceiling fixtures and seperate switches and will put them on the same circuit. The first room will be powered from the fuse box to the...
Hello There,
I would put the Switch's Independently for each fixture, thought wired together through the same wiring to the fusebox.
If one Switch is wired to another, they could both alternate for the same fixture, however, use them independently:
with the wires connected from the fuse box, to independent switches, but the switches are hooked up towards the fuse box. And then from the fuse box, to switches, and then to fixtures. :)
Apr 01, 2010 | Atlas Hammering
1998 Jetta when you turn the heater on nothing happens the fan doesn't even come on.
If you are getting power to the unit will need to replace the blower unit. Try putting an independant power supply to the motor to see if it works. If the blower motor still won't work then you will have to source a replacement.
Nov 28, 2008 | 1998 Volkswagen Jetta
Acer 3680 will not turn on at all
take out the memory from bottom, and battery, plug into wall, and try again..
Mar 20, 2008 | Acer Aspire 3680 Laptop
Heating & Cooling Logo
37 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
