SOURCE: Singer Fashion Mate digital error E4.
E4 error.its the bobbin shaft error.first try to clean the bobbin case then turn the machine on for some minutes then turn on and check out.if still the same error then
Check the bobbin winder shaft. If it is pushed over when you try to run the machine you may get the error.adjust it properly.and check out.
if still the same problem the bobbin shaft needs to be replaced.as its slipping out.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
SOURCE: were can i buy bobins
bobbins are available at sewingpartsonline.com
http://www.sewingpartsonline.com/bobbins-singer-85128-10pk.aspx
try changing the needle--
Correct needle insertion is mandatory for proper use of your sewing machine.
Raise the needle bar to the highest point, then loosen the needle clamp screw to remove the old needle.
Place the new needle in the needle clamp with the flat side of the needle facing the back, (round needle, the groove in the needle should face away from the shaft).
Push the needle all the way up as far as it will go. Then tighten the needle clamp screw.
rethread the machine top & bobbin
make sure the thread has not come off the thread take up lever
also check the top thread tension
do you have a manual?
SOURCE: what does error E5 mean on the singer brilliance sewing machine
you tube has detailed videos on how to fix your error just type in e5 error on singer brilliance sewing machine and lots of videos will come up click the one that best explains your problem and hopefully this will help. you may have to try a phew before you get it right. hope this helps.
